Question about Kenmore 774 sq. in. Cooking Area Gas Grill 15337
Low output My grill six burner Kenmore elite grill (three years old) lights but the heat output is VERY low; after time maybe up to 150 degrees. I shut down, disconnect the tank, wait 5-10 minutes, hook up the tank and restart. Somettimes it works, other times it does not.
  • Anonymous Sep 05, 2008
    I have somewhat the same problem.  My grill's ignition wires melted and when i replaced them and put the grill back together it does not light correctly.
  • Anonymous Mar 21, 2009
    Iam having problems with ny kenmore grill low out put after having it on fro a long time?
The grill is not staying lite and not heating up like it should.
Posted on Mar 21, 2009
Flame height is very low when burners are on high and grill temperatuture does not excede 400 degrees
It is most likely the regulator especially if all the burners are at the same height. This is a common problem. If you grill is under a year old go into sears and they should be able to replace it for free. (the regulator is the round metal piece that conects to your propane tank.
Jul 02, 2010 | Kenmore 16225 Grill
Silver C 2000 Model heats to 420 degrees with all 3 burners on Low. Normal? Weber support service has given me conflicting information. With 2 burners on Low it heats to 310-320 degrees.
That's fairly common with the lid closed and a day that is not too cool. Keep in mind that a gas flame is about 800F. Try using only one burner on low or between on and high to get a lower temperature. This is a grill, not a smoker or slow cooker.
It will run cooler with a large amount of food.
Feb 08, 2010 | Weber Genesis Silver C Grill
Rear Burner is hotter than the front burner on my Weber Grill
Since the grill is 15 years old, it is probably time to rebuild it. Replace both burners and anything else that is not working properly
Dec 20, 2009 | Weber Genesis Silver B Grill
Char Broil grill w/full tank and cleaned air jets, no heat
try opening the tank really slowly. if you open it too quickly the overfill protection devise in the tank will restrict the gas flow to the burners. hope this helps.
Sep 17, 2009 | Uniflame FG2204C Grill
My kenmore elite gas grill will light, then quickly go out.
check for leak if it is propane if no leak most likely regulator and hose
Aug 10, 2009 | Grilling
Low pressur on gas grill
orfices are possibly clogged with spider web
and the check to see if your dial on tank is fully open and check to see if your tank is almost empty...
Jun 01, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
My weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Sloution;
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Mar 21, 2009 | Thermos Stainless Steel Gas Grill
Weber Silver B - 3 burner BBQ
Check your instruction manual, you have probably set off the safety valve in your propane tank. It is set to trigger if there is an open connection, such as turning on the jets when the tank is turned off. You may have to re-connect the tank...careful of course, make sure it's valve is off.
Aug 21, 2008 | Weber Q Grill
Gas grill lights but doesn't get very hot
I had this same problem especially when the tank on my 5 burner 2 year-old Kenmore was about half full. The solution above fixed it. I was used to opening the gas fully, turning one burner to high and clicking the button. If I would have read the front of the grill I would have seen that this was incorrect. I turned off the grill completely, unhooked the regulator and reconnected it. With one burner on high I began clicking the button BEFORE I turned on the gas. I slowly turned the gas on one quarter turn and it lit up full flame. I slowly turned the gas another quarter turn and lit the second burner. I slowly opened the gas all the way and lit the third and so on. That did the trick!
Mar 10, 2008 | Kenmore 700 sq. in. Cooking Area Gas Grill...
KENMORE Gas Grill 141-152210 Kenmore 437 sq. in cooking will only heat to 250 degrees
sudsy, this exact same thing would happen to me every time I changed a tank. I know it's nothing to do with the grill itself. I would have to seat and reseat the regulator hose to the tank a couple of times before it would start heating normally. Your model has 3 burners and I suspect that the flame is real low on each one even on the high setting. Try connecting and disconnecting the tank a couple of times and see if it comes to life. If worse comes to worse you can order a new regulator hose. Part number P3632L. Catriver..post back.
Apr 03, 2007 | Kenmore 437 sq. in. Cooking Area Gas Grill...
Kenmore 774 sq. in. Cooking Area Gas Grill 15337 Logo
430 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
