Question about Lexmark X1150 All-In-One InkJet Printer
Scanner will no longer work
I uninstalled
  • zzkatjean Jul 03, 2008
    Yes, it is for a Vista system.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is this for a Vista computer?
  • Lexmark Master
  • 2,794 Answers
Make sure you uninstall the driver you have and then download and install this new driver:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:386:0:0&searchLang=en&os_group=Windows%20Vista&target=
If the XP drivers are not removed, this driver may not install properly.
Posted on Jul 03, 2008
    Sergeant:
  • 287 Answers
Try HERE for the appropriate driver, download and install.
    Scholar:
  • 101 Answers
Try reinstalling it. It may have had a corrupted driver.
My Canoscan lide 700f will no longer scan negatives
Hello try to reinstall the software for the scanner from here:
http://www.usa.canon.com/cusa/consumer/products/scanners/film_negative_scanners/canoscan_lide_700f#DriversAndSoftware
Please select your windows system 32 or 64 bit.
Download the driver and uninstall the old software before you install the new.
Canon does make an driver upgrade once a while to fix previous problems with the software.
Hope this will help you
Dec 18, 2012 | Canon CanoScan LiDE 700F
My Lexmark X2500 will no longer scan anything and send it to documents like it used to do? Instead I get the "test pattern" printed out that you get when changing ink jet cartriges?
Make sure the usb and leads are securely sated
the drivers for the scanner might have been corrupted
you might have to uninstall the scanner restart your computer then reinstall your scanner
if your printer/scanner came with an installation disc the drivers could be on it
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow ? ! Question/exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver disable uninstall or select properties again you will have the similiar options also have option to troubleshoot hope this helps you
Oct 03, 2011 | Lexmark X2500 All-In-One Printer
Cano Scan lide 60 no longer able to find twain source. What to do? Am using windows vista. My laptop is a toshiba equium u400-124
Usual issue with this scanner. Best solution is to uninstall the drivers for it then re-install the drivers from canons website.
Dec 29, 2010 | Canon CanoScan LiDE 60
Scanner will not scan an item into My Documents
try to uninstall then reinstall the driver. to do that go type device manager in run box in XP and start search in Vista/ Win 7, and look for the scanner. right click and uninstall. then load the driver from the website or from the cd that came with your device..
Mar 29, 2010 | Computers & Internet
My HP 5370C scanner no longer works. When I tried to scan, a blank white image appeared. Tried a few more times, same thing. The next day I tried scanning again a pop-up appeared indicating ,no scanner...
The problem is in the connection cable, Check the cable that connects your scanner with your computer, If still not working, try replacing it with a new one.
Jan 26, 2010 | HP ScanJet 5370C Flatbed Scanner
I have an HP Photosmart 4280 All in oNe printer scanner. The canner stopped working in the middle of a project - sais that the USB was not connected. I looked at your site and downloaded new drivers. ...
uninstall the printer software from ur computer restart and the reinstall the same, disconnect the printer while doing all that and the connect the printer to a different usb port bro
Jan 11, 2010 | HP ScanJet 2200C Flatbed Scanner
Will not scan my pictures into my pc
im just going to guess here. im going to take it that this scan option has not work since first installing it?
if this is the case. disconnect you pc from the web and disable you antiviru software. then uninstall the previous installation completely. and reinstall the software.
anti viru software is the biggest cause of incomplete installations of scanner drivers.
if your os is vista check with the maker for your all in one look for a patch that mentions drivers uninstalling themselves.
i had to get a patch for my 7410 because in about hour after i installed it the scanner would quit working and the drivers were no longer present on my pc.
Dec 02, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Epson all-in-one printer no longer detecting scanner
Your scanner might not work proprietly. Try to take it back to the shop you bought the printer from and report to them your problems.
Dec 24, 2008 | Computers & Internet
Canon Scanner - Twain Pilot
QUICK ANSWER: use the original USB cable that came with the scanner.
LONG EXPLANATION:
Using Vista (32 bit version) and a Canon N670U scanner with the new drivers installed from the CanonUSA website. This driver is works for Canon scanners: LiDE 20, LiDE 30, N670U, N676U and N1240U, found at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=6625
Canon says it doesn't support Vista 64 bit version. I couldn't get the scanner to work and kept getting the TWAIN error also, despite uninstalling / reinstalling the driver. Finally, decided to disconnect my 3rd party 16 foot USB cable and use the original cable. I swear, it WORKED! I can't explain why, but it did. Perhaps there is increased resistance, hence reduced power going to the scanner by using longer/different USB cable? Anyhow, it worked...go figure. If you have the 64 bit version of Vista, I guess it won't work(?).
Mar 24, 2008 | Canon CanoScan N656U Flatbed Scanner
Lexmark X1150 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
