Question about Acer Aspire 5100 Notebook
Power I shut down the laptop saw it logging off but when the screen turned black the power button and the HDD button is still active. I waited and waited for the lights to go off but it didn't. I closed the laptop and after a while opened it and still everything's on. what seems to be the problem and what do i do? Thank you.
    Sergeant:
  • 313 Answers
1.
Connect your wireless router
Since you'll be temporarily disconnected from the Internet, print these instructions before you go any further.
First, locate your cable modem or DSL modem and unplug it to turn it off.
Next, connect your wireless router to your modem. Your modem should stay connected directly to the Internet. Later, after you've hooked everything up, your computer will wirelessly connect to your router, and the router will send communications through your modem to the Internet.
power - efefddd.jpg Next, connect your router to your modem:
If you currently have your computer connected directly to your modem: Unplug the network cable from the back of your computer, and plug it into the port labeled Internet, WAN, or WLAN on the back of your router.
If you do not currently have a computer connected to the Internet: Plug one end of a network cable (included with your router) into your modem, and plug the other end of the network cable into the Internet, WAN, or WLAN port on your wireless router.
If you currently have your computer connected to a router: Unplug the network cable connected to the Internet, WAN, or WLAN port from your current router, and plug this end of the cable into the Internet, WAN, or WLAN port on your wireless router. Then, unplug any other network cables, and plug them into the available ports on your wireless router. You no longer need your original router, because your new wireless router replaces it.
Next, plug in and turn on your cable or DSL modem. Wait a few minutes to give it time to connect to the Internet, and then plug in and turn on your wireless router. After a minute, the Internet, WAN, or WLAN light on your wireless router should light up, indicating that it has successfully connected to your modem.
3.
Configure your wireless router
Using the network cable that came with your wireless router, you should temporarily connect your computer to one of the open network ports on your wireless router (any port that isn't labeled Internet, WAN, or WLAN). If you need to, turn your computer on. It should automatically connect to your router.
Next, open Internet Explorer and type in the address to configure your router.
You might be prompted for a password. The address and password you use will vary depending on what type of router you have, so refer to the instructions included with your router.
As a quick reference, this table shows the default addresses, usernames, and passwords for some common router manufacturers.
Router Address Username Password 3Com
http://192.168.1.1
admin
admin
D-Link
http://192.168.0.1
admin
ts.gif Linksys
http://192.168.1.1
admin
admin
Microsoft Broadband
http://192.168.2.1
admin
admin
Netgear
http://192.168.0.1
admin
password
Internet Explorer will show your router's configuration page. Most of the default settings should be fine, but you should configure three things:
1.
Your wireless network name, known as the SSID. This name identifies your network. You should choose something unique that none of your neighbors will be using.
2.
Wireless encryption (WEP) or Wi-Fi Protected Access (WPA), which help protect your wireless network. For most routers, you will provide a passphrase that your router uses to generate several keys. Make sure your passphrase is unique and long (you don't need to memorize it).
3.
Your administrative password, which controls your wireless network. Just like any other password, it should not be a word that you can find in the dictionary, and it should be a combination of letters, numbers, and symbols. Be sure you can remember this password, because you'll need it if you ever have to change your router's settings.
The exact steps you follow to configure these settings will vary depending on the type of router you have. After each configuration setting, be sure to click Save Settings, Apply, or OK to save your changes.
Now, you should disconnect the network cable from your computer.
4.
Connect your computers
If your computer does not have wireless network support built in, plug your network adapter into your USB port, and place the antenna on top of your computer (in the case of a desktop computer), or insert the network adapter into an empty PC card slot (in the case of a laptop). Windows XP will automatically detect the new adapter, and may prompt you to insert the CD that came with your adapter. The on-screen instructions will guide you through the configuration process.
Note: The steps below only apply if you're using Windows XP Service Pack 2. If you're running Windows XP and you don't have Service Pack 2 yet, plug your computer into your wireless router and download and install Windows XP Service Pack 2.
Windows XP should show an icon with a notification that says it has found a wireless network.
5118333.gif Follow these steps to connect your computer to your wireless network:
1.
Right-click the wireless network icon in the lower-right corner of your screen, and then click View Available Wireless Networks. If you run into any problems, consult the documentation that came with your network adapter. Don't be afraid to call their tech support.
2.
The Wireless Network Connection window should appear and you should see your wireless network listed with the network name you chose. If you don't see your network, click Refresh network list in the upper-left corner. Click your network, and then click Connect in the lower-right corner.5914228.gif 3.
Windows XP prompts you to enter a key. Type the encryption key that you wrote down earlier in both the Network key and Confirm network key boxes, and then click Connect.
4.
Windows XP will show its progress as it connects to your network. After you're connected, you can now close the Wireless Network Connection window. You're done.
