Question about Ricoh Office Equipment & Supplies
Ricoh 1085 do oyu have technical Cds or maintenance manuals
    Problem Solver:
I have one
Posted on Jul 03, 2008
Sc 491 for ricoh aficio 1085
sc491 on a Ricoh 1085 is a problem with the fan that cools the polygon mirror motor, in the laser unit. The problem might lie with the fan motor itself, or it might be another problem inside the laser unit. You could try replacing the fan (part #A2941965) but that may or may not fix the problem -- and you may not even be able to find a new fan anywhere, since the 1085 is so old. Ricoh stops producing new parts for old machines after a certain number of years.
The laser unit sits under the scanner bed... remove the platen glass and the laser covers and try cleaning the unit out with some compressed air. Then reboot the machine and see if the code clears up.
Jun 21, 2010 | Ricoh Aficio 1085 Laser Printer
I want to buy a Ricoh 1085 that looks in good condition, but the hard drive was removed for security reason, Will it work with out the hard drive?
No, the 1085 needs the hard drive to run. You're better off trying to find a newer copier anyway -- the 1085 is ancient and you probably won't be able to get a lot of replacement parts for it. You can probably find a 2090 or 2105 for a good price -- those machines are still supported and will run for a long time.
May 27, 2010 | Ricoh (400614) 6 GB Hard Drive
Error 592....
Hello sir; The error code you display, means the toner motor defect, just replace it, will take care your problem.
May 27, 2009 | Ricoh Aficio 1085 Laser Printer
I want download the engine firmware ricoh aficio 850 1085 105e
When I can download the firmware cicu / bcu 8.1 by ricoh aficio 1085?
Mar 27, 2009 | Ricoh Aficio 450 Copier
Use as a scanner .... How to ?
you must first connect scanner interface drive board
Jan 22, 2009 | Ricoh Aficio 1085 Laser Printer
Ricoh 1018d not print with lan conection
Hi Usama,
I had the same proplem as you when i installed pcl6 driver on my ricoh 1085
I solved but by uninstalling pcl6 driver and installing pcl5e
for your 1018d try this driver for windows XP D O W N L O A D H E R E
BTW.
about using 1085 as a scanner ,
I don't know what is "scanner interface drive board" ?
more help please.
Oct 23, 2008 | Ricoh Aficio 1085 Laser Printer
Error Code SC580 on Ricoh Aficio SP C811DN
First try switching off and on the printer to reset the error.
If still there the error check the following;
  1. Check CN983, it may be disconnected on the IH inverter.
  2. Defective IH inverter - replace IH inverter.
  3. Defective IH coil unit - replace IH coil unit.
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
Jun 04, 2008 | Ricoh Aficio SP C811DN Laser Printer
This soo good site
devolper type 14 &type 21
May 18, 2008 | Ricoh Aficio 1085 Laser Printer
SC547
try to replace power supply
Apr 24, 2008 | Ricoh Aficio 1085 Laser Printer
Ricoh Aficio 1085 Paper Tray 1 Jamming
you can change the tray setting in user mode to tray 2 and same time do not fill the tray one. same apply on print job from a computer, select tray two as default with print driver.
Jan 07, 2008 | Ricoh Aficio 1085 Laser Printer
62 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
