It can be a possible hardware issue or a software issue
Try to run the dell diagnostics
http://findtechhelp12.blogspot.com/2010/12/how-to-run-dell-diagnostics.html
If it fails replace the part on which it fails.. If it passes reinstall the OS to fix the issue
http://findtechhelp12.blogspot.com/2010/11/how-to-reinstall-os-in-dell-computer.html
SOURCE: my dell 5125 indicates internal
Try accessing setup utility and verify there if it still recognizes your hard drive, if not then that means your hard drive had crashed. If you have important files on the drive, you can try to recover it by going to a local service provider and have your files recovered, and of course you have to get a new hard drive for your dell.
SOURCE: no bootable device
Error Code 0141 means no drive detected.
If that's your problem then you should take out the harddrive out and try it on another laptop or buy an external enclosure.
You can get them for $10
If it won't run on another computer that means the harddrive is bad but if it does run then it means you have a serious issue within the laptop componants.
SOURCE: no bootable device found.try reseating hard drive,error code 0141
Make sure you fixed the HDD properly..In some cases you need to push a little harder. See if any pins had been bent, if so straighten it, without breaking it.
SOURCE: error 0141 msg:error code 2000-0141
The hard drive has failed. If you're in warranty, contact Dell for a warranty replacement of the drive - it's a customer-replaceable part.
If you're out of warranty, look on ebay for a good deal on a brand new hard drive for your Dell Inspiron 1525
