Question about Maytag Portable Air Conditioner M6P09S2A
Poetable AC compressor licks in for 10 min
The compressor on my portable A/c started shutting off about every 10-15 mins. it will blow cold air then blows warm for 10-15 mins then kicks back in again. is this an expensive problem to fix? whats causing it?
  • Anonymous Jul 09, 2008
    These Maytag portable A/C units were manafactured by the (now-defunct) Feders corporation. Maytag took over the warrantys in Dec 2007 after Feders filed for Chapter 11. Unfortunately, Maytag has NO CLUE how long it will be before these units can be serviced.... everything is tied up in Chapter 11 legal ****. It has already been 7 months and they still can't answer the basic question of when? In the meantime, we are dying in the current heat wave here.
    denise@denisestone.com
    Novelist:
    Champion:
  • 230 Answers
It is probably either the high pressure switch or the frost control. The high temp switch usually trips because the condenser coil is dirty which does not allow it to exhaust heat very well. The frost control will trip if the system gets below 39 degrees on the pipes. This is usually do to low refrigerant or dirty filters. Good Luck!
Posted on Jul 03, 2008
How do i get my newair af 1200e portable air conditioner to stop blowing cold and warm air.
that is normal operation when thermostat setting is reached it will cycle off compressor.
Sep 09, 2015 | NewAir Heating & Cooling
2007 Toyota Yaris blowing cold air for 1 min then starts blowing hot/warm air
Vacuum leak most likely, thus not operating air blend door.
Jul 01, 2015 | AC Cars & Trucks
Compressor only stays on for 2-3 minutes than shuts off
if the sensors are okay, it might be the compressor overheating, my portable ac (moretti elite ac) is also behaving the same, especially when i turn the fan to max. the compressor shuts down about 7 mins and turns on again in about 5 mins, now i found out when i turn to medium or low the compressor runs normally. i think when on medium or low setting some of the cool air directs/channels to the compressor thus cooling it more.
Jun 03, 2013 | Frigidaire FAP094P1Z Portable Air...
Ac clutch relay 2001 lincoln ls location
drivers side next to the battery
Sep 11, 2012 | 2001 Lincoln LS
My ac gets cold for 10 to 15 mins then it starts to blow hot air it does that everytime
could be freezing up in the evaporator core thermister may be your problem that sensor shuts off your compressor to allow the core to defrost also check charge in the system may be overcharged hope this helps
Aug 02, 2011 | 1999 Volvo S70
I have a 2003 toyota corolla. My AC would blow cold air for a min or two then when the compressor shut off it would no longer blow cold air or come back on. A new compressor was put in it but it did not...
the ac clutch relay is the problem. It is located in the under hood fuse box. It is a $10 part. The relay will make a clicking sound when activated but the contacts inside are burnt causing no electrical flow to the ac compressor. Simply unplug and replace. The relay is labeled M/G CLT .
replace or blow out the cabin air filter as well. It is located behind the glove box. Instructions are in your owners manual.
Oct 31, 2010 | 2003 Toyota Corolla
It blows cold air for 5 min. and the it blows cool air for 15 min. the room warms up . Why does it stops blowing cold air continuasly???? The thermostat was disconectet on purpose so it coul clow cold air...
See if you can reposition the thermister on the facing of the evaporator coils. That could be it or the thermister might be bad. They don't use copper/mercury sensing bulbs these days. They use these cheap thermisters.
May 22, 2010 | LG Heat cool Window Air Conditioner
Blows cold but shuts down no freeze up
Check the capacitor. It should be a dual capacitor , runs both compressor and fan. This sounds like your problem only because both the compressor and the fan go out together. Good Luck Hope I helped
Dave
Sep 16, 2009 | Dometic Rooftop RV Air Conditioner
A.c compressor kicks on and off
How long has it been there, without experiencing any problems? This just start recently? Have you cleaned intake air filters at ceiling? Fan keeps running?
Jul 18, 2009 | Coleman Mach 15 Air Conditioner
Heating & Cooling Logo
426 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
