Question about i-mate K-jam Smartphone
Synchronization with outlook?
I have lost the CD that came with my K-JAM. I have a new computer and I would like to synchronize with outlook. How can I get the software for sync
Download Active Sync from Microsofts wabsite. It is free.
Posted on Jul 11, 2008
How do I load and coordinate my MS Outlook address book and calendar with my Blackberry Curve 8330?
Here is how you do it:
1Install Blackberry Desktop Manager Softwarewhich included in your Blackberry Installation CD. If you don’t haveone, you may download software from Here
2Make sure you set an Outlook profile that the Desktop Manager can use.3Start the BlackBerry Desktop Manager.4Connect your Blackberry with your computer via USB cable and allow Blackberry device driver install.5Click on Synchronize in BlackBerry Desktop Manager.6Activate the Synchronize organizer data checkbox: BlackBerry Synchronize.7Click on the Configuration tab. Then, click on the Configure synch: BlackBerry Synchronize Configuration.8Check the data you want your BlackBerry being synchronized to. Choose CONTACTS, TASKS, CALENDAR, and NOTES databases.9Afteryou check each item, the software will ask which application you wouldlike to sync it with, you will choose OUTLOOK for all.10Nowgo back to the Desktop Manager. Make sure that the SYCHRONIZE ORGANIZERDATA check box is checked. And select the Synchronize now button at thesynchronize dialog to begin synchronization.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Dec 30, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
How do I copy address book and calendar from Tungsten E to Outlook?
In order to synchronize with Outlook you need to setup the replication to be with Outlook instead of Palm Desktop. On you cd there should be a third party piece of software (Chapura). Install the required software and follow the instructions.
Sep 12, 2005 | Palm Tungsten E Handheld
Original sync worked all others failed with 650 and Outlook 2003
I was ready to give up completely. Uninstalled, reinstalled, nothing worked. Here is what I did to resolve sync errors: 1. Perform a hard reset on the Palm 2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old. 3. Connect the Treo to your computer. 4. Right click the Hotsync icon in the taskbar and click Custom. Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld. 5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now. This worked for me. I hope it helps with your errors.
Sep 12, 2005 | Palm Treo 650 Handheld
Switch from outlook to palm desktop
Remember to change (HotSync, Custom) settings before you perform your sync or else you will get duplicate records as I did. Good luck. Support Knowledge Library Click here to go back Click here to print Solution ID: 25263 Switching between Outlook and Palm Desktop synchronization Depending on your device, you might be synchronizing with Outlook using the Palmâ„¢ Outlook Conduits, or PocketMirror conduits from Chapura (find out which). Both of these types of conduits are installed and activated when you run the CD-ROM that came with your device. What do you want to learn about? * Switching synchronization: Palm Outlook Conduits * Switching synchronization: PocketMirror Conduits * Synchronizing partially with Palm Desktop, partially with Outlook * Note about data transfer * Macintosh information * Multiple users on the same desktop computer Switching synchronization: Palm Outlook Conduits These instructions apply to the Palm Outlook Conduits that are included with handhelds released after late 2003. The Palm Desktop installer determines which conduits are activated during the installation process. If you want to switch synchronization from Palm Desktop to Outlook, or vice versa, you'll need the original CD-ROM that came with your handheld. 1. Insert the CD-ROM into your computer. A window should open, containing the contents of the CD-ROM. 2. From the Discover Your Handheld screen, select "Install Microsoft Outlook Conduits" or "Change synchronization method" (depending on which device you have) 3. Follow the instructions for switching synchroniztion from or to Palm Desktop or Outlook. 4. See our note about data transfer Remember: Some applications will continue to synchronize with Palm Desktop. Use Palm Desktop to manage applications such as Photos and VoiceMemo
Sep 12, 2005 | Palm Tungsten T5 - Multilingual Handheld
Just bought Zire 31 and won't hot sync Outlook Calendar, Contacts, Notes with the following log:
Generally this error means that HotSync manager (via the 4 Outlook conduits) is having a hard time connecting to your Outlook or, in some cases, specifically to your Oultook profile.
Sep 12, 2005 | Palm Zire 31 Handheld
OLERR messages, however all of mine fail to sync: Calendar, Contacts, Tasks, Notes. Tried web troubleshooter to no avail. Can anyone please shed some light on this issue??? Thanks
I was having the same problem, and I used Detect and Repair in Outlook. Now all is working fine. You will need the original CD that you installed from. Hope this helps as none of the other things that I saw on any sites did until I tried this.
Sep 11, 2005 | Palm Zire 72 Handheld
How Do I hotsync w/Outlook
what software did you download for your outlook conduits? the installation cd already has the outlook conduits you need.. you just have to install palm desktop first then you'll be given options whether to sync your handheld with palm desktop or with outlook. choose sync with outlook
Sep 11, 2005 | Palm Treo 650 Handheld
How to synchronize outlook
Switcher.... Inorder to sync your handheld with Outlook you must have outlook conduits installed. Follow these steps to have an outlook conduits installed. 1. Place the Desktop Installation & Software Essentials CD on your cd-rom drive. Wait for it to finish its autorun 2. At this point you'll be presented wth a flash window which contains certain options you can choose. 3. Click on "Change your synchronization method" 4. Click on "Use Microsoft Outlook to ...... " 5. Click on "Yes" 6. Click on "Done" 7. Restart your computer inorder to refresh the new settings. You can now use Microsoft Outlook to synch your appointments, contacts etc..
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Sync fails with "too many open databases"
This is what I did to fix that error:
Hard-reset your Palm to erase all data (that usually involves pushing the small "reset" button on the back, then pressing the "power on" button until the device boots, and then pressing "up" to confirm the hard-reset)
After that, sync your palm. The sync software will ask if you want to use your existing profile or create a new one. Create a new one. Then the program will offer to sync your Outlook profile with your Palm. Click on "ok", and a message asking you to accept to sync your Outlook data with more than one profile will pop-up. Click on OK, again... and that's it!
Sep 07, 2005 | Palm Tungsten T3 Handheld
Synch question
If you have PocketMirror from Chapura (included with certain Palm handhelds), you can choose to install conduits that synchronize MS Outlook with the handheld applications Date Book, Address Book, To Do List, and Memo Pad. You can choose to synchronize these applications with either Palm Desktop or Microsoft Outlook, but not both. If you want to synchronize with Microsoft Outlook, DO NOT install Palm Desktop from the Web. Instead, run the Palm Desktop installer from the CD that came with your handheld and select the option "Synchronize with Microsoft Outlook" when the choice appears. Visit www.PocketMirror.com for more information about Chapura(R) PocketMirror.
i-mate K-jam Smartphone Logo
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
