Question about Haier hwr10xc6 Air Conditioner
Gurrgeling noise after compressor kicks in
In 2001 I purchased 2 Model HWF07XCA Window AC.I installed one and put the other upstairs in the box it came in unopened until last month. The ac in my room gave out so I took the AC out of the box after it sat since2001. It work Ok For a month but now makes a noise like gurgling or like a wheel fan running through water.THIS HAPPENS WHEN THE COMPRESOR kicks in, It slowly decreases and goes away.The unit seems to cycle ,that is the compresor,on and off too much,Has the fact that the AC sat in its carton and was not removed for seven years caused this problem ?
    Novelist:
    Champion:
  • 230 Answers
The sound that you are hearing is the refrigerant moving through the system. That can be a very normal sound. If you are not experiencing any other issues I think it is ok.
I can't believe that just sitting in a box can harm it. If it was stored in an upright condition, you should be fine. The system has oils in the compressor. So if it was stored upside down or something then the compressor could have run dry. This is usually ok if the unit returns to an upright position for a day or so before it is run.
Posted on Jul 03, 2008
Jeep cherokee when in drive, front right under the hood clicks and the RPM's kick for about 2 seconds this cycles about every ten seconds.
its hard to say is your ac compressor kicking on i need more details on where the clicking is coming from ac compressor is a guess due to it raising rpms when turned on and makes clicking noise turning on and off
Dec 05, 2012 | Cars & Trucks
Compressor won't kick on 12,000BTU Frigidaire window A/C After cleaning
Is everything dry? Do you hear any noises like the compressor running it is just not cooling?
Aug 04, 2012 | Frigidaire FAH106N1 Wall/Window Air...
Compressor clicks 2000 chevy silverado 1500 5.3L
First thing is have the AC charge checked by a shop, if that is OK then the AC compressor low side pressure switch may be defective or the compressor relay is defective.
Jul 26, 2017 | Chevrolet Silverado 1500 Cars & Trucks
I need a fuse panel layout diagram for my 2001 mazda b3000 pickup
I purchase atruck and they put a wire from the compressor ac to fuse box. I want to eliminate that because ac compressor is always on. I check the ac heater selector switch and is ok. What if they take the fuse of ac out and bypass with a wire. Wich number in the chart fuse box is the compressor switch
Mar 13, 2012 | Cars & Trucks
Air conditioner suddenly not working.. No funny noise, just acts like it is not getting power. compressor kicks on and off checked relays behind glove compartment. Was told ac relay may not located with...
AC COMPRESSOR KICKING OFF AND ON.SOUND LIKE REFRIGERANT LOW.LOW SIDE SHOULD BE 20 - 36 PSI AND HIGH SIDE SHOULD BE 215 - 310 PSI. AC SYSTEM COULD HAVE A LEAK WHILE YOUR COOLING STOPPED. DRIVER SIDE WINDOW MOST TIME SWITCH WILL BE THE PROBLEM.REMOVE SWITCH SEE IF POWER GOING TO POWER WINDOW MOTOR.YOU HEAR WINDOW MOTOR TRYING TO WORK WHILE USING SWITCH.WINDOW REGULATOR COULD BE BINDING DAMAGED OR NEED LUBRICATING.OR MOTOR NEED REPLACED.IF POWER NOT GOING TO POWER WINDOW MOTOR THE CONTROL SWITCH IS BAD IF ITS THE ONLY SWITCH.TO TELL IF WINDOW SWITCH IS BAD SHAKE POWER WINDOW SWITCH WIRES WHILE OPERATING CONTROL SWITCH.IF POWER WINDOW WORKS YOU KNOW SWITCH IS BAD.TAKE CAR TO AC SHOP BECAUSE LET THEM CHECK AC SYSTEM BECAUSE IF YOU BUY 2 CANS OF R134 REFRIGERANT. AND YOU TRY CHARGING AC SYSTEM YOUR SELF AND ALL REFRIGERANT LEAKS OUT. YOU GOING TO BE OUT OF $30.00 STILL NO AC.THAT WHY ITS BEST TO LET SHOP PUMP DOWN AC SYSTEM CHECK FOR LEAKS BEFORE RECHARGING AC SYSTEM.
Jun 26, 2011 | 2000 Acura TL
LG 24000btu not blowing cold air. Fan runs but i do not hear the compressor kick on. temps upstairs hit 104 and temp is set at 80. unit is only in use for 2 months. none stop though on cool.
please check the temperature sensor this will make the compressor for running and stopping and also check the compressor if its in warranty period please call the service technician to check these and replace if necessary.
Sep 04, 2009 | LG Electronic Window Air Conditioner
Goodman Model # GPG15709041AA Gas pack just
depending on the brand and if he had to recharge and pulled oil oiut of compressor it can cause comp to be load. goodman is also a lower end unit and you pay for what you get. it is a very reliable unit howvere
Aug 17, 2009 | Goodman CKL60AR60 Air Conditioner
Ac compressor not working
This unit is a 220 volt ac unit. 12-2 wiring is usually for 120 violt circuits?
  • Amps: 22.2 / 20.0
  • Watts (Heat): 4900 / 4000
  • Watts (Cool): 1650 / 1625
  • Amps (Cool): 7.7 / 8.3
  • Voltage Rating: 230V / 208V 60Hz
  • Power Cord Length: 5' (6')
  • Horsepower (Cool): 2.49
  • Plug Type: LCDI 6-30P
  • http://www.frigidaire.com/Home-Comfort/Air-Conditioning/Window-Mounted-AC/FFRH1822R2
    hope this helps?
    Jun 05, 2017 | Frigidaire Heating & Cooling
    Oldsmobile AC resistor location
    The blower motor resister is located next to the fan under the passenger side dash. You will have to remove the glove box and plastic cover under the dash to expose the blower motor. the resister is next to the blower motor.
    Aug 09, 2008 | 2004 Oldsmobile Alero
    Haier hwr10xc6 Air Conditioner Logo
    307 people viewed this question
    Top Haier Heating & Cooling Experts
    Tom Chichester
    Matt
    Matt
    Level 1 Expert
    Michelle Balcom
    Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
