Tally 6306 Matrix Printer Logo
Posted on Dec 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tallygenicom 6306L Line Matrix Printer - Problem as follows : Junk information are printed For example in place of a it is printing b, in place of 1 it is printing 0 etc. Also Each line is printed on a new page.
Anonymous
Level 2:
New Friend:
  • Expert 60 Answers
  • Posted on Feb 02, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
60
Questions
0
Helped
11677
Points
159
HAMMER CALIBRATION DONE WORKIKING FINE
Sir, We have a Genicom 6312 L Line Printer. This printer is attached with UNIX (5.9) system. It was working fine till few days back. Recently we changed the Logic Card. After this the printer is not...
If the printer does not print from Unix via parallel interface, it may be nessesaey to set the BI-DIRECTIONAL setting within the Parallel interface settings to OFF.
1helpful
Printer TallyGenicom T6312 printing blank pages
This is most likely caused by a problem with the print gap mechanism. It seems the print gap sensor was not able to adjust the gap correctly for your paper. The first I would try is to update to the current firmware version (4.0A) which is in many times solving the problem. If not you would need to replace the print gap sensor.
6helpful
2answers
T6312
The problem coming from your logic card hammer bank cable . Need to be replace logic card and hammer bank cable.
1helpful
6306L line printer not functioning? Is there any problem in logic
6306L line printer not functioning? Is there any problem in PAPER SENSOR, KINDLY GIVE ME PICTURE AND PART NO SO THAT I CAN ORDER THIS PART ALSO IF I CAN GET PRICE IDEA FOR THE SAME
' /* * For text ads, append each ad to the string. */ for(i = 0; i ' + 'Ads by Google' + '
' + ' ' + google_ads[i].line1 + '
'; url = '' + google_ads[i].visible_url + ''; info = '' + makeBoldAdWords(google_ads[i].line2) + ' ' + makeBoldAdWords(google_ads[i].line3) + ' '; s += url + info; s += ''; } s += ''; } document.write(s); G_GGL_SKIP += google_ads.length; return; } var G_MAX_ADS_WL = 1; google_ad_client = "pub-8183356113384228"; // substitute your client_id (pub-#) google_ad_channel = "2849999023+2438490332+4447185069+8396243181"; google_ad_output = 'js'; google_max_num_ads = '1'; google_ad_type = 'text'; google_feedback = 'on'; if(typeof G_GGL_SKIP == 'undefined') { G_GGL_SKIP = 0; } google_skip = G_GGL_SKIP; // --> google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); Ads by Google
half your printing costs
www.hp.com/in/deskjetget the HP deskjet advantage cost per page 72 paisa only
4helpful
My printer stoped in the midle of print
The 2280+ is indicating a defect with the paper width sensor, the paper width sensor on the 2280+ is locate on the carriage and detects when you try to print off the paper.
You may wish to disable the paper width sensor. To continue printing, this can be done in the following way.
Power the printer on holding down ONLINE
When the printer displays ASCII80 ASCII136 along the top line of the display release the ONLINE button.
Press the Button under NEXT (button 4) repeatedly until you see APW
Press the button under APW
Press button 3 to change this to OFF
Press SET
Place the printer ONLINE to exit the menu.
This will disable the Paper Width sensor which should resolve the issue with the message being seen. You can then get an engineer to look at the paper width sensor to see why this is not working.
TallyGenicom 2265+ not printing with custom paper size
There may be a number of causes for the problem you are seeing. There are a number of places which may hold the origin to the page length problem you are seeing, in order of precedence these are;
  1. The page size set in the software package printing the 6 x 4.25 cards
  2. The page size set the printer driver printing to the printer
  3. The page size set on the printer
I would recommend the follwoing;
  1. Set the form length on the printer to 6 inches (i am assuming this is the length of the card)
    The form length can be set through the menu and is normally set in lines (normaly the print size is set to 6 LPI) so the form length should be set to 33 lines
  2. Create a custom form size in SERVER PROPERTIES on the Windows XP machine to match the form size you are using.
    Ensure you select this form size in both PRINTER PROPERTIES and PRINTING PREFERENCES
  3. Try printing some Windows Test pages to see if these respect the page size selected withing the printer driver properties.
If the Windows Test Pages do not print correctly I would recommend checking how you are creating the CUSTOM SIZE form, perhaps create a new form and double check the form properties one it has been saved to confirm these are correct.
Check you are using the correct printer driver for the printer, you should be using the 2265+ printer driver. As a test you may wish to install the GENERIC TEXT printer driver or the EPSON LQ2250 driver, these will be included in the Windows Add Printers Wizard and should print OK to the 2265+.
If the Windows Test Page prints OK I think you would need to look at the software package printing to the printer. Ensure the correct page size is selected here also, perhaps try printing from another software package selecting your custom size form to see if these print correctly.
It is passable your software package is sending escape commands to the printer to call up the page size, I note you say Genicom printers printed ok from Win 98. The 2265+ may not have the same emulations as the Genicom printers.
You can print a menu print on both Genicom (if these are available) and 2265+ and compare the settings on these.
I do not believe the 2265+ has a Genicom emulation as standard, but you may be able to load an alternative version of firmware into the 2265+ which provides the Genicom emulation. If the data going to the printer contains Genicom Escape command to set form length this may resolve the issue.
You may need to contact your TallyGenicom support department for the firmware (I think it may be called 7265+ firmware)
If you are able to provide Hex Dumps of the data to the TallyGenicom support people they should be able to say what is going wrong with the form length setting.
My print out cat read some line very light and some line very dark priner is tally genicom 2348
I would recomend the following;
  1. Check the ribbon is seated correctly in the printer
  2. Check the ribbon is not jammed or tight to move
  3. Check the print head gap, ensure this is not trapping the ribbon
  4. Change the ribbon for a new one
  5. Check the ribbon drive is ok
TallyT2240 Dot Matrix only prints the middle part of the caracters
It sounds like you have one of two problems;
1) The ribbon cartrige it warn out or damaged, leading to no ink in a particular area.
More likely
2) The print head is damaged or warn out or is not connected correctly to the pritner. The print head may need to be reseated or if this does not fix the problem the print head may need to be replaced.
Top Tally Office Equipment & Supplies Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
