Question about HP LaserJet 3050 All-In-One Printer
Do I need to dial 9 before dialing out?
This is pretty simple, but I can't find the answer anywhere online. When dialing out do I need to dial 9 first? I have tried it both ways and am getting a "no answer" message. The numbers I am trying to send to are working numbers. Thanks
    Sergeant:
  • 287 Answers
If you plug a standard phone into the line can you dial the number you want?
Do you have the line plugged into the socket marked "L" or the one with a "phone" symbol?
The "L" is line in and should go to the wall socket, the "phone" is so you can plug a phone into the fax and share the line.
Also this note is in the user guide, it may be important
NOTE Use only the fax cord that came with the all-in-one.
For more information about faxing, see the online User Guide.
Posted on Jul 03, 2008
How do you set up voicemail on the Panasonic KX-T7636 system?
1. Raise the handset on any telephone in the Panasonic Telephone system.
2. Press the "INTERCOM" button and dial 165.
3. When answered by the Auto Attendant, dial # XXXXX * 9 9 8.
(Pound Six Star Nine Nine Eight)
4. Enter the Administrator Password. Followed by a #. (Pound) If required.
5. Dial 5 to "Modify Message"
6. Dial 1 to "To Change The Company Greeting"
7. Enter the Company Greeting Number from 1 to 32.
If you are not sure of which Company Greeting Number to change, then start with 1.
The Panasonic Voice Mail system will actually play the greeting to you.
Then you can determine if it is the correct one you want to change.
If it isn't, you can dial 2 and move on to next greeting and so on.
If you select a greeting number where there is no greeting recorded,
the Panasonic Voice Mail system will prompt you to record one at that time.
You may dial *1 (STAR ONE) to skip recording and return to Step 7.
8. When you have found the Company Greeting you want to re-record
follow the system prompts to record and save your new greeting.
Note:
You can change the Company Greetings remotely from anywhere.
1. Call the main number of your business.
2. When answered go to Step 3 and follow the same procedures.
3. When completed....Hang up....
Aug 09, 2011 | Panasonic KX-T7636-B Corded Phone
I NEED TO STORE NUMBER ON MY PANASONIC KX T7730
The mechanics of storing a speed dial number on Panasonic phones is the same, even if the phone can be connected to one of 18 different model Key Service Units. It involves pressing PROGRAM a button, an access code, the number, and STORE. In the U.S. our access code to get an outside line is "9". You may be using something different, like '0'.
The differences are if you can dial "9" on the intercom and get a dial tone, which collumn of buttons you press, and/or whether you want this to be PERSONAL numbers or SYSTEM numbers.
In a TA-824, lines are accessed high to low. If you have 2 lines on a basic system and dial "9" to get an outside line, you will land on line 3 if you have not told the system that line 3 is disabled (system program 400). So, the fast answer is press PROGRAM, a button on the right side, dial 9+your desired number and STORE. If it's a left side button, dial 29 instead of 9.
System speed dials requrie access to system program 001.
If this does not work on your system, please comment back with your actual system model number.
Carl
Nov 09, 2009 | Panasonic KX-T7730 Corded Phone
I need help setting speed dials on a Panasonic KX-T7730!!
Hello, from the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
PLEASE rate this answer if it was helpful.
Thank you.
Sep 14, 2009 | Panasonic KX-T7730 Corded Phone
How to enter phone numbers into the memory/speed dial?
The manual from the GE web site is here:
http://www.home-electronics.net/ge/pc/IB/29267GE3_IB.pdf
It's a pretty straightforward process, Pick up the handset press STORE a location (0-9) STORE dial the number STORE
With only 10 storable numbers it's pretty thin, but you also have the last 50 CID numbers to dial. If you live in an area with more than one local area code (overlays) and mixed 10 digit dialing, it looks like you may have some programming to do to make it dial CID numbers properly.
Carl
Apr 21, 2009 | GE 29267 Corded Phone
Programming Auto Dial Number
Yep. Those are speed dial numbers. They are programmed from ext 101 or the main phone. Without picking up the handset, press PROG **1234 and dial 001 and ENTER. Dial your 3 digit speed dial number If there is something there, it will be displayed. A speed dial number is stored with the trunk access code in it (usually 9) so if you're putting in a new number, include the "9" plus the number exactly the way you dial it. Dial your new number with the access code and press ENTER.
Number changed :-)
You can keep putting in a whole boatload of new numbers with this procedure.
Carl
Mar 16, 2009 | Panasonic KX-T7633 Corded Phone
5610 issue
dial 9 then pu in 4 to 6 ",,,,,," then the number.
old fashion fax method, don't knock it, it works
Dec 05, 2008 | HP Officejet 5610 All-In-One InkJet...
How to tune AWA-Thorn C6337 television
There should be two dials, one is UHF, you need the main dial on U for the UHF channel tuner to work, turn the UHF dial with the main dial on U and if you have a UHF antenna, you should see something if you get a UHF broadcast where you are, the main dial will probably be numbered 0 1 2 3 4 5 6 6a 7 8 9 or something like that, they are VHF channels, should be preset at the factory, but if not, turn the centre of the main dial, you may have to push it in and turn.
In saying all that, i dont know the model, but im pretty damn sure it was the same or simular 63cm AWA Deep Image Colour set that i had from way back in the VERY early 80s. I cant remember that model number though.
Apr 20, 2008 | Televison & Video
NO Dial Tone on Verifone tranz 380
It could be the number programmed to dial is invalid, or it needs a PABX (8 or 9, etc)
If you have digital lines, these terminals will function in an inconsistant way. Make sure you are using a dedicated analog line. If you have a fax machine, try that line.
You can try slowing down the speed by checking fields 542 and 543 and changing them from 2 to 1.
You're best bet is to call you terminal software provider.
Feb 07, 2008 | VeriFone TRANZ 380 Transaction System (X2,...
Programming instructions for used phone
Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works)
To program:
1. press speaker or lift handset.
2. press STORE
3. dial the number to be stored
4. press MEMORY DIAL
5. press location (0-9 on keypad or 1 of the 3 emergency quick dial)
6. press speaker or hangup.
To dial emergency numbers:
2. press any of 3 emergency quick dial
To dial stored numbers:
2. press MEMORY DIAL
3. press location (0-9 on keypad)
Does anyone know how to add PAUSE in a stored dial string?
Aug 27, 2007 | GE Corded Speakerphone with 2 Cordless...
Can only dial 9 or 1, 2-8 keys not working
it sound to be block but thats my personal opinion due that I dont work with that brand, there are few other brand model that have that feuture just to have controls of the use of the phone, they use to recive only but allowe to call 9-1-1..unles no other tech tell you something else try to get the manual of that unit..good luck
Jul 27, 2006 | Vtech VT-2431 Cordless Phone
HP LaserJet 3050 All-In-One Printer Logo
62 people viewed this question
Seeker5211
Seeker5211
