Question about Hunter Heating & Cooling
I have a hunter programable thermostat model number 44422 and the condenser outside will not kick on The fan is working inside but I have no cool air(air conditioning) I do not understand why the outside condensor will not start to cool It is so hot in the house Could the thermostat be programmed is so how do i deactivate it to so the condensor will work Thank you
    Novelist:
    Champion:
  • 230 Answers
The outdoor unit has failed in some way. This is probably not the thermostats fault. You can check the breaker for the outdoor unit by turning it off and then back on. If this does not work, the problem is most commonly one of the following issues. All of which should be done by a professional because the danger of electrocution.
1) Bad Start/Run capacitor
2) Bad Compressor
3) Bad Exhaust fan motor
4) Combination of some or all of the above.
Posted on Jul 03, 2008
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
Hunter thermostat 44110
This sounds like a split system, the condensing unit outside and the evaporator coil and fan inside. You must be referring to the indoor fan, since the compressor and outdoor fan are controlled by the same contacter. The indoor fan relay contacts sounds to be welded shut, and needs to be replaced.
Aug 24, 2013 | Heating & Cooling
Flashing time on a Hunter Programmable Thermostate #44665
Teresa
have a cental air guy in for a check up on your units. they may need servicing
Jul 22, 2010 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44260 Thermostat Problem
make sure you have the jumper in place
if you dont have a secondary heat source red should be on r with a jumper to rh
Oct 17, 2009 | Hunter Fan Company 5/1/1 Programmable...
Oustide unit fan won't work
It sure sounds like the out side condenser fan has gone out.If you need to Fix a water hose to run on it like a spray fanning out over the out side coils(condenser)and try and see if it will cool.It will do the trick,until you get it fixed on week days.If I can help,let me know.>>>roniecon@gmail.com
Aug 16, 2009 | Goodman CLQ36AR49 Air Conditioner
Bryant central air unit fan doesn't stop.
This is a condenser fan and as long as the A/c unit is in cool mode, this fan will run. The only time it should shut off is when temperature setting is satified and the unit shuts off.
Jun 03, 2009 | Heating & Cooling
Low battery on hunter 44422
I have the same unit, 44422. The base has four clips, two on the top and two on the bottom. The front portion is clip-on. Try to push on the base's bottom and pull off the front portion, like opening a book. After the battery replacement you will have to reset the unit trough the little reset hole. Otherwise, the ''LOW BATTERY" will not go away. Yes, you will have to reprogram the unit.
Jan 01, 2009 | Hunter Fan Company 5/1/1 Programmable...
Hunter programable thermostat
google search hunter thermostat and the model number and manual and it should come up, I found mine with "hunter thermostat 44200 manual"
Nov 25, 2007 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
167 people viewed this question
Top Hunter Heating & Cooling Experts
1STHVACMAN
Jay Finke
Jay Finke
Are you a Hunter Heating and Cooling Expert? Answer questions, earn points and help others
