Few different things are possibilities.
1. Are you connecting the device via USB 3.0 to the USB 3.0 adapter on the computer?
2. Try switching out your USB 3.0 cable for a different one.
3. If you are using the USB 2.0 instead. Make sure you are using the USB Y cable for the device and not just a standard USB 2.0 straight cable.
Using the USB Y cable. Plug the cable into the device first, then make sure to plug both USB's
into the computer starting with the short side USB then the longer side USB second. Also try
using the USB's on the back side of the computer as they will supply more power than the
USB's on the front of the computer.
At first glance a lot of people may not appreciate the usefulness of a hard drive dock, but when you have to access a friend or relatives drive to recover data they are a welcome piece of equipment. Thanks to the latest update to usb 3.0 hdd dockhttp://www.espow.com/wholesale-usb-3-0-d...
I have a iOmega eGo external hard drive, a 1TB one with USB 3.0 port.
The board that makes the connection between the hdd inside the eGo hard case and the usb port where the cable connects is damaged.
I've never used these 2,5" external hdd and last week tryed it on a different case and it worked.
As I have a few more 1TB and 500GB eGo's in use, I'd like to keep the same hard case.
Can you please supply the damaged board for me to replace?
How much would it cost?
Thks in advance.
-Miguel
PS : My e-mail address is [email protected]
