Question about Singer 7462 Mechanical Sewing Machine
I dont know how to thread the pfaff 1222e machine, I need a picture showing threading of the bobin and the machine. I dony have any money..................
  • Anonymous Sep 09, 2008
    lost my manual on model 3116 i need to know how to thread my machine...
  • Singer Master
  • 1,388 Answers
Take a look at this Sewusa Link to take you to the threading diagram for this model.
Bargainbox
Posted on Jul 18, 2008
The top thread will not pickup bobbin therad it is a pfaff 5.0 machine
The bobin may not be in correctly. When looking at the bobin, with the thread threaded through the bobbin case, make sure that it spins counter clockwise. Also the problem could be caused by the machine not threaded correctly. But it is more likely the bobbin case and bobbin
May 04, 2017 | PfaFF Sewing Machines
I have a pfaff 4.2 quilt expression brand new but cant make it work. The thread in the bobin keeps jamming? What cani do
thread jams or breakage generally points to incorrect thread tensions
read the hand book and adjust accordingly
Jun 10, 2015 | PfaFF Sewing Machines
Pfaff 1222e
Hmm, be sure when you thread your top thread that you ALWAYS RAISE the presser foot. That allows the thread to seat completely in the tension disk. However, in your case, the tension mechanism may need repair or replacement. Most often, there is a spring involved that will wear or be damaged over time. May be time to take it for service.
In my opinion, those older mechanicals are keepers. Consider that it has lasted you 40 years---can't beat that! And it's still worth fixing.
Nov 17, 2017 | Sewing Machines
My pfaff 1222e isn't working the motor runs but the needle doesn't move ~ the knob at the end of the machine won't turn at all
Check for thread jams... hopefully that's the problem and not a bent shaft in the thing.
Nov 28, 2012 | Sewing Machines
Hobbylock 797 how to thread
The hobbylocks all thread in much the same fashion.  There is a diagram for a four thread hobbylock on this website.  It would be better if you found a Pfaff dealer to show you as it is quite complicated.
http://www.pfaffmachines.co.uk/overlock/pfaff-hobbylock-2-overlocker.htm
Once you have it threaded, always cut the old threads at the spool and knot new ones on and pull through.  You will have to thread the needles as the knots will not pass through but it does save an awful lot of frustration when needing new colours on the spools.
Mar 28, 2011 | PfaFF Sewing Machines
How do I tighten the tension on the bobin thread I am quitiing with invisible thread on the top and dark blue on the bottom, the bobin thread shows. I don't want that
you can either increase the bottom tension or reduce the top tension .. you will notice a little screw on the bobin case ... that screw adjusts the force on a small flat spring which provides the bottom tension (the thread goes under the spring when properly threaded) .. .. tighten that screw a little to increase bottom tension .. you can pull thread thru the bobin case to get a feel for how much tension you have ... you dont have to turn the screw very far to make a significant difference .. try just 1/4 of a turn at a time .. remember where it was originally set so you can put it back when you are finished with your present project .. the greater the bottom tension the less bobin thread will show at the top ... if you get the tension too high then you might see some puckering as you sew ..
Jan 03, 2010 | Sewing Machines
PfaFF 1222e timming is off
Setting time isn't as simple as it sounds. You'd have to follow a checklist first before you can do the setting. I could tell you but it is just too long to upload and don't know how I can post the img's. So my best advice is to buy the factory or generic repair manual.
Dec 17, 2008 | PfaFF Creative 7570
Singer 7462 Mechanical Sewing Machine Logo
184 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
