Question about Dryers
Frigidiare dryer no heat - Dryers
  • wo7777 Jul 04, 2008
    THIS IS A MODEL LEQ2152SEO. ERROR CODE E5B.
    EVERYTHING SEEMS TO WORK, BUT NOT DRY. 240 VOLTS ON R2 RELAY, CHART SAYS TO CHANGE CONTROL BOARD. DONE SO TWICE , NOT WORKING
    Genius:
  • 1,028 Answers
Remove lower panel (if it has one ) fine thermistor and schematic somewhere close by ckd thermistor for 50k ohms if a lot less bingo!
Posted on Jul 05, 2008
I want to try to put my washer (Frigidaire FTF model) on top/bottom of my dryer (also frigidaire). However, we didnt receive any brackets which are standard for stacking, so we are curious to how to stack...
Hello the advice about removing the top of the washer and bolting the dryer to it is exactly what to do.Under the washer top is built in brackets to do that.Every front load Frigidiare washer leave the factory pre-equipped to stack the dryer to it by removing the top and bolting the dryer to it
Aug 21, 2011 | Frigidaire FTF530FS Front Load Washer
I HAVE A FRIGIDIARE DRYER MODEL NUMBER LEQ1442ES0 AND IT DOES NOT HEAT. I HAVE TESTED EVERYTHING WITH A OHM METER AND IT CHECKS OUT GOOD. WHAT COULD BE CAUSING THE DRYER NOT TO HEAT UP?
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 10, 2010 | Dryers
My Frigidiare dryer will not heat up. Is it fried or what?
heatman101
Jun 04, 2010 | Frigidaire FGR341AC Electric Dryer
Neew lint filter
Your washer/dryer was made by Kelvinator / Frigidiare.
(This is the 417 prefix)
See the Sears parts list for your machine:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=417.99175120&pathTaken=partSearch
Do a part search on Lint filter and you should see the part number 3204278
Although the Sears site says that this part is "no longer available", by doing a Google search on the part number itself, you should be able to find a number of places that have that part.
Mar 27, 2010 | Kenmore Washing Machines
I have a frigidiare range that the oven does not heat up at all it is about 2 yrs old it has the digital display you can turn on and set temp but nothing happens
i would check your bake element make sure it isnt damaged or broken.... you could check the element also by turing off power removing the 2 screws inside the back wall that hold the element in place and testing the two ends for continuity with a meter,, if it reads anyting is good if notthin its bad......if its gas then check the ignitors...
Feb 05, 2010 | Frigidaire Kitchen Ranges
I have a dryer that is making squeal as the
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 11, 2009 | Dryers
Not enough heat
If your dryer doesn't heat, check these:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
May 15, 2009 | Dryers
Dryers Logo
105 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
