Question about Kenmore 63942 Dryer
Kenmore heavy duty 70 Series Electric Dryer
The clothes are sometimes getting light/streaky burn marks on them. I checked vent pipe and it is completely clear. Any suggestions?
  • 1 more comment
  • dburris Jul 25, 2008
    jsrock516, sorry for the slow response but my model # is 96374200 63742. I look forward to your response.
  • bgc63 Sep 26, 2008
    I have the same problem with the streaks on clothes. How hard is it to replace the felt drum gaskets?
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Those may not be burn marks. Your clothing may be getting caught in the felt drum gasket seal. If the seal is worn sometimes clothing can become caught between the drum and the bulkhead and leave brownish colored rub marks on your clothing. Post back with your model number and I can see if I can find a part listing for you to illustrate what I'm talking about.
  • 868 Answers
If you are using Fabric Softener Sheets than look in the dryer closely for one to be wedged in a fin or anywhere inside .They will make the streaks you mention. Please rate this !!!
Posted on Jul 09, 2008
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
80 Series Gas Dryer - No Heat. All other parts
check outside drye vent where it goes through the wall they clog up with lint sometimes and force the escaping warm air to back up which causes sensor to give wrong reading if this is clogged just clear it till you feel the air coming through also check vent at bottom of dryer disconnect flex pipe and check for clogs there as well ..and always clear lint trap after every load
Dec 13, 2009 | Kenmore Dryers
Kenmore Electric Dryer Series 80 Model
Disconnect the dryer from your vent completely,. pull dryer out 3 ft. from wall and test to see if the smell continues, You have to test for a few minutes to clear out any burning lint from vent restrictions. If the smell hoes away then you know you have venting problems. Also check on the grate that covers the element( the part you look through when you see the orange glow from the element) sometimes plastic or clothing burns onto this grate and needs to be cleaned off. I the smell remains, you will have to tear down the dryer to see if you can find the cause of the smell.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Dryer wont start.
can you hear the motor or does the unit humm or vibrate when it is turned on
if yes then have a look at the belt
if not it's time sor a service call
Aug 04, 2009 | Kenmore 700 6972 Dryer
Kenmore 70 Series - 2 years old. Won't dry clothes, but there is definitely heat. Had a similar problem a year ago and ended up being a bird nest in the vent piping. I took off the vent piping nearest the...
Check for lint build up in the flex pipe connecting the dryer to the vent pipe..
While it's disconnected clean the duct on the back of the dryer..
A great lint cleaner is a "webster duster" on a pole...you can get alot of lint out with one of these..
k
Jun 18, 2009 | Kenmore 63942 Dryer
Kenmore 70 series electric dryer. Clothes are
most common reason for this would be clogged vent...check all the way in and out!
Mar 16, 2009 | Dryers
Kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Kenmore 70 series dryer leaving brown marks
you can get the parts direct from www3.sears.com and to replace it you pop up the top, take 2 screws out holding front panel onto cabinet and take off, take belt loose from idler and motor and slide drum out ,, go back same way / thanks
Jan 13, 2009 | Dryers
Clothes don't dry but dryer gets hot
ck vent to outside starting and dryer back to verify vent issue try drying a load with hose disconnected
Nov 24, 2008 | Kenmore 60172 Electric Commercial Dryer
Kenmore 63942 Dryer Logo
306 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
