Question about JVC HR-VP673 VHS VCR
Sharp LC-15/20AV6U Is this Enhanced definitionTV set a "digital" TV? Does it need a converter box? Thank you
  • 579 Answers
SOURCE: RCA dvd player, drc200n
DVD optics should be cleaned
Posted on Dec 28, 2007
Benimur
  • 6966 Answers
SOURCE: jvc 32220 and digital converter box
Pls try:
012, 013, 024, 036, 037, 040, 048, 051, 054, 055, 060, 065, 067, 089 or 0053.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 27, 2008
  • 161 Answers
SOURCE: will a universal remote work on a insignia digital converter box?
doublecheck the paperwork for both the converter box and the universal remote. the universal may be too old to be used with your converter. look in the back of the universal's manual to see if your box's corporation has a code you can set.
Posted on Jun 12, 2009
  • 9 Answers
SOURCE: Does the JVC AV27230 require a digital to analog converter?
if you are going to continue using the rooftop antenna, then you will nee to purchase a digital converter box. Those television sets are only analog. You do have an option to get Directv or Dish network and you will not need a converter box at all. Directv and Dish network are 100% Digital and the receivers work as converter boxes for that product only.
Posted on Jun 16, 2009
jcameo7270
  • 675 Answers
SOURCE: Ihave a jvc tv, model
You will need a converter to view hd
Posted on May 09, 2011
I have a sharp LC-37G4U and can not get it to load over air channels. this a digital tv but the only way they would load is with a converter. how can I download over the air channels on the tv
Unfortunately, the Sharp Aquos LC-37G4U TV is an HDTV-ready monitor. It does not have an ATSC (digital OTA) tuner. The A/V Center box (TU-GA1U-S) that came with the TV has two NTSC tuners. You'll need the over-the-air ATSC to NTSC (analog) converter box or a stand-alone ATSC tuner DVR set-top box to get most OTA channels. There are only low power NTSC tuners that continue to broadcast; you will only receive those stations if you are close to their transmitters.
Crutchfield has a nice list of the specifications for the TV here: http://www.crutchfield.com/S-4LS7pNsldXK/p_70037G4U/Sharp-LC-37G4U.html . The manual has the full specifications for the TV on page 100. Crutchfield has the manual here: http://pdf.crutchfieldonline.com/ImageBank/v20040615154800/Manuals/700/70032G4U.PDF .
I wish that I had better news for you.
Oct 21, 2016 | Sharp Televison & Video
I have an older Sharp Aquos TV - model # LC-32G4U. I am trying to connect a digital antenna but it doesn't work. Anyone know if I need a separate digital tuner for this TV? Or what else might be t
There is no difference between a "digital" and analog antenna. Either antenna will capture the signal. What you need is a digital converter box to convert the over air digital signal to the older analog type signal your TV needs. You connect the antenna to the digital converter box, and the digital converter box to the TV.
Several years ago, the US government forced peopel to buy digital converter boxes or newer TVs that could pick up the digital signal. Either get a digital converter box or a new TV.
Oct 29, 2012 | Televison & Video
Do I need a digital converter box to recieve a digital broadcast with a Sharp LC-20SH4U TV?
Yes you need a digital converter box. Your model has an NTSC Analog Tuner. It doesn't have a Digital Tuner. This is why you need the converter box.
For example, many companies like Comcast or Time Warner or TCI etc used to broadcast Analog Signals through their wires. Now they have broadcasted only Digital Signals. This makes either your TV Obsolete as a Tuner or you have to get a digital converter so your Analog TV can receive the signal.
Depending on your service, it may be worth your while to get a TV with a digital Tuner.
Then again, it also depends on if you are connecting a box receiver to your TV. For example, if you have Directv or Dish, you would then use your standard Video/Audio or Composite Cables to transmit your signal OR your Out to TV Coaxial whichever works for your receiver. Some receivers have already built in converters . You should really consider all the factors to decide and determine it based on the type of service you have or want.
Mar 09, 2011 | Sharp LC-20SH4U 20 in. EDTV-Ready LCD...
I purchased in 2000 a Sharp 13" tv model 13N-M150. I used it with rabbit ears. Is this tv cable ready? If not, do I need a converter box? Thank you.
Yes,u need a converter box to get DTV free over the air signal.The converter box is not a cable tv box,it a free DTV free over air signal box,to help the old technolgy CRT tv tube anolg tv to get Digital tv signal.All CRT(Tube Tvs) must have a converter box to get free air Digital tv.Must have pay cable tv to get a signal,if don't have coverter box.If u have a crt tube tv or u get nothing,but statics.
Apr 27, 2010 | Sharp 13N-M150 13" TV
Analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Jan 16, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Just got my 32" and am not clear on whether it can be connected directly to cable wire or if it has to go through the converter box. Thoughts?
Yes it should be fed through the coverter box, otherwise you'll not be able to get any digitally enhanced channels. If it is HD you definately need to use the converter/cable box.
Aug 01, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Dont have cable. i bought the analog converter, but read i don't
Digital Ready is not the same as having a digital tuner built in. Yours is probably the former and you do need a converter box: http://www.ezdigitaltv.com/HDTV_vs_HDTV-Ready.html
May 04, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Does the Sharp Aquous LC-13E1U receive digital or analog broadcas
It looks like your TV is not HDTV capable, so you will need a box when the conversion takes place next year unless you have cable box or satellite TV receiver.
Dec 20, 2008 | Sharp Aquos LC-13E1U 13 in. EDTV LCD...
Analog to digital conversion on Aquos?
First of all, the change is actually goping from analog over-air broadcasting to a digital signal. Second, if you have cable or satelite, you don't need anything. The only time a converter is required is if you use rabbit ears or an external antenna. In your case, the TV DOES have a digital tuner so you DO NOT need a converter in either case.
Dan
Sep 23, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
JVC HR-VP673 VHS VCR Logo
190 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
