Hello garyfoy, This is Intova. Please try to use fresh batteries if the ones you are using are used. If that doesn't address the issue, then the camera is probably broken. Unfortunately your IC800 is a discontinued model for which we do not have any replacement cameras or parts. We do however have other cameras available with similar waterproof capabilities. If you are interested, please call us directly at 877-837-0074 or 808-837-0074 or email [email protected] . Best Regards, Intova
when I bought mine. The weed eater didn't start right away so I took it back where I bought it and I had them look over it. when reading the manuel It said that it might not start right away becuse the fuel mixture needs to be adjusted on the pro prolan pp125 weed eated. so we utilized what we had around us and found a tube. adjusted it and it started right up.
You need to locate a piece of software called Patchburn - but I think that might be difficult now.
This particular vintage mac only worked with the drive that was in it. in order to use a different drive you had to patch the system so that the new drive would be recognised as a burner - that said, it should just work as a player/CD-ROM.
The later Macs didn't have this problem and you could stick a drive in and it would be recognised straight away as a burner. I recently put a LG drive (with lightscribe) into a G5 mac and it worked straight away as a burner/player but I did have to install the lightscribe software.
Normal
0
Disconnect
the printer or at least be sure it is turned off. I'd do
both and when the CD software program asks you to connect the printer
to the USB port, do so and it should again work properly.
Hope this helps. Bud
have the printer preferences been changed accidentally to print in greyscale? Is the cartridge installed correctly? Now and again if the cartridges are opened and not installed straight away the ink dries up in the nossel and clogs the printer head, easily rectified with some cleaning solution. Cartridges also go out of date. hope this helped
No, Canon only sell through supported dealers. If it does work and
sometimes stops working, it could be cd tray is dirty or the disc are
too shinny calls the sensor to reflect back to the tray. some cheaper
disc do not work as they are not matte white.
Don't run the setup program. Instead reboot your computer and use the windows add hardware wizard to install the drivers from the CD. The windows hardware wizard will detect several different devices, allow it to install them all from the CD.
