I had a cd blow up inside my lightscribe dvd writer. I was eventually able to open it up and clean out all the broken pieces from the cd but when I reinstalled the disk it will not open when I press the eject button; it just makes a noise as if it is trying to open but can't. Do you have any ideas on how to fix the problem.
    Sergeant:
  • 313 Answers
To manually open your disk drive, stick a paper clip or push pin in the small hole in front of the DVD Drive - (see picture below)
Posted on Jul 03, 2008
  • 197 Answers
Will it open if you push the button on the front of dvd writer. you might have to open it up and see if there is nothing wrong. look for broken band or broken gears. if so you may have to buy another one or just open it from the front.
hope this works
I kept a disk in a dvd writer and after sometime it has broken in the writer i have removed the disk tray and removed the broken disk pieces now the tray is not going inside
You need to open the cover of you DVD driver to check if there is some particle left inside the DVD. As there is a possibility that there is something left inside the DVD. If you have idea you can open it and remove everything left inside the DVD.
Apr 26, 2011 | Samsung (SH-S162L/BEBN) DVD RW Burner
I am looking for a hp lightscribe dvd supermulti drive/cd writer that is compatable with a hp pavilion a720n desk top computer and all so a dvd/cd rom combo that is compatable with ...
Any brand-new CD/DVD reader/writer with LightScribe *WILL* be compatible with your HP.
Check whether your "power" and "data" cables are the "old" style (white power connector and a 80-pin ribbon-cable) or the "new" style (thin SATA cables), before you buy a writer with the "wrong" (PATA versus SATA) interface.
Sep 26, 2010 | HP Pavilion A720N PC Desktop
My lightscribe dvd supermulti drive/cd writer wont read this one program installation dvd. All other discs work in that drive, and the installation dvd will boot in an another computer. It just sounds like...
this happens, u dnt need to change nethng if other dvd's are working
take that particular dvd, pour a little bit of water on the side where data is ( I AM SERIOUS) clean it inside out gently with a soft cloth or paper napkin, make sure u clean it inside out, as in dnt go round n round, clean from inner circle to out, gently do it n then try
n make sure its completely dry before u put it in the drive.
Nov 01, 2009 | HP LightScribe dvd640i (DVD640I)...
LightScribe DVD SuperMulti Drive/CD-Writer won't read disks. It has been cleaned and passes all tests. Has read these disks before, but file will not load from disk.
check and see if there are updated drivers and install them. have you changed your Operating System via upgrade or anything.
May 26, 2009 | HP PAVILION A6230N DESKTOP PC
My LG multi dvd writer lightscribe tray wont open. the green light is steady. no matter how many times i try to eject the tray ang it wont open. there is dvd+r inside.
use a unfolded paperclip and insert it into a small hole below the disc tray. This is the manual eject port. Stick it straight in and push, a little bit of pressure will be needed.
Apr 20, 2009 | LG Super-Multi GSA-4163B 16x8x16x DVD+R/RW...
HP DVD 1040 external lightscribe
  1. Clean Drive: commercial cd/dvd cleaner + air compressed can with narrow pipe inserted into device to reach lens.
  2. Update you sw from http://www.lightscribe.com/ (Control panel, diagnostic tool, application)
  3. be sure service is started: as Administrator go to Control panel/Administrative tools/Services
    double-click on Lightscribe Service, and if it says disabled change it to automatic, then "start service" in the left pane if is already started and set to automatic stop and restart it you don't have to reboot to see results.
It worked for me on HP6710b with internal drive and with liteon external burner
Dec 16, 2008 | HP DVD1040e DVD-RAM Burner
Lg dvd writer
First try to clean the drive (dvd drive cleaner cd).
If the problem continues then replace the drive with new one.
May 06, 2008 | LG Electronics GSA-H42LK LightScribe 18X...
Dvd writer for toshiba satellite pro
HP dvd1040i 20x Super Multiformat DVD Writer
Price: $69.99
  Internal drive (double layer)
 Write speed: 8x double layer, 20x DVD±R, 48x CD-R
Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
Read speed: 16x DVD-ROM; 48x CD-ROM
Lightscribe disc-labeling technology
one-year limited warranty....
HP dvd1040e 20x Super Multi DVD Writer
External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    Software problem
    Nero needs to be uninstalled (using Nero Clean Tool) and then reinstalled after you have added a new lightscribe DVD drive. To correctly uninstall Nero go to Nero website to download Clean Tool application specific to your version of Nero. http://www.nero.com/nero7/enu/Clean_Tools.html
    Sep 16, 2007 | Lite On LH-20A1H DVD RW Dual Layer Burner
    Computers & Internet Logo
    77 people viewed this question
    David Payne
    David Payne
