Question about Gateway 6022GZ Notebook
Shutting off I would have to wiggle the power cord every now and then, I finally had to replace the cord completly. Computer worked for about 5 days then it started turing off. When I turn it on it will go through the login screen then shut off.
    Genius:
  • 2,028 Answers
Try running it without the battery and see if it does the same. Sometimes a bad power supply will cause a short to develop in the battery. If it stops shutting down without the battery the you'll need a new battery.
Posted on Jul 03, 2008
Can't turn my a/c off Or fan. I hit theoff button & just changes settings. Other than turn the car off itself, I can't figure it out. Earlier in the year rebooting the car'd work. No more.
Laptop not shutting completely (Power light and fan stays on ...
www.tomsguide.com/.../laptop-shutting-completely-power-light-fan-stay...
3 days ago - I have to hold the power button for 5 seconds for my laptop to turn offcompletely. ... I tried removing my battery completely, and started the windows with my A/C adapter and then shut it down ... when i shutdown my pc , my pc has get shutdown but the power light in my cpu tower ... Can't find your answer ?
Nov 19, 2015 | Computers & Internet
Icons wiggle
Your computer screen or monitor may have wiggling images when it is too close to electronic interference, such as a power supply, cell phone, non-shielded speakers, a fan or electric motor.
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 10, 2014 | Acer Computers & Internet
It seems like im having some issue with my syncmaster2493 monitor. it will black out and once i wiggle the power cord it will come back on. any help will be apprecaited
Your power supply board is failing and when you wiggle the cord it is turning it on and off until it finally starts up. There are parts called capacitors that start failing and it will cause intermittent power issues such as slow to show picture, flashing power button, wavy or flashing picture. The board can be repaired and the monitor will be as good as new. Here is a picture of the power supply with the parts circled that need to be replaced.
There is a step by step repair guide for the Samsung 2493HM unit here:
http://www.ccl-la.com/blog/index.php/reparing-a-samsung-2493hm-24-lcd-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Jul 30, 2011 | Samsung SyncMaster 2493HM Monitor
Printer won't start
1. completely unplug power cord from wall socket,
2. unplug power cord from printer
3. unplug printer cable completely from computer
4. unplug printer cable completely from printer.
5. let printer stay disconnected for approx 1 minute
Now securely:
1. reconnect the printer cable to the printer.
2. reconnect the printer cable to the computer
3. reconnect the power cord to the printer
4. reconnect the power cord to the wall socket
turn printer on
You may find that a connection has simply worked itself loose over time.
Mar 29, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
What do we do when Canon MX330 code comes up besides shutting off the printer and putting it back on?
Turn off your computer and completely shut down.
Turn off your printer.
Disconnect all cables and electrical cords from your printer.
Make sure the electrical cord is also removed from the wall.
Wait 5 minutes and reconnect the power cord to the printer.
Then connect the printer cable from the computer to the printer.
Turn on your printer
Now reboot your computer (cold boot)
Your printer should now clear itself.
Mar 23, 2010 | Canon PIXMA MX330 Multifunction InkJet...
Monitor will come on but then will click off and on
Sounds like a bad connection on the inside of the power cord socket on the back of the monitor. If you feel confident enough to take the back off just remove the power cord, remove the back and then wiggle the pins inside the socket 1 at a time and look in the back of the socket at the same time to see if the wires are loose on the pins, or if the wires from the pins are loose on the circuit board. May just need resoldering. If you can find out what it is it could save you money getting it repaired, unless you can do it yourself.
Feb 02, 2010 | Compaq FS7600 17" Flat Glass Monitor
HP Pavilion dv2020us laptop battery won't charge
How is your power supply? does it seem like you have to wiggle your cord that connects to computer to make it recieve power?...Many laptops power supply become loose over time form moving the cord around..when it does, the battery has a hard time getting electric power to recharge. Also, you my have other problems with your lithium internal battery that powers your cmos.
Check to see if your power supply is loose and go from there. the power supply is the little hole where you connect the cord to the laptop.
let me know what the status is
Apr 10, 2009 | HP Pavilion dv6000z Notebook
Will not power up for more than 1 second. Without battery installed, will not power up at all
Sounds like battery is dead. Have you been having problems with power cord? When you plug in power cord with battery installed you should see a charging light. Maybe wiggle coord and see if you get some power. Toshiba, In my opinion is a great computer, but they do have a poorly designed power plug. They are forever being broken from the boards. I hope this helps and if it is a bad power socket, you can get them from Ebay for about $5. Good luck and have good day.
Feb 02, 2009 | Toshiba Satellite A100-S8111TD Notebook
Computer stopped receiving wireless router signal
In this order: 1) Turn off all PCs and printers connected to the router. 2) Unplug your router's power cord. 3) Unplug your modem's power cord. 4) Wait for at least 2-3 minutes. 5) Connect the modem's power cord and wait for at least 2-3 minutes. 6) Connect the router's power cord wait for at least 2-3 minutes. 7) Turn on each PC separately and wait until it is completely finished booting before turning on the next PC.
If you still do not have connectivity, read the manual and change the channel of the modem. YOu may be experiencing some RF interference, ie microwave, wireless phone system etc...
Oct 29, 2008 | Linksys Wireless-G Broadband Router
Random powering down of my Z-5500s?
I have the same problem, logitech replaced the whole system under the warranty
May 21, 2008 | Logitech Z-5500 Computer Speakers
Computers & Internet Logo
79 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
