Hey borot,
"Firmware" is another word for any pre-installed software that is necessary to operate an electronic device, like your PSP. Often manufacturers will release updates (also called "patches") to firmware, in an effort to solve problems that users may have encountered or to provide additional features and content for their products.
The first thing you'll need to do is establish an internet connection with your PSP in order to perform a firmware update. If you are unsure how to do so, you may wish to refer to your owner's manual documentation for further information.
Once an internet connection has been established, you will need to insert a memory stick into your PSP and connect the AC adaptor. Next, you should be able to select "Network Update" under the "Settings" option in the main dashboard menu. After you've chosen the "Settings" option, you will need to select which connection that you want to use. Available updates should automatically be detected once you've connected to the Playstation Network. You'll then need to follow the step-by-step instructions that appear on your screen to download and install the update files.
If you're still not sure how to proceed, I would strongly suggest checking out the link I've provided below to Sony's online support center.
http://manuals.playstation.net/document/en/psp/current/settings/update.html
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
