Sony Walkman NWZ-B135  MP3 Player Logo
A
Anonymous Posted on Dec 20, 2010
Sony nwzb152f is not recognised. after plugging in it shows as "found new hardware" and walkman. after some time it shows as mtp device with a message " a problem occurred during installation, the device might not work properly. it does not also show in my computer. in the device manger it shows under portable devices with a yellow exclamation mark.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 22, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1363
Points
9
I am having Sony NWZ B152f it is stucked and displays POWER OFF screen ....Buttons are not worked
Anonymous
Level 1:
New Friend:
  • Posted on Nov 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1363
Points
I've one like it but it stucked and displays power off on the screen .. so what should i do ?
2helpful
2answers
Nwz-e344 sony walkman isn't being recognized by my computer
If your PC has windows XP sp2 or later and Windows Media Player 11 try to do these steps:
1. Connect the player to the computer.
2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed.
3. Select Hardware tab, and open Device manager.
4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX.
5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed.
6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next.
7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method.
8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option.
9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed.
10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
I hope this helps.
Thanks.
gylacz
2helpful
2answers
Hi am trying to connect it with my pc but its asking new hardware found "mtp device driver" but not installing just poping up againg and again not connecting with pc
You don't need any driver software, if your pc has windows xp sp2 or later and Windows Media Player 11.
If you have problem with your device follow this steps:
gylacz
113helpful
3answers
Sony Walkman not connecting to computer
I had a similar problem (my computer uses Windows XP) - Sony Walkman beeps a couple times when I insert the USB Cable that connects it, like it is connecting, but it does not charge or is not found by Windows Media Player. In my case, the way I fixed it was to:
1, Go into Control Panel
2. Double Click 'System' ICON
3. Select Hardware Tab
4. Select Device Manager
5. Select 'View' at the Top
6. 'Devices by Type' AND 'Show Hidden Devices' should be selected
7. 'Scroll down to 'Portable Devices' and open it up.
8. My Sony Walkman was there with and Exclamtion point ( ! ) in a yellow circle,
9. Right Click on this yellow exclamation point.
10, Select 'UNINSTALL'
11. Once the computer says 'Device has been Uninstalled, Disconnect your Walkman's USB cable then reconnect.
12. At this point, my Walkman was recognized by my computer, started charging, and was recognized by Windows Media Player
Hope this helps
28helpful
6answers
Sony nwz-b135f problem
MTP problem SOLVED!!!!! Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} I have a Sony MP3 Player(NWZ-B135F). when i inserted it to my pc's USB port(which is working fine), win XP (SP 3) prompted "Found New hardware" wizard. I followed the steps and finally I reached to a step where it shows “MTP device Problem......” I tried many times with different USB ports, but the same problem happened.
Fully frustrated, I finally did what the whole world does, GOOGLE my problem. Google showed me a lot of posts but nothing could solve my problem. Microsoft was providing the MTP driver, but only after a lot of authentication and procedure, which I was not going to follow….
After repeatedly experimenting by inserting my MP3 player, I got the solution!! It is as follows:
1) Insert your music player in the USB port. You will get a Hardware Installation wizard by XP.
2) Select, “No, Not this time” and click next.
3) Select “Install from a list or specific location (Advanced)”.
4) Select “Don’t search. I will search the driver to install”.
5) Select “USB Mass Storage Device” and then click "Next"
7) Wow!! Now you are done!!!
Enjoy and listen to your favorite music!!
5helpful
My mp4 player wont connect keeps coming up connecting usb mtp
Great Solution by  DCDW
Rank: Apprentice
Rating: 95%, 43 votes
I first found that when I plugged my player into my computer it registered it as a MTP (Media Transfer Protocol) device and in turn never showed up as a storage device on my computer. I fixed this by going into my Control Panel -> System Icon -> Hardware Tab -> Device Manager button.
Clicking on the "System Devices" tab should have "Walkman" or MTP device. Right click on it and go to properties, now before doing anything it should say "Location -- ------ Location 0 (Walkman)" if not try unplugging the walkman and see if the MTP device you're looking at is removed from the list, just to make sure it's the right device we're looking for.
If you've confirmed it's the Walkman, click on the "Driver tab" and click on "Update Driver...". Then click on the "Install from a list or a specific location (Advanced)" option and click "Next". Now select the "Don't search. I will choose the driver to install." and click next. It should now bring up 2 driver choices, one being "MTP Device" and the other "USB Mass Storage Device". Select the USB option and select next, it will then install your walkman as a USB storage device and after that's done. It should be a matter of unplugging and plugging the Walkman back in and it should show up on your storage options in "My Computer"
1helpful
6answers
Problem installing driver
I first found that when I plugged my player into my computer it registered it as a MTP (Media Transfer Protocol) device and in turn never showed up as a storage device on my computer. I fixed this by going into my Control Panel -> System Icon -> Hardware Tab -> Device Manager button. Clicking on the “System Devices” tab should have “Walkman” or MTP device. Right click on it and go to properties, now before doing anything it should say “Location — —— Location 0 (Walkman)” if not try unplugging the walkman and see if the MTP device you’re looking at is removed from the list, just to make sure it’s the right device we’re looking for.
If you’ve confirmed it’s the Walkman, click on the “Driver tab” and click on “Update Driver…”. Then click on the “Install from a list or a specific location (Advanced)” option and click “Next”. Now select the “Don’t search. I will choose the driver to install.” and click next. It should now bring up 2 driver choices, one being “MTP Device” and the other “USB Mass Storage Device”. Select the USB option and select next, it will then install your walkman as a USB storage device and after that’s done. It should be a matter of unplugging and plugging the Walkman back in and it should show up on your storage options in “My Computer”"
3helpful
2answers
NWZ-B103F MP3: connected to USB port on pc( vista) and tried on laptop( xp)
68helpful
9answers
Sony Walkman NWZ-B105F MP3 wont connect
42helpful
9answers
MTP DEVICE Sony 4gb walkman NWZ-S616 not installing
if you have a problem about MTP Device and wont be able to show in your "My Computer", here are tips that may help you fixed your problem:
*First- Uninstall the MTP Device Driver in your system.(Right click My Computer then manage, then click Device manager at the left part, then after that, find MTP Device in your right part, then click and Right click the name of your MTP Device then uninstall.)
*Second- Reconnect the device and then after a pop-up show which says, New hardware found,
click install the driver in a specific location, then choose the bottom option and then choose
Storage Device.
*Lastly- Turn On your Device and search it in My Computer.
that's all, and i hope i do a little help to you!
Mark Anthony Quintana
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
