Question about Samsung PS42S5H 42 in. HD-Ready Plasma Television
Samsung plasma tv hp-r4262
I purchased my Samsung (new) on March 2006. Today I see a black bar (3 inches wide) running from top to bottom in the middle of the screen. What do you think is causing this.
  • jessegroce Dec 09, 2008
    black bar from top to bottom 3 inch wide on right side of screen was going to replace logic buffer when i found a short in the connector that connects from the bottom of the plasma screen it has a small hole burned into it can this be fixed?
  • 44 Answers
The x drive board is bad in the area you see as black. OR the cable came loose.
Posted on Jul 04, 2008
Black line about 5" wide
one of your buttom scanning bords is dead or it needs to be cleaned or simply reconnected properly , at the buttom of your plasma tv you have 2 to 4 small boards with flex connecters one of these flexible connecters will be adjacent to the black line ,replace entire board because it cannot be repaired
Sep 05, 2011 | Samsung HP-R4262 42 in. Plasma Television
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
We have lost a two inch wide black section on the right side of the plasma panel, any ideas
Most likely the lower buffer board " E " needs to be replaced. Right now I'm working on repairing a 42" Samsung plasma HP-R4272. The Service manual for that TV says for trouble shooting for that problem is the lower buffer board " E ".
Best to find the correct Service Manual for your TV over the internet to get the correct part number for replacement. The Service Manual should be less than $20.
Oct 25, 2009 | Samsung PS42P2S 42 in. Plasma Television
Black bar running from top to bottom in the screen.
There are horizontal and vertical relays in plazmas that go out over time and cause this to happen , You can get an estimate from a local tv repair service in some cases they can give it to you over the phone. Good luck.
Dec 30, 2008 | Samsung PS42S5H 42 in. HD-Ready Plasma...
Black line
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Dec 11, 2007 | Samsung HP-R4262 42 in. Plasma Television
Screen Problem
I have been trying to fix one of these tvs and found out from a repair man that the lower half going blank means a problem with the lower buffer. and that is also what the manual I downloaded says.
have you checked that?
Dec 07, 2007 | Samsung HP-R4262 42 in. Plasma Television
Large black line top to bottom
Oct 26, 2007 | Samsung HP-R4262 42 in. Plasma Television
Black 3-4 inch wide Stripe
this problem is a bad panel it needs to be replaced in some cases the panel is under warranty. check your warranty.
also the E and F buffers could be at fault I would have these replaced first.
Oct 14, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung PS42S5H 42 in. HD-Ready Plasma Television Logo
284 people viewed this question
Henry  Thomas
Henry Thomas
