Question about Neff Microwave Ovens
NEFF microwave inner glass splintered and needs to be repkaced. We have the new glass but are having difficulty in relacing the old. EverythiNg appars sealed.Can you advise please
  • edgethin Jul 04, 2008
    Regretably the door shown has the door with side hinges where as my oven door drops down
  • Neff Master
  • 9,086 Answers
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 04, 2008
  • William Miller
    William Miller Jul 04, 2008
    Ouch!
    If you can't see any screws, then the door will still be held together by hidden locking tabs, just as I state in my solution.
    The principle is the same regardless of the door type.
    They are all held together with either screws or locking tabs.
    I hope you check your door again with this solution in mind.
    Maybe watching the video will help?
Neff b6774N0gb/02. Inner glass shattered. replaced. Internal fuse blown. replaced. Now microwave working (heating water) for approx 5 sec, then switching off, beeping and showing E1 fault. Also display...
Usually if this model stops after approx 3 secs it is an invertor or mag fault. Check that the aerial cover is clean Page 3 of the breakdown part position 315. If this is really grubby it would be the cause of the door shattering. The PTC is not used on the microwave function so may be an additional fault. Check also the alignment of the door switches as this can also cause a similar fault. My best guess is if you remove the mag, you'll probably find scorching on it and it (and the invertor) will need replacing.
Mar 25, 2013 | Neff Microwave Ovens
How easy is it to replace the inner glass on a Bosch HTH B84K microwave
see the video and proceed according with common sense.
God bless you
Jul 31, 2012 | Neff B7740N0GB Microwave Oven
How to replace inner glass panel on Neff H7871 microwave
Hi Bill, I am having a same problem I have managed to order the glass from:-
http://www.4neff.co.uk/cgi-bin/product.pl?PID=876912&query=Neff%20H7871N1GB%2f01&model=H7871N1GB&path=127858
1. Open the door.
2. Take out the 2 screws just behind the handle, on the inside of the door, the door should flop down at the handle end.
3. Hold the door handle and pull the door out. It is only housed in by a slip in hooks at the bottom end.
4. Once you remove the door you will see the inner metal mesh and the inner door behind it.
5. Remove the 16 screws holding the inner glass with a special star type screw driver bit no T30.
6. Once you done that the glass housing holding the inner glass can be carefully prised free and taken off the inner door assembley.
7. Once you done that remove and inner glass, and be carefull to leave the glass glass seal intact, clean around the frame housing and the seal then replace the new inner glass and reverse the process.
PS. Becareful of the inner door once you've removed the outer door, as the hinges holding the inner door tend to shut quickly as there is less weight on the hinges.
It will do the job if you follow these instructions.Good Luck. AL
Oct 10, 2011 | Neff H7871 Convection/Microwave Oven
The inner glass door on my oven exploded over christmas sending glass all over the kitchen no one was in the kitchen at the time or we would have been injured
That can happen with tempered glass. It sometimes happens with car windows too. Tempered glass is treated so that when it breaks, it shatters into little mainly rectangular pieces instead of very sharp shards and splinters. Because of the treatment, it's under stress and can sometimes break if there's a scratch or nick or sudden temperature change. It's possible that over time your oven's inner door had gotten scratched by things in the oven rubbing it, or it had been heated in spots where food spatters absorbed lots of microwave energy. It's a rare thing to happen, not really a result of anything you did, and not likely to happen again.
Jan 11, 2011 | Microwave Ovens
The inner door glass shattered and now no power
There's a safty switch which prevents the unit from operating if the door isn't fully closed. When the glass shattered a small piece may have blocked the switch from operating properly. Check around the door seals for any irregularities.
Mar 22, 2010 | Neff H7871N2GB Convection / Microwave Oven
Glass continually shattering on combination neff oven
That's a huge gap.
You might ask their customer service people to authorize the replacement of the whole door or the glass and the inner door panel where the gap is.
If they won't help you, you could clean it thoroughly, then carefully caulk the gap with high temperature caulk.
Oct 09, 2009 | Bosch Microwave Ovens
Neff H7871 inner glass broken
Hi, I am having a same problem I have managed to order theglass from:-
1. Open the door.
2. Take out the 2 screws just behind the handle, on the inside of the door, thedoor should flop down at the handle end.
3. Hold the door handle and pull the door out. It is only housed in by a slipin hooks at the bottom end.
4. Once you remove the door you will see the inner metal mesh and the inner doorbehind it.
5. Remove the 16 screws holding the inner glass with a special star type screwdriver bit no T30.
6. Once you done that the glass housing holding the inner glass can becarefully prised free and taken off the inner door assembly.
7. Once you done that remove and inner glass, and be careful to leave the glassseal intact, clean around the frame housing and the seal then replace the newinner glass and reverse the process.
PS. Be careful of the inner door once you've removed the outer door, asthe hinges holding the inner door tend to shut quickly as there is less weighton the hinges.
It will do the job if you follow these instructions. AL (srahbah@hotmail.com)
Dec 05, 2008 | Neff H7871 Convection/Microwave Oven
Oven Glass replacement HTHB84K
You can find their support and spares links via their Belgian site or British site.
May 22, 2008 | Neff B7740N0GB Microwave Oven
Microwave Ovens Logo
111 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