Note: If the Wireless Network Connection window continues to show Acquiring Network Address, you may have mistyped the encryption key.
Posted on Jul 03, 2008
Toshiba Satellite L505D-S5983 black screen
Hold the power button down until the unit shuts off, wait 10 seconds then turn it on again.
Upon restarting, make sure to choose Start Normally if the startup failure menu comes up.
Apr 13, 2014 | Toshiba Satellite Computers & Internet
Acer Aspire 7520 black screen wont boot
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Dec 19, 2009 | Acer Aspire 7520-5185 Laptop
Laptop turns on for a couple seconds but then shuts down, screen doesnt show anything during that ttime
Remove the battery and plug the laptop. If there is no activity when you push on the power button (not even for a second) your motherboard is defective: it could be only the power jack, but it could be a bigger problem also.
There is a very small chance to be a memory problem; check the memory as it follows;
- if you have 2 memory modules use only one at a time, the other one could be defective or
- check your memory with another laptop or
- use some known good memory etc.
If there is no activity or no video signal with good memory that means the motherboard is defective. Could be expensive to be repaired or replaced. Verify if the laptop is in warranty and have it checked by a professional.
Oct 21, 2009 | Dell Computers & Internet
Canon imageRUNNER C2058 color network printer board-B1 only. Upon power up the display screen indicates "Wait...".
The printer Board B1: you must shut it down by hitting the Options button and then selecting Function >Shut down > Shut down sytem>OK. Then power the machine off with the main switch. If the Customer has not been shutting off the machine properly and you get the please wait message you might try reloading system software first before replacing the hard drive.
Or = remove and reseat the printer board, if that doesn't work then you'll have to reformat the HDD unit and reload system software from a laptop. If the problem remains, the printer board may need to be replaced.
The Color Network Printer Board -B1 has a shut down function. It is for preventing corruption of the HDD. Be sure to turn off the main power switch after performing shutdown.
To properly shut down the Color Network Printer Board -B1:
1. Press the Option key on the control panel if the copier is in copier mode.
2. Make sure that the LCD reads Idle.
3. Select Functions on the LCD.
4. Select Shut Down from the Functions screen.
5. Select Shut Down System from the Shut Down screen.
6. The message 'It is now safe to power off the system' appears on the screen.
7. Power off the main power switch located on the lower right side of the copier.
* Note- After powering off the copier, wait at least five seconds before powering the copier back on.
Jan 25, 2009 | Canon imageRUNNER C2058 Led Printer
Blank screen
the power is supposed to stay on when that little plastic button is pressed(screen switch)the screen switch activates hibernate and power saving;if you press the power button a screen will open informing you what programs are currently working.by shutting down you have caused an illegal command.
hopefully if you restart in safemode then shut down correctly and restart every thing should be ok.
Mar 03, 2008 | Dell Inspiron 700M Notebook
Signing out problem
To turn off, hold down power button (may take "long" time--6-8seconds). It WILL shut down.
If recurring problem, check setup settings for Power switch and lid options--turn off, go into standby, etc.
Feb 29, 2008 | Lenovo 3000 C200 Notebook
Screen went black
When you close the lid, there is a small pin that engages the case and flips a switch to tell the laptop the case has been closed. The monitor will ALWAYS turn off then, because otherwise, the heat build up would burn the screen! Do not try to defeat this, replacing an LCD screen is usually more expensive than the value of the laptop!
Now, that all being said (and please remember), the situation you have now is (hopefully) just that the laptop tried/succeeded in going into ACPI "suspend" or "hibernate" mode.
1. Remove all cables and 10/100. Remove all USB devices. Just leave the PSU (AC power supply) connected.
2. Press the power button firmly, JUST once. Wait. And I mean WAIT, because some laptops can take 2 minutes or more to come out of suspend/hibernate, if they were very busy at the time it was shut down.
3. If the LCD screen lights up. you are done. But if it does not light up now, then proceed to step 4.
4. Press and HOLD the power button down for 10 seconds. This forces the laptop to shut down completely, even from suspend/hibernation. Some unsaved files may be lost, but tghe laptop goes cold, so you can start ACPI over again.
5. After a few minutes, press the power button again, firmly, just ONCE and for 1 second max. Laptop should start up OK.
6. Once it starts up, go to START MENU/SETTINGS/CONTROL PANEL/POWER SETTINGS and search for the "hibernation" tab. Turn hibernation OFF. your laptop obviously has some problems or lack of responsiveness with hibernation (most do). Use suspend, instead. It is much safer,. faster, and still does a good job of saving HDD and LCD wear. Please let me know how this goes for you, there are other more detailed problems that may be involved here, but I suspect this is most likely.
Feb 11, 2008 | Dell Inspiron 710m Notebook
Acer Aspire 5100 Notebook Logo
236 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
