Question about Emerson MW8108P Microwave Oven
Melted turntable support
We had the microwave on with nothing in it...the little turntable support under the glass turntable melted and sparked...can this be replaced?  Hotpoint model RVM1335BC001
  • r_carig Jan 01, 2009
    Hotpoint Model RVM1335BC 001
    Serial Number: GZ 9693558
    MFR Date: April 2000
    Turntable Support Coupling burnt even with food in the oven. Burn started and progressively got worse on one side of the coupling until large sparks and flashes appeared. When the burnt area was cleaned off sparks went away and returned within a few days. Coupling is now damage beyond cleaning as a temporary fix. Is this a material decency or random failure?
  • Emerson Master
  • 9,098 Answers
Yes, that's part # WB06X10138 (coupler) and you can get it here.
You will need to remove the bottom cover of the microwave and remove the turntable motor to get the new coupler in.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 04, 2008
Melted plastic turntable teeth
If only the teeth, get a new replacement ring . If it has melted so bad that it is part of the m/wave floor, you don't have much choice. Have you tried speaking to manufacturer?
Aug 07, 2013 | Samsung Microwave Ovens
The turntable stopped turning and when I press start, nothing happenes. The clock still works and the light comes on when opened but, nothing else.
Check the turntable guide to make sure it is lined up properly and that there is no debris caught in it. You may need to re-align or clean your turntable guide.
Cleaning and realigning a turntable guide;
Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable.
With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing.
Test your microwave after this thorough cleaning and realigning in order to determine whether this has solved your problem. DO NOT run your microwave with nothing in it.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Also, Examine the plastic drive bushing the turntable tray sits on. It may have become worn, or even may have split in two;
Drive bushing replacement
Inspect the plastic drive bushing located below your microwave oven's turntable tray. There may be some debris blocking the tray's range of motion. Clean away any blockage you find, and then test your microwave to see if this has cleared up the problem. DO NOT run your microwave with nothing in it.
However, if upon your inspection, you notice that the plastic drive bushing below the turntable tray is worn and/or broken, you will need to have the bushing replaced. Consult with a certified and experienced appliance repair technician. Replacing a drive bushing is a lengthy and involved process that the average layman should not perform.
Jan 09, 2012 | Emerson Microwave Ovens
It burns thru the glass trray and melts the wheeled tray holder...
There are two possible reasons for this to occur.
1.there was dirt on the turntable and that carbonized and got so hot that it melted the tray. That heat would've melted the plastic spider as well.
2.the microwave oven was turned on with nothing. or almost nothing, in it: the glass turntable is what is known as "a matching load". That means it is there as a safety precaution, protecting the magnetron, in case there's nothing in the microwave oven when it is energized. As such, the glass turntable can get hot enough to melt. That, in turn, will melt the plastic spider.
If either of those is the case, it is OK to buy a new spider & turntable.
Mar 10, 2011 | Microwave Ovens
GE PVM1870 turntable not working
The little brown thing is broken. I have several break or melt. Pull it out and look at it.
Nov 18, 2009 | General Electric PVM1870 Microwave Oven
Maytag Over The Range Microwave: Melted glass turntable, rollers
Considering the melting pooint of glass ...
Normally, microwave travels around round surfaces (Look at the B-1 for example) If you put flat metal in a microwave, you will create sparks ... lots of em. Is it possible you have something going on with one of the wheels ... like a piece of tin foil?
At a minimum, I think id be inspecting everything inside very carefully and then give it a good cleaning.
You might want a pro in your area tale a look at this as well.
Oct 05, 2009 | Maytag MMV4205 Microwave Oven
Plastic piece for turning turntable has partial meleted.
This is a pretty simple, inexpensive fix,
The best place to order parts for this brand is Encompass (formerly Tritronics).
If you don't find the part on their Web site, I would call them with your model number. They are toll-free at 866-779-5835.
Feb 02, 2009 | Goldstar MV-1715 1000 Watts Microwave Oven
Emerson MW8108P Microwave Oven Logo
711 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
