SOURCE: JVC GR-DVL310 VISTA DRIVER
Your JVC is a MiniDV camcorder, which uses a Firewire connection for capture. Firewire drivers are standard for all DV camcorders, and built-in on every version of Windows since about Windows 98SE (well, they didn't work very well until Windows 2000).
You still need a capture application to complete the transfer. Most (maybe all) versions of Windows comes with Windows Movie Maker, which is a very basic program, but it can do this.
Normally, a DV camcoder can't be detected by Windows until you have it connected via Firewire, and have it the appropriate mode. On some cameras, this can be play or record (the latter would tranfer live video, or allow recording TO the camera), on others, you need to set the camera to a "link to PC" mode. I currently own Sony and Canon camcorders that both work in the former way, but my first DV camcorder was a JVC, and it did have to put in a "link to PC" mode to be detected by the computer. If you can't find the setting, you might want to check your user manual.
For still photos, it looks like you use a USB connection. I haven't found all the details on this camcorder, but this is likely to be a normal USB "storage class" connection. If so, your camcorder would show up like a disc drive, and you can drag photos over. Vista will support this by default, too.
The other way some older camcorders send photos is to appear to the system as a USB scanner type device. You would need a device driver for this, from JVC.
The user manual would be helpful here. You can get one via download if you don't have it:
http://books.jvcservice.com/booklist.asp?Model=GR-DVL310U
http://books.jvcservice.com/booklist.asp?Model=GR-DVL310UM
SOURCE: jvc- gr-d740 camcorder's cassette is not ejecting
There should be an error code star with E-01 to E-06.Below is an example you have to make sure that which error code showing on your camera
Whenever some abnormal signal is input to the syscon CPU,
an error number (E01, as an example) is displayed on the
LCD monitor or (in the electronic view finder).
In every error status, such the message as shown below
E01 LOADING--------
1. The mechanism is locked during mode shift.
2. The mechanism is locked at the mechanism loading
end, because the encoder position is skipped during
mechanism mode shift.
3. No power is supplied to the loading MDA
SOURCE: my jvc camcorder model GR D23Ek displayed remove
Hello :
Error 03 is very common in the Mini-DV models. This problem can be defective reel tables, or it can also be a defective rotary encoder. You can expect to pay intermediate to major labor for this type of repair. Parts are nominal.
PLEASE DON'T FORGET TO RATE .
good luck .
SOURCE: Sir, I am unable to connect my JVC GR-D725E
You need a Firewire DV connection on the laptop. Windows PCs usually don't have one. Quite often these mini-DV camcorders won't work with Windows 7 anyway. If this camera worked with your old computer, you should keep it around just to get the tapes into a computer file, which you can transfer to the new laptop on a memory stick or network.
