Question about Compaq 233Mhz AMD-K6 CPU Processor Presario 2200 (319281001)
Presario 2218rs power wont boot comp
I dissassembled laptop how do i check power module that goes into board
  • Compaq Master
  • 13,433 Answers
Basicly the laptop uses a external power adapter.. .. the black box between the wall socket and the laptop power socket.
Posted on Jul 22, 2008
Compaq Presario g62-225nr wont boot
check the ram card. also the battery on the mother board if the are fine then the mother board may have gone.
Sep 21, 2013 | Compaq Computers & Internet
Presario 2500 screen wont come on but computer and lites are working
If you can't see any obvious damage, like a cracked screen, sometimes the module that illuminates the LCD screen just goes out. If it has a VGA port and you can get a computer monitor, plug the monitor in and see if it will boot up and run. It is possible that you might have the computer set up to boot to an external screen, but you would still see the Windows and HP logos at the boot up. If you see NOTHING at all, then try an external monitor. If that works, you may replace your screen...or not.
Aug 12, 2013 | Compaq Presario CQ62238DX Laptop
I have a compaq nc6000 which wont boot up it trys to fire up then it goes off i have got to run but then it went back to this not booting up
Check and see if your DC connector is loose:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Jan 02, 2011 | Compaq Presario Notebook
I am tryng to start my computer and it comes on for only 2 seconds and it shut off
Any beeps as it boots up?
Check the power button is not sticking first. It needs to release after powering up the board, otherwise it will cause the comp to shut down.
Feb 09, 2010 | HP Compaq Presario F750US
Tower powers up great,but monitor has no signal
1st if the monitor light is yello and as soon as u switch on the comp,or if the monitor goes to sleep even though u ave checked the connection wht u need to do is u need to reset the graphic card if u ave a add on card and then clean the slot check for any damage or moisture and then put it back and reboot.i m working for hp ave got lots of those cases
'2nd wht u can do is press space bar and slightly tap the power button of comp seeif tht helps.let me know wht happened and in detail
Aug 25, 2009 | Compaq Presario 5000 PC Desktop
T41 appears to be dead. I see the power light but
Good day sir, there are several resons why a laptop wont power up, or wont display a thing.
  1. Memory is bad so make sure to check for memory module.
  2. The battery is bad, check you battery with other similar laptop.
  3. The power supply/charger is bad.
  4. There seem to be a shorted circuit board on your laptop ground chassis. For you to test it, you should dissassemble the laptop and one by one reassemble it again.
  5. Mainboard, sad to say if everything else fails, the mainboard is the last culprit. better visit your local service center.
hope this helps, please update me if you may have any progress report on your laptop, thanks
Jul 24, 2009 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
Problem with compaq presario 2500
hi
go to the Bios setup and set the first booting device as CD drive and it will check the CD first
cheers
pls rate if it was any help
Jul 05, 2009 | HP Compaq Presario 2500 HP Pavilion ZE...
Compaq presario C501nr wont charge battery
its in your power jack its a common problem try to check and change.
May 06, 2009 | Microsoft Compaq Presario C501nr Notebook
Compaq Presario V2000 laptop wont boot
hi it seems that ur mother board has been damaged.. and immediately u should go for replacement....
thank u!!!
Apr 09, 2009 | HP Compaq Presario V2000 Notebook
Computer wont boot
yep you said it loose connection, wiggle the power cord and and thing attached.
Jan 08, 2008 | Computers & Internet
Computers & Internet Logo
59 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
