Question about Apple iPhone 3G
I have a shaver type 5735 about 4 months and i leave it in the charger after every shave but after about 4 shaves it is not charged why not.
The shaver is only 3 months old still under guarantee ,when I emailed you it was braun I needed.thank you.P Hally
Posted on Jul 04, 2008
When the "Philips Senso Touch 2D" electric shaver is fully charged should the charger be turned off
It is not advised that you leave the shaver charging after it has fully charged.
Apr 17, 2013 | Health & Beauty
I was given a norelco 3605 shaver in excellent condition (used) without instructions and would like to know the charging procedure and duration (the amount of time it takes to fully charge the razor). Is...
The manual says to charge for 16 hours if it has not been used in awhile. They say nothing about it over charging, but the batteries need to be used and let discharge through shaving. A fresh/new battery is supposed to last about 2 weeks before needing a recharge. I think keeping them charged all the time cuts down on battery life.
Jun 07, 2011 | Norelco 3605 X Electric Shaver
I just purchased a Panasonic Arc IV nanotech wet/dry shaver. I've been using it in the shower, and it's very effective. However, I'm wondering if I'm using it correctly. The shaver's manual says it should...
You did not include the specific model number written on your shaver but I will try to address your questions the best I can without it.
Most likely, your shaver came with a cleaning station and charging station. The cleaning light would tell you it is time to use the cleaning station. After each shave, you should dump out the shavings and rinse under the tap. You should let the shaver dry without the cap on.
ShaverOutlet com ShaverOutlet com Shaver Replacement Parts Manufacturer...
Mar 27, 2017 | Panasonic Es8243a Arc Iv Nano Electric...
My 7540 shaver will only start when it is fully charged. After the first shave it will start only start if I lossen the foil. Do I need a new battery?
Hi, yes these batteries only have a limited life unfortunately. To prolong the life of your battery, always ensure the batery is completely flat before charging and always charge fully but do not leave charger on after charge has completed.
Hope this helps
Aug 01, 2010 | Braun 7000 Series Foil and Cutterblock
Red light at bottom flashes even when razor ids fully charged. What can causrethis?
When the battery is almost empty (when there are only 5 or fewer shaving minutes left), the battery symbol lights up red.
Make sure that the battery does not have a memory effect. What I suggest is taking the shaving head unit off and running the shaver till empty, then recharging. Check if the red light is still flashing.
There's also a head indicator at the bottom of some shavers.
To remind you to replace the shaving unit, the shaving unit symbol flashes (all types) and you hear a beep when you switch off the shaver (RQ1090 only). This happens at the end of 7 successive shaves to remind you to replace the shaving unit.
Without knowing what model you have it's difficult to diagnose further.
May 23, 2010 | Norelco Arcitec Electric Shaver -...
Not shaving close enough.
This problem is usually cause by a worn out shaving head (foil and cutters). Braun suggests that you change these every 12-18 months for best performance. You will find replacements at shaveroutlet.com for your model 4501 Braun shaver. See link below.
http://shaveroutlet.com/foil-cutter-fit-braun-4000-series-flex-control-twin-control-p-146.html
It is also possible that your shaver is running too slowly due to an old battery if you've never replaced it. If you require a new battery, it can also be ordered from shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
To change the battery you will need to be able to do a little soldering. Open the shaver by removing the two round screw covers on the bottom of the shaver and then the screws underneath. You will also need to remove the foil and cutters and then the swivel frame which is attached by two tiny screws. Once removed, you will be able to open the shaver from the bottom and seperate the front and back. Remove the circuit board to easily get to the battery.
Note: The tabs on this type battery will work for most applications however they may be slightly different than some original equipment. For these instances, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather that removing them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can them solder the tabs from the new batteries to the old existing tabs
Feb 19, 2010 | Braun 4501 Electric Shaver
I get three shaves per charge
I have a couple of thoughts...
First, the amount of shaves you get is directly relevamt to the amount of time it takes you to shave. Most shavers today have a run time of about 30 minutes while there are some that are longer. If your shaver has a 30 minute run time and it takes you 5 minutes to shave, you should get about 6 shaves on a charge. If it takes you about 10 minutes to shaver, 3 shaves is all you can expect on a charge. You get the idea.
If your shaver does not hold a charge for at least 30 minutes, the batteries may be going bad. Although you mention that you just got this shaver, it was manufactured some time ago. Model R-450s has been discontinued for about two years. The batteries on lower end models like this one often dont last as many years are the older models did.
Jan 26, 2010 | Remington Health & Beauty
Red L.E.D light won't stop flashing
Shaving head check indication After two years of use the red shaving unit symbol î will flash for 30 seconds during 7 shaves to indicate that you should check the condition of the shaving heads. This indication is based on an average shaving time of 3 minutes per shave. When the shaving head symbol flashes, all other symbols and lights are out. When the shaver is switched off, the shaving unit symbol disappears. When the red shaving unit symbol starts flashing, you should check the shaving heads for possible damage. If the shaving heads are damaged in any way, they must be replaced in order to obtain optimal shaving results
Nov 20, 2007 | Health & Beauty
Apple iPhone 3G Logo
106 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
