DVD trouble When playing a DVD the picture becomes fixed on the TV screen for a short time then resumes playing and moving. This happens to DVD's we have watched other times without any problem. It is happening on brand new DVD's also. We have cleaned the discs well before inserting them into the player, this does not improve the situation.
    President:
  • 1,314 Answers
You can try and clean the lens with a lens cleaning cd/dvd.
Posted on Jul 04, 2008
I am having issues with my RCA Scenium D52W135D (playstation 3 connection). Recently, I have been having a very specific problem with this combo. I have it connected using HDMI to a Pioneer receiver...
Had the same problem. With mine the other day you probably moved your Playstation 3 too another tv and set your 1080i,720,480 to high deaf on settings in Playstation. You have to change them back to automatic that TV says HDTV but it only plays Playstation 3 on 480 checked in settings of Playstation. Played mine for 4 years on that TV moved and got a 3d wifi then dad got him one And was going to trash that RCA but I told him I would take it for now too keep from buying another TV at this time got it in my new home wouldn't play video but it. would sound tried different cables but still now change. But remembered i changed all of my settings over when I got 3D TV. Playstation 3 hadn't been on know other TV. Since I owned it but that RCA now won't work then came to me last night and playing it on both TVs but you have to change the settings on it before moving it or you cant see the screen to fix it do that guarantee it will fix it. Like you said everything else works PS 1,PS 2,DVD, cable,but PS 3 won't its the settings in theme,and audio.
Nov 10, 2012 | RCA D52W135D 52 in. TV/DVD Combo
Hello. I contacted you earlier, your email went to my spam. I missed it and cancelled . Sorry. The problem. I have is a ghosting picture of a program I watched earlier. The problem comes and gos....
Good day!!!
Sorry but I can't see any previous questions from you to my email but anyways lets proceed to your problem..
If you are watching TV shows and the picture is ghosting kindly try to play a DVD movies or anything that having video on your DVD if the picture is fine when you play a DVD movies your TV is in good condition you don't have to worry about..If the picture is fine when you play a DVD let me know and I will give you next step of troubleshooting..
However if you play a DVD but still picture is ghosting there something wrong with your TV..
If you are using DVR then when you back to TV it become ghosting..It is possible that you hit the wrong button on remote..you can also try to restore factory settings to correct all possible wrong set up and also to to auto scan your TV to get back all channels clearly..
Hope it helps..
regards,
chester
Jan 25, 2012 | LG 50PC1DRA 50 in. Plasma Television
Red glare on screen and seems that paused script is burned into screen.
Hello
This is anormal fault to all flat panel tVs. If a still picture is paused for a long duration of time, itd image will seem to appear on the secreen even after that picture has been moved away from it. In some cases, this fault will be retified with time. There is no repair for this fault. Just input any plain white screen signal input to it, and let it be there for at least 15 minutes or so. If the fault has not been rectified by this, the screen may need repalcement.
As your set is almost new one, and will be within warranty period, just cusult to the service center for any remedy. Never tell them the cuse for this fault, as you have made it by yoursef (eventhough they knows the cuse). OK.
Nov 14, 2011 | Televison & Video
TV picture upside down.
go to " SETTINGS " and rotate picture in there , hope it helps , AJ
Nov 03, 2009 | Audiovox VE1020 10.2 in. TV/DVD Combo
Picture distortion
check the settings on the dvd as if you set the dvd to 4:3 format for instance, the picture will be "squashed" to a letter box format and when you play on wide screen it will become "morphed" and mishaped. also if the tv is set to wide all the time, then this will cause a stretching effect. set the tv to auto picture size or "smart" as it is on sony's, with auto 16:9 on.
Oct 07, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No video from dvd
You could possibly have a faulty set of RCA cables. Happens all to often. Change your RCA cables (Red,White,Yellow). And make sure they are inserted good. If problem still presists. you could have a short in your inputs on either you dvd player or your t.v.
Aug 31, 2009 | Marantz SR-5200 Receiver
Unable to retrieve picture on TV
when the screen becomes snowy, it means that something in the cable box is being overheated. what you should do is take a small desk fan and hold it beside the cable box. this has happened many times when my family has played on their xbox 360, and the desk fan solved this problem. i hope that this helps!
Jun 12, 2009 | Televison & Video
We keep losing sound and picture on our TV
If you haven't replaced the lamp, it is almost certainly time to change it. A weak lamp will cause the TV to play for a short time. As the old weak lamp heats up, it draws more current, and the reflector in the lamp, having become cloudy over time, converts the light into more heat rather than reflected it out into the set. Eventually the lamp draws too much current and the set turns it off, going into a restart cycle. Buy an original Sony lamp, as the aftermarket replacement lamps are known trouble makers. Be sure to rate this solution. Thanks!
Nov 13, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Dvd -no picture
Sometimes the displays can't be sent to another tv or monitor. Make sure that isn't turned on. Sometimes there can be a short in the wiring if your unit folds up to play like a notebook computer. You can try moving the screen back and forth and see if the picture changes. If neither of these solutions work, contact audiovox and see if it is cover under warranty.
Here is the website:
http://www.audiovox.com/webapp/wcs/stores/servlet/contact_us.jsp?type=nprev&catalogId=10001&storeId=10001&categoryId=874323&langId=-1&page=&urlString=&productId=&brand=
Jun 30, 2008 | Initial IDM-1731 Portable DVD Player with...
Green line on TV with DVD playing
The aspect ratio is fine, I just fixed mine you have to use the TV remote, and press the left or right directional button depending on where the green line. Philips TV offsets the picture when using HDMI, but its easily fixable using this remedy. Time to take the tape off haha!
Mar 07, 2008 | Philips HTS-6500/37 System
Televison & Video Logo
Top Televison & Video Experts
