Computer will not stop running, but is not connecting or showing anything on the monitor
  • Anonymous May 02, 2009
    i hve the disc in and the USB attached to the camera and nothing works
    Problem Solver:
  • 4 Answers
Try a new screen, had the same problem with mine, i was using a CRT and my computer didnt like it after awhile and only works on LCD screens now
Posted on Jul 03, 2008
Dell laptop screen unreadable
Yes, it won't change anything because it's not a software problem. It has something to do between the connection of your LCD screen and your motherboard. Or your LCD backlight has a problem with it.
What you need to do is to open your computer and reset the connections inside. It should be the connection between your motherboard and the monitor.
I suggest you visit www.support.dell.com for more information on how to do that or if you want help then you can contact dell's tech support if you still have the phone support warranty.
I hope this helps!
Carlo
Dec 20, 2012 | Dell Vostro 1510 Laptop
Aspire AX1200-U1510A starts but monitor doesn't show anything. Monitor works with an odl Dell.
If an old Dell monitor works with your computer then that monitor has something wrong with it.
Try to plug in the monitor to a wall outlet but do not plug it to your computer. If it still doesn't show anything, then you should replace it. You can contact the manufacturer of the monitor. You might have a warranty for it. They might fix it or replace it with a new one.
I hope this helps.
Carlo
Nov 20, 2012 | Acer Aspire X1200U1510A PC Desktop
Packard Bell monitor showing colors
Replace the monitor, is dead.
Aug 04, 2012 | Computers & Internet
I have an hp dv5 1004nr when it was on it would go out and show strips in def. colors no will not turn on
Are you saying the computer will not turn on at all or are you saying the monitor will not turn on?
If it sounds like your computer is on and running but you don't see anything, then your monitor is bad based on the stripes you say it used to show.
Plug in an external monitor and see if thedisplay shows up on it. It can be any kind of monitor even the old big fat crtmonitors as long as it has a vga cable to connect to your computer's vgaport. If so that proves your video card is ok. The video will showon most systems when you reboot without you having to do anything. Some systemswill require you to hit the FN (Function key) + F1 thru F12. Hold downthe FN key then hit the correct key for displaying on the monitor (F1 thruF12). The correct key will normally have CRT/LCD on it or it will havethe icon of a display.
Apr 26, 2012 | HP G60-235DX Notebook
CPU will not reboot
computer not starting up,theres a bios reset button,try that,does the monitor show anything atall,if not check cable to monitor
Jul 05, 2010 | Siemens Simatic S5 HMI Monitor
My screen is showing Self test feature check and will not stop! Help!
The first thing to check is--is your computer actually running?
It sounds like your computer is either off or it is not sending a video signal to the monitor.
If there was a signal going to the monitor, you would be seeing something other than self test.
There is also probably a menu button on the monitor. Find it and push it to reset the monitor.
Now check your computer--preferably with another monitor to see for sure what is going on.
Oct 22, 2009 | Dell Computers & Internet
PC running without anything showing on monitor.
Hi
Sounds like you have somehow deleted the driver for the monitor - - you need to plug another monitor into your PC - you can use the laptop you are using now - then you need to download the driver for the monitor again when you can see on the screen
May 03, 2009 | E-Machines eMachines Desktop PC
24" CRT HP A7217A Monitor stopped working
hello sir your vertical or horizal IC damaged.......... thats why its showing multi colour ...... just do one thing sir.......... fit your new IC
if your problem not solved..... type in comment
Apr 29, 2009 | HP A7217A (White) 24" CRT Monitor
Analog Monitor problem
The problem in your monitor is SRGB
Use 3 simple steps to rectify this problem
1. Connect your monitor to another CPU
2. Change The Resolution to 800x600 32/24bit
(After 2 Miniuts SRGB will Reset)
3. After 5 Miniuts change the monitor to your CPU
Thank U
Apr 06, 2008 | Computers & Internet
I am trying to connect my laptop to the Polaroid LCD TV, as i would like to use the TV monitor as a computer monitor (my laptop monitor is broken). So I connect the correct wire to correct places, however...
The simple patch that I found (same problem) was to start by using any old monitor that I could borrow to set up my Dell Laptop.
After getting the Laptop booted on a regular monitor I right clicked on the desktop and went to properties then to the settings tab.
Here I found the dual monitor settings (#2 will usually be dis-abled by default.)
Click on #2 monitor and set the resolution to the lowest number (800 x 600 works well)
Then I clicked on "make this monitor my primary monitor"
As soon as I clicked apply the PC Windows screen appeared on the Polaroid TV screen
Earlier I had set the secondary monitor as "extend this screen to this monitor"
This also worked but I had to "drag the current screen to the right all the way off the
"borrowed monitor" until it appeared on the TV screen. The mouse pointer will be there also.
At first it took a little getting used to but in a few minutes I was up and running.
Hope this helps your situation
David Flournoy
Waxahachie Texas
Mar 10, 2008 | Televison & Video
Computers & Internet Logo
David Payne
David Payne
