Question about Minolta DiALTA Di183 Copier
Hi i have photo copier minolta dialta di183
After every 2 min it goes locked then i have to again enter the password , how can i remove the password key from it that it should work continouselly.
thanks
    Problem Solver:
  • 17 Answers
Enter the admin mode (U-5) by holding down the Panel Reset key for 3 seconds (until "U- " appears in the display), entering the number 5 from the keypad, and pressing the start key. Enter the 6 digit administrator code and press the start key again. The display should show "Ad-". Enter 1 from the keypad and again press the start key. The display should read "0". Hit the clear key, enter "1" and hit the start key yet again. Hit Panel Reset several times (or turn the machine off and back on) to return to normal operation.
The default administrator code is 000000.
If you do not know the administrator code, it will be necessary to reset it using the tech rep mode. Enter the tech rep mode by pressing the Meter Count key and hitting "Stop - 0 - 0 - Stop - 0 - 1" quickly. Then hit 7 and the start key. The administrator code will flash. You can write it down and use it, or hit the clear key and enter a new code, then the start key. Exit as above.
Posted on Nov 27, 2008
I have a photo copier machine minolta dialta di 470 that show error code c-0400
open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
May 03, 2014 | Konica Minolta Office Equipment & Supplies
Error code c0400 on minolta Dialta Di470
As I said before, Open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
How to clear the user pass word on minolta DI 2610
Utility mode then admin and enter password and then turn off account tracking. no more password to use machine.
Mar 15, 2014 | Minolta DiALTA Di620 All-In-One Laser...
C06 50 error code minolta dialta copier
The scanner which is the bright lite under the big glass has a home sensor to let the copier know that scanner is back home and ready to scan again. will the code is saying the senor is bad, could be dirty get some can air. Remove big glass will be though to get at small and black under the scanner bay side.
Dec 02, 2013 | Minolta DiALTA Di183 Copier
Minolta dialta di183 copier error code c06 50
C 0650 - Faulty scanner home position sensor.
Remove the glass and clean the home sensor.If the scanner moves smoothly remove foreign matter and other obstacles,clean the scanner rails,clean or change the scanner bushing.Place WD 40 oil on scanner bushings.
How i assemble di520 bottom tray lock
Step 1:
Remove the rear cover and in area of wastw tonwr box remove the tray blocking unit.2_3_2013_6_10_50_pm.jpg
Step 2:
Jan 22, 2013 | Konica Minolta Minolta Di520 Dialta Color...
Minolta DiALTA Di183 Grayscale Copier Logo Minolta DiALTA Di183 Grayscale Copier printer driver problems
Contact for Konica minolta, Canon copier for repairing/rental/amc/fsma.
We provide CANON IR SeriesDIGITAL PHOTOCOPIER for rental basis also, our rental prices per month 3500/- with free 10,000 copies pre month.
New Delhi & NCR.
Gaurav Pahuja : 9811139117, 9990258388
Jul 01, 2011 | Minolta DiALTA Di183 Copier
Minolta dialta di181 c1300 error
C1301 errors after setting up the Di181.
Solution:
Replace PWB-A, part number 1177-0106-03 for C1301.
Jul 30, 2008 | Minolta DiALTA Di181 Printer
Minolta keeps jamming
Hi Daryl, what does the paper look like? Is there a "nick" in the leading edge of the paper or any signs of damage to the paper? Remove it carefully an look, but be careful cause the toner isn't fused yet, so it will get on your hands and clothes.
Nov 15, 2007 | Konica Minolta DiALTA Di200 Copier
Minolta DiALTA Di183 Copier Logo
336 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
