Question about PfaFF Hobby 4260
I can't thread the needle on the Pfaff 463 sewing machine I have. I do have the manual with the picture and numbers pointing at everything but it still isn't clear how to thread the needle. Do you have any instructions that are more detailed? Thanks.
  • Georg Carson Jul 30, 2008
    I need to get an instruction manual for the Pfaff 463. Could some one send a copy?
    New Friend:
Http://www.youtube.com/watch?v=a7vaoJxLlWA
this shows you step by step plus she has a bobbin video two.
Tara
Posted on Jul 30, 2013
There is a video on utube showing how. Spinktor.
Posted on Jun 23, 2009
Thread shred. Pfaff 463. Using 120/19 new needle. And Sunguard Anti-wick UVR bonded polyester thread for marine canvas. Why is my thread shredding?
From my past sewing experience (not an industrial machine), the thread will shred if the needle/thread/fabric are incompatible. Could be the canvas is too coarse and is wearing on the thread like sandpaper. Remember, the thread/needle will penetrate over 10 times before that section of thread actually forms a stitch, so that's a lot of friction going on. In regular sewing, a top-stitch needle has a larger scarf which acts to protect the thread, however, not sure that is a choice for your machine.
http://www.upholster.com/upholstery-forum/index.php?topic=11340.0;wap2
Is Pfaff 463 Suitable For Upholstery
Pfaff 463 Instruction Book
May 19, 2017 | PfaFF Sewing Machines
My Pfaff grand quilter 1200 keeps bunching up the top thread on the bottom side of my quilts. I've replace the needle and thread. It won't pick up the bobbin thread. Could this be a timing problem?
Remove the thread from the machine. (Always raise the presser foot and pull the thread up, NEVER down!).
Install a brand new needle.
ALWAYS RAISE the presser foot when threading.
Rethread from the beginning and verify the thread pathway is correct.
Set the upper tension to midway between High & Low numbers--you may need to tweak this for your particular machine, but this is a standard starting point.
Confirm the bobbin is loaded and threaded correctly in the bobbin case.
Begin sewing slowly. It helps if you begin sewing with the needle in the uppermost position.
Test on medium weight woven cotton.
If it is still not picking up the bobbin thread, then it most likely is a timing problem. You can search the internet for web sites and videos regarding sewing machine timing or take it for service.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
What causes Bird Nests Superior Threads
Nov 21, 2016 | PfaFF Sewing Machines
My thread keeps breaking every time I start sewing on my pfaff 4.0 sewing machine. O have changed the thread two times. re threaded the needle six times and ensured the needle was in the correct location....
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Sep 02, 2013 | Pfaff Creative 4.0 Sewing Machnie
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Jul 31, 2011 | PfaFF Creative 7570
I have acquired a pfaff 463-34/01 machine and require needles bobbins bobbine holder/s and a handbook Can you help? Regards peterjjohn@tiscali.co.uk Tel 01829 270931
i have bought a pfaff 463 machine and when i sew the thread going through the needle keeps on shreading..... any suggestions
Feb 08, 2010 | PfaFF Sewing Machines
Pfaff sewing machine hobby 850? from 1986...
Try installing a brand new needle. A bent/dull needle will frequently not pick up the bobbin thread.
If a new needle doesn't help, then most likely the machine has been knocked out of time (the needle and hook are out of sync). You can search for sewing machine timing to see if you want to try to fix it yourself or take it for service. Timing is usually affected when a needle hits something hard (like a pin, the needleplate or a hard seam of fabric) and is deflected
Jan 04, 2018 | Sewing Machines
Pfaff sewing machine 463
how do you thread a Pfaff sewing machine
May 20, 2008 | PfaFF Hobby 4260
Sewing Machines Logo
348 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
