Hi Iam on the internet with the main computer and netgeardg834g wireless router iam trying to connect 2 lapptops 1 is vista 1 is xp how do i do this. Mark.
    Sergeant:
  • 313 Answers
Right click on network icon in the systray, click on “connect to a network” – you’ll see it’s listed as a “security enabled network”
"Type the network security key or passphrase for..."
The person who setup the network can give you the key or passphrase"
"Security key or passphrase"
Note: Checking the box next to "Display characters" can make life easier
Click on “Connect”
Leave the defaults of “Save this network” and “Start this connection automatically”
Click on “Close”
This works for both xp and vista
Posted on Jul 03, 2008
How do I connect my Action tec router V1000H to other computers to be able to print to ne printer. Iam running widnows 7
1)make sure that the printer is capable to be a network printer.
2) make sure that your able to print with main computer on the network.
3) make sure that the printer was able to detect the network via wireless connection ( if the printer have wireless capability) ( if not then it should be connected with a ETHERNET cable directly to your router)
4) make sure that the other computer already have the driver of the printer.
try using this first and if this will not work try sending me a message so that i can give you some more steps.
(ramiroreulin@gmail.com)
Apr 10, 2011 | Actiontec (5GE583000-01) Router
Hi, till recently I was conneted to the internet (AOL) via cable connected to a NetgearDG834G v3 Modem router with no problems. Replaced PC with laptop (vista home premium) and connected via cable in the...
do your router modem got a wifi wire? or does it capable on wireless connection. try to use a windows xp not vista. it must be the problem. or configure it manually on your wireless connection in control panel. hope that helps!
CHARCOIS
Aug 09, 2008 | Computers & Internet
Cannot connect my laptop that runs on vista, to the internet through my router. Wrt54g v8 router Info.. I can read the router through my wireless adapter in my laptop and I can connect to the network....
hi there, try this method
SETTING UP WIRELESS SECURITY ON YOUR ROUTER--------
1> connect your laptop with the WRT54G at port no. 1 it is very imp. to hardwire your computer, also check for the light status of the router to ensure that it is connected.
2> access the router setup from a web browser (may be using 192.168.1.1, the default address of your router, and admin as the password.). You can also go to kb.linksys.com if you need more help to access your router setup.
3> at the top click on wireless on the BLACK bar at the top.
4> under wireless click on wireless security on the blue bar.
5> select the security mode as WPA-PERSONAL (best encryption and supported by all devices).
6> select WPA ALGORITHUM as TKIP.
7> in WPA Shared Key type: "superman" or any thing else but it should be at least 8 characters long. and you should remember it as this will be your wireless password.
8> the Group Renewal key should be 3600.
9> Click on save settings at the bottom.
PERSONALIZING YOUR WIRELESS NETWORK NAME--------
1> Under Wireless, click on Basic wireless settings.
2> MODE: mixed
3> NAME: <WHAT EVER U WANT> CHANGE IT eg NINJA, SPIDER etc
4> Channel: 11
5> SSID BROADCAST: ENABLED
NOW YOUR ROUTER IS CONFIGURED.
Now u just need to connect your laptop to this new secured wireless network using the security key and hope it will work for your laptop
http://www.onlinepcrepair.vox.com
http://www.onlinepcrepair.url-go.com
Dec 03, 2009 | Linksys Wireless-G WRT54G Router
Iam not able to get the internet on my laptop. i have a desktop which has internet. i have the belkin wireless g plus.
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Dec 03, 2009 | Belkin (F5D5231-4) Router
Router not seeing internet connection
If you are on cable internet, you need to perform MAC Address Cloning. Access the router's setup page using your main PC, under SETUP tab, there's a sub-tab called MAC Address Clone. Enable that and click on "Clone My PC's MAC" then click on Save Settings. Power cycle the router and the modem. You should be online after that.
Jun 09, 2009 | Linksys Wireless-G WRT54G Router
How to connect ADSL 2 modem to Wireless Router
just change the ip address in the router and give the proper settings in the router
Apr 03, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Iam not able to connect to internet via wireless router
Need more information to help you.
1. If not using the router at all is there connection to the internet??
2. When working woth a utp cable between computer an router is there internet connection??
Don't forgett getting connection with your wireless network is not the same as gettin connected with the internet.
Suggestion: Clone your computer MAC address in the router.
Jan 23, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
David Payne
David Payne
