Download ip4000 to imac g5 - Office Equipment & Supplies
    Genius:
  • 1,142 Answers
Lines on imac g5 screen
For more help follow the Apple iMac g5 line on screen discussion over here https://discussions.apple.com/thread/4929409
and if isn't helpful then take some guidance over it Mac Tech Support .
Apr 16, 2014 | Apple iMac G5 Desktop
Need update for flashplayer on a imac G5 10.5.8
You can not update flash on 10.5. 10.7 or 10.8 are required. PowerPC and 10.6 And below are no longer supported.
Oct 05, 2013 | Apple iMac G5 Desktop
Android File Transfer
Hi Kim,
Yikes, an Android phone on an iMac G5...
It is probably an upgrade or an update that was not compatible with the G5 Processor... That machine is going on 10 years old now...
Try connecting it to another computer, a friends or at work, to see of it connects properly... if so, it's end of the line for G5's ;-(
May 27, 2013 | Apple iMac G5 Desktop
Imac g5 27" schematic or repair nabual
The imac g5 repair manuals can be found at http://support.apple.com/kb/HT2278 can not find one for the 27 inch version but hope this helps.
Dec 22, 2011 | Computers & Internet
G5 keeps powering up for a few mins then switches off?
Thank you for contacting Fixya Support, I am glad to assist.
There are a few steps you can try to troubleshoot this issue:
Try a PMU Reset:
* Turn of your iMac if it is already turned off
* Disconnect all connections to the iMac except the power cord
* Now disconnect the power cord for approximately 20 seconds
* Reconnect just the power cable the keyboard, mouse and power cord, and then power your iMac G5 up.
* Check to see if the iMac boots up normally without power interruption.
* If the iMac G5 shuts off again, try these steps, another recommendation would be to remove all connections including the power cord, and lay the iMac G5 on soft cloth face down and with a philips screwdriver, remove the plate on the bottom of the iMac G5 where your RAM memory is located.
Before removing the RAM however, touch your hand on the metal boot to discharge any static current you carry for approximately 5 seconds.
Now remove each RAM card and then reseat (re-install) each card.
Restore the RAM card cover with your Philips screwdriver, reconnect your power cable, keyboard an
d mouse and turn on your iMac G5.
See if this second procedure helps if the first procedure does not work.
Let me know if this helps.
Regards
-Mactechtrainer
Sep 11, 2010 | Apple iMac G5 Desktop
Imac g5 speaker has very loud buzz
Check the cable of your speakers or
Download another Music Player
Mar 18, 2009 | Apple iMac G5 Desktop
17" iMac quit working
Your Imac may be one of those affected by Apples purchase of inferior capacitators from Taiwan. If you are less than 3 years from the purchase date, apple will repair the problem for you for free. Just take the unit to your nearest local Apple Genius or tech. If you are outside of the repair extension guidelines, I have provided a link here which can show you or someone more skilled how to repair the problem. Ordering a new motherboard and power supply will set you back a lot of money, however the following guide and pdf give you step by step instructions on how to ressurrect your dead imac without speding more than $100.00. I was able to repair my imac using this guide and it was worth it to save a $2k computer that was only 3 1/2 years old. Check it out:
the following information (in italics and bold)  is taken directly from: http://www.jimwarholic.com/2008/07/how-to-repair-apple-imac-g5.php.  (this site is complete with instructions, manual and the full compliment of materials available at an extremely affordable and fair price. I took a chance and repaired my own, it is not as hard as it sounds1)
The iMac G5 Repair Extension Program for Video and Power Issues applies to first generation iMac G5 computers that have video or power-related issues as a result of a specific component failure. If your iMac G5 is exhibiting any of the symptoms listed below and your computer's serial number is within the noted ranges, your computer may be eligible for repair, free of charge. If Apple or an Apple Authorized Service Provider (AASP) determines that your iMac G5 computer is eligible as part of the program, the repair will be covered by Apple for up to three years from the original date of purchase even if your iMac G5 is out of warranty.
This is a worldwide Apple program.
Affected systems will exhibit one of the following video- or power-related symptoms:
Scrambled or distorted video
No video
No power
Note: If your iMac G5 is not experiencing any of these symptoms, you do not have to contact Apple or any Apple Authorized Service Provider.
Which iMac G5 computers are affected by the iMac G5 Repair Extension Program for Video and Power Issues?
The program is available for certain first generation iMac G5 models that were sold between approximately September 2004 and June 2005 featuring 17- and 20-inch displays with 1.6GHz and 1.8GHz G5 processors.
The affected iMac G5 computers have serial numbers where the first 5 digits fall into the ranges noted below.
Serial Number ranges:
W8435xxxxxx - W8522xxxxxx
QP435xxxxxx - QP522xxxxxx
CK435xxxxxx - CK522xxxxxx
YD435xxxxxx - YD522xxxxxx
Some second generation iMac G5 computers have serial numbers that fall within the upper band of the ranges listed below. Only first generation iMac G5 computers are affected by this program.
Where do I find the serial number of my iMac G5?
The 11-digit serial number is located on a label under the foot of the iMac G5. There is a bar code underneath the serial number.
To view the label, hold the sides of the iMac and gently lay the computer face down on a soft, clean towel or cloth.
Is the iMac G5 Repair Extension program available for other Apple computers?
This program applies only to the systems noted in this FAQ. Other versions of the iMac G5 line are not part of this program. Click here for more information on how to identify iMac G5 models
Free guide for how to repair the motherboard capacitors, rescue the hard drive and more.
http://www.jimwarholic.com/docs/Repairing-Apple-iMac-G5-Motherboard.pdf
Feb 22, 2009 | Apple (661-2795) for iMac Motherboard
Imac g5 model:a1058
iMac G5's cannot run windows alone, but older software can be purchased like Virtual PC to run windows on that unit.
Aug 05, 2008 | Apple iMac G5 Desktop
Download ip4000 driver to imac g5
Greetings,
Here is the link.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 03, 2008 | Office Equipment & Supplies
35 people viewed this question
jasbo
jasbo
