Question about Nikon Coolpix 2200 Digital Camera
Nikon coolpix L11
I dropped my camera last night on quite a solid floor. the zoom lens seems to be slanted slightly to one side now and 'lens error' appears on the screen anytime it's switched on. i'm pretty gutted given i've only had it about 6 months.  you got any solutions on how i can solve the problem without taking it to a repair shop?
Hi..
I have problem with my camera coolpix 2200, if i want to take a picture, it's must be turn off then turn on, and i get one picture, yes just one picture, if i want get more, its must be turn off and turn on again every time want to take a picture, can somebody help me?
thanx a lot before
Posted on Jul 24, 2008
  • 477 Answers
I really wish their was a solution for you that was easy. I am a repair company that fixes these all the time. Here is the sistuation once the case is removed you have to make sure you watch out for a 330 volt compasitor that can shock you. after that it requires you to desolider about 15 soilder joints and wires to take off the back main board after about a hour of doing this you will have to install a new lens and reverse the process. If you feal you want to still do this than I wish you good luck If you want a repair center to do this I charge 60.00 for this service and can have it fixed in a week of getting it. I hope this helps you make a choice on what todo. if I can help any further goto www.digitalcamrepair.com
Posted on Jul 03, 2008
Lens error message - how can it be fixed?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
May 28, 2011 | Nikon Coolpix L11 Digital Camera
Camera dropped on floor lens won't retract and I get a lens error message
Unfortunately optical part of the digital cameras are very sensitive to shock. Some more shock may allow your camera to start working again or make it worse. These devices usually don't worth repairing such major defect. I suggest you look in to obtaining another camera.
Feb 24, 2011 | Nikon Coolpix L11 Digital Camera
I have a nikon coolpix s3000 purple.it is 12 megapixels 4x wide zoom and 2.7 inch lcd-zoom was out-not kept in case-dropped on carpet on cruise ship maybe about 3 feet-get lens error-screen comes on but...
Your photos will not be affected by this fault. Just take the memory card out of the camera and read it with a card reader attached to the computer.
Unfortunately the camera will probably need an expensive repair, or if that isn't economic, replacement.
Nov 18, 2010 | Nikon Coolpix S3000 Digital Camera
Nikon coolpix L11 Lens stuck
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Sep 28, 2009 | Nikon Coolpix L11 Digital Camera
Lens error
It is a pretty major problem for the Coolpix it seems. The internal coupling of the zoom lens is somewhat fragile, and a slight tap at the wrong time can mess up the system. It could have been something as small as a bump while it was being carried in your pocket. The problem is that you'll have to pay for repairs on it since technically it's not a camera error but something that Nikon says happened during usage.
Some owners seem to have been able to solve the problem with a gentle bump to the side of the camera, or some gentle twisting on the lens itself. I don't necessarily recommend that- or, at least I would call Nikon first and see what they have to say about cost of repairs. Other people say that once you do get it fixed, put the camera in Playback mode before you switch it off so that the problem doesn't happen again.
Good luck.
Mar 16, 2009 | Nikon COOLPIX L18 Digital Camera
Zoom lens broken nikon coolpix L1
hi
the lens alignment is messed up you can try to push it while slightly turning it or slap/tap the sides of the lens to fix it...
Aug 11, 2008 | Nikon COOLPIX P4 Digital Camera
Lens Error
Check the contacts in the battery case. You can stretch/bend the contacts further out and the problem seems to go away for a while.
Jul 08, 2008 | Nikon Coolpix L11 Digital Camera
Nikon Coolpix L11 Error....
Assisting the lens gently when it opens and shuts may work.
Dec 28, 2007 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix 2200 Digital Camera Logo
69 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
