Question about Whirlpool GGQ8831L Gas Dryer
WHIRLPOOL DRYER WHAT KINDS OF DRYER BELTS FIT AN OLDER MODEL WHIRLPOOL DRYER?
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Provide me with a model number and I can probably find out for you. Most dryer belts are standard among certain brand names. Even though the dryer case looks different on the outside with newer models, the internal components (i.e., drive motor, idler pulley, heating circuits) are still the same.
    Genius:
  • 1,028 Answers
Part # 341241
Posted on Jul 05, 2008
Can I stack a new whirlpool washer model # WFW72HEDW with an old whirlpool washer model # WED9270XW1? If yes, what stacking kit do I need to use? Can I stack a new whirlpool washer model # WFW72HED
As we could see new one are not compatible with older one as size and dimension of new washer are changed but in case you could try .It is simple just try compatibility of your older washer stack kit with new one in most new model
Oct 14, 2014 | Whirlpool 8541503 Duet Stack Kit 8541503
I changed the heating element in my whirlpool dryer (older model). I replaced it but the wires to the element and the wires to the thermostat are similar. 3 are red and 1 is red with a white stripe. I am...
there should be a red and then a red and white wire going to the element and the wires going to the element are thicker than the t-stat wires,also if it's an older machine if you just let the wires hang free they should almost line up to where they should go because they've been in that position for a while.
Nov 11, 2017 | Whirlpool Dryers
Please, can you tell me how to tighten the belt on an Inglis dryer model J073500
Sorry for the troubles but you cant tighten the belts on those or any dryer for that matter. Here is the problem your belt is worn out and that's why it is loose and if you have replaced it and its loose you are installing the belt incorrectly around the idler pulley or have the wrong belt or your idler pulley is worn out. I hope this helps solve the issue your having and for instructions on installing the belt go to youtube and type in whirlpool dryer drum belt installation they will show you the correct way to do it and whirlpool builds your model dryer.
Jan 22, 2011 | Dryers
Fit new drive belt to tumble dryer
I need to know more. like how to instal belt or how to find what belt fits your dryer . need more info like mod # there 5 different belts for hotpoint . and several different ways to install them so model # ______________ needed . **** . pls .
Jan 02, 2010 | Dryers
Whirlpool Dryer (model lg5791xmw1) blows cold air. I switched out the igniter, dryer heated up and we put a load of laundry in. Checked in a half hour and dryer was running cold again. Thermal fuse?
no, cause thats a one shot deal, check your hi-limiy switch on the element case,they get weak from heat and can cause all kinds of (Under-Overheat) problems
Oct 15, 2009 | Dryers
How do I replace the belt on a Whirlpool Dryer LER7646EQO and where do I get one of these belts?
you will need a putty knife to insert in the front gap on the left and right ends to remove the top. belts can be bougth from Sears .
Jun 06, 2009 | Whirlpool LER4634J Electric Dryer
Older model Whirlpool oven 24
do you not know what a tape measure is or how to use one .we can not go shopping for you .
Feb 01, 2018 | Ovens
Kenmore dryer
The belt you will need for that unit is part # 341241. These belts will fit almost all Whirlpool and Kenmore models except for the DOTT (Dryer Of Tomorrow, Today) dryers. A DOTT dryer is a Kenmore model only, and has a front kick plate and the lint filter in the door.
Jan 27, 2008 | Dryers
Whirlpool GGQ8831L Gas Dryer Logo
59 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
