Question about Intel Motherboard
Press F4 always message to press F4 at the time of starting
  • 36 Answers
Svjyrat
"always message to press F4 at the time of star up". this problem happen when CMOS detect any error. is also happen if CMOS battery fail (Chack sum error).
to solve this problem at first check CMOS battery (it voltage less then 3V or not) if it bad then replace it. u can buy this battery form any computer accessories shope.
or if u not connect floppy drive, and controller enable. if u desable floppy drive contoller from CMOS setup (in intel mother board is show BIOS setup) then this problem solved.
Posted on Jul 03, 2008
How do i get the internet explorer message that appears from time to time off the screen of motorola mc3190 without having to shut it down
The key combination you looking for to close any window or message in a Windows environment is ALT+F4, depending on the type of keypad the Motorola MC3190G are using.
Please Note: Keypad functions can be changed by an application so the mobile computer keypad may not function as described.
48-Key Keypad
The ALT functions are indicated in blue on the keypad, so in order to use these, you have to activate the ALT Functions first by pressing the BLUE BUTTON (FUNC) (Right side below ENTER button) and then press the CTRL BUTTON (left side below BKSP button).
After the key combination is pressed, the ALT icon appears on the taskbar on WinCE devices or the ALT icon appears at the bottom of the screen on Windows Mobile 6.5 devices.
Now you can press the "D" button to use F4, this will close any window or message that is currently in view.
38-key Keypad
Press the blue FUNC BUTTON (Right side below RIGHT ARROW button), and then press CTRL button (Middle below UP ARROW button), now you can press the F4 button.
28-Key Keypad
Press the blue FUNC button (Bottom right next to Power button), and then press the CTRL button (Top right side below RIGHT ARROW button), now you can press number 4 to use F4.
Hope this helps, good luck.
Jul 02, 2014 | Zebra Symbol MC3190G Handheld Mobile...
How to change the date and time?
Simultaneously press [F2] & [F4].Key in 1, Alpha, Alpha, 66831 and press [Enter].Select CLOCK [F3].Key in the Year, the Month and the Day and then press [Enter]. Do not press [Enter] between these values, the terminal will automatically populate the appropriate fields as they are entered. Use the down arrow to scroll down to check/adjust the time. Key in the hour, using military format (ex: 3 p.m. = 15), then key in the minutes and press [Enter] to complete and return to Menu 1. Do not press [Enter] between these values, the terminal will automatically populate the appropriate fields as they are entered.when finish Select Restart [F4].
Mar 08, 2011 | VeriFone VX510
When I turn on my roland vs 2480 it never makes it past the load project start up screen. What can I do? please help
moz-screenshot.pngHave you tried to do a factory reset?
Hold SHIFT and press F4 (Utility). Press PAGE to get to page 3. Press F6 (PrmIni). Press F5. Press ENTER/YES
Dec 03, 2010 | Roland Vs2400CD Digital Workstation W/CD...
My son has a TI-84 Plus calculator and it is completely frozen. There is a message on the screen that reads " RAM cleared". Below that message it says "Press ALPHA F1-F4 to locate shortcut menus" but it...
The calculator OS has been upgraded to the version 2.53 MP.
For this version, whenever you remove batteries (or replace them) and turn calculator ON, you are reminded to Press [ALPHA][F1-F4] to locate Shortcuts Menu.
The calculator also asks the user to press either
[1:Do NOT show Again]
[2:Continue].
Here is what these cryptic messages mean.
Certain functions implemented on the new OS are available by pressing the [ALPHA] key followed by F1, F2, F3 or F4.
Since you may forget how to get to them, the calculator gently reminds you that there are other functions accessed only by pressing the [ALPHA] key.
It also gives you the option to flash the reminder every time the calculator memory is reset (CONTINUE) or NOT to SHOW the REMINDER again.
Usually after the RAM cleared message, press [2:Continue] or any other key but [1: ] to keep being reminded how to access the new functions.
Once a key is pressed the screen is cleared and you have the solid blinking cursor.
Oct 06, 2010 | Texas Instruments TI-84 Plus Calculator
''Press Clock'' but can't press buttons, then beeps with F4 error
F4
Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor
Sep 07, 2009 | GE Microwave Ovens
Computer freezes when I start it
Please make sure the boot device is correct from BIOS.
If correct please boot your system from Windows XP bootable CD and choose recovery option in Command Mode.
run the command
chkdsk /f C:
Check the result and let me know if any error comes.
Jul 30, 2009 | Computers & Internet
I have a hp pavillion dv2315nr laptop with a black screen. In the past, I was always able to resolve the issue by pressing fn/f4 at start up which worked but takes a long time to kick in. Now however...
when you power up the press F8 key then enter in enable vga mode then go to control panel ->display ->settings ->change screen resolution to 1024*768 then apply and ok then restart .
Thanks for using fixya.
Please rate solution if it helps.
Jul 25, 2009 | Computers & Internet
Bios date and time problem
You need to replace the cmos battery in your computer. Theu are usually Cr2032 batteries which you should be able to pick up for about £1.
unplug your computer and open the case.
When you look at the motherboard you should be able to easily locate the cmos battery cliped onto the mobo.
Take the old battery out and insert the new one.
put the case back on and plug the pc into the mains again.
You will need to re-enter the date etc the next time you boot up, but the settings should be retained after that.
Ian
Mar 09, 2009 | Dell OPTIPLEX GX150 PIII-1.0GHz 256MB 40GB...
CMOS bad message being displayed
what you should do? here is what you do.....a simple idea....replace the CMOS battery and 100% it will work good...it will not bugging you everytime you open the pc....check,i need to share only my experience.
Mar 03, 2009 | Intel D845GVSR Motherboard
Starting problem
Check the cables to your HDD
This can be the problem.
Sergio
Jul 23, 2008 | Computers & Internet
Intel Motherboard Logo
303 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
