Question about Microsoft Windows Vista Ultimate Edition
Slow booting & shut down
Im running vista ultimate edition, its working fine, except it boots & shuts down really slow, 10-15 mins, minimum. Help.
  • Anonymous Jul 03, 2008
    I have the same exact the problem but when it is time to boot up it takes hours to get going. Windows says I need the disc to it order to repair since I purchased this through a third party. I am stuck.
  • sadams2_2001 Jul 23, 2008
    Vista takes over 10 min to shut down, have a Satellite L335-S7812
    Novelist:
    Scholar:
  • 158 Answers
The only thing I can sugust is remove norton 360 if you have this onboard and get other firewall and spyware and antivirus software.
and disable the sidebar with the widgets, and change desktop view from aero to clasic this will boost up loading and shutting down of laptop.
you can purschase vista, then download all drivers for laptop from manufactures and re-install from scratch.
good luck with problem
Posted on Jul 09, 2008
Gateway zx6971 no signal
Let's see if anyone else has a suggestion, but it sounds a bit like the DDC info is not being transferred correctly by the monitor OR you have a bad graphics driver. You should try and boot up in Windows Safe-More by pressing f8 before the windows logo shows on the screen during the boot process. if this does not help, I would suspect hardware malfunction, which means you should connect another known working screen to the computer for testing.
Mar 27, 2014 | Gateway ZX6971-UB30P 23 Touch-Screen...
Computer very slow ,won't print,forever to load pages, have corrupted files
Several things can slow down the computer: overheating, spyware, not enough RAM etc. If you know for sure you have corrupted files were they corrupted by a virus? You may need to reinstall Vista.
Is it slow when you boot up in safe mode? To boot into safe mode hit (usually) F8 while it is booting up. Let it completely boot into safe mode and then reboot again. Now is if it is behaving better.
To get rid of spyware download the free Spybot Search & Destroy from the net, run the update and then run it to dectect and get rid of the spyware. Spyware tries to send info which can slow down everything.
Overheating - does it feel hot? Is the fan running and pushing air?
If it worked fine before it is unlikely you don't have enough RAM. Windows itself needs at least 256mbs to run well without running other problems.
Again if you know files are corrupted, if they are windows files, you might need to reinstall vista.
Feb 22, 2011 | Microsoft Windows Vista Home Basic Edition
My computer is slow Carachteristics Cup: 3.2 Ram: 2 Giga Cash M: 2
Run a Disc Defragmentation: found under the start menu, accessories, system tools.
After this, under the same menu list, run a "disc cleanup".
Also, consider installing the following:
webroot window washer
webroot Essentials
You can find these at http://www.webroot.com
Please let me know if you need any further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
May 29, 2010 | Microsoft Windows Vista Ultimate Edition
My Toshiba P35-S611 shuts down without warning a short time (2 min-45 min) after it boots up. The battery isn't hot but the heat dissipation fins in the back are very hot.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
May 09, 2010 | Toshiba Satellite P35-S611 Notebook
I have Windows Vista Ultimate, my computer was running slow, so I decided to reinstall the OS. It boots with no problem and goes as far as setting up your computer. Then a window pops up stating windows...
Your missing the files that load the operating system. Put the vista disk back in, let it run and it will eventually ask if you want to setup or repair. Choose repair and then type "fixboot". That will fix your master boot record so the operating system can load.
Mar 08, 2009 | Microsoft Windows Vista Ultimate Edition
Start up and shut down
Extremely slow operation can be the sign of many issues. The first of them is the hard drive failing. (I suspect this as the most likely reason.) You should be able to run hard drive diagnostics from the F12 menu. If they fail, replace the HDD.
If the diags pass, then next thing I would look at is free space available. At a minimum, you should have 10% OF THE HARD DRIVE free for Windows to cache data. Dropping below 5% usually effect dramatic slow downs and below 2% can prevent internet access too.
Other possiblities include Virus/Spyware infection
Jul 29, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Windows XP Unusually Slow Startup
plz go to msconfig and disable all item except the antiviruse in the startup tab, then go to my computer propeties ,click on advance then click on performance then select adjust for best performance(visual tab) then go to advance tab and change the page file to 1024 for both(min and max) then do a full scale system scan for viruse
Post your findings
Apr 28, 2008 | Microsoft Windows XP Media Center Edition...
No startup
while its booting tap the F8 key into safe mode, once in safemode run registry cleaners/spyware/virus cleaners. if that doesnt work formate drive and reinstall windows.
Nov 27, 2007 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
119 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
