I have jbl eon15 g2 which recently started to crackle when adjusting the levels. Recently that noise stopped, but when I raised it to high level (not out ordinary for the last 7 years) the sound cut out! I immediately pulled the cord from input 3 and plugged into input 2. It worked for a few seconds, then did it again. I pulled it from 2, put it back in 3 and so the cycle repeated it self. My guess is that it made no difference which one it went into, rather whatever heated up, seemed to have reset itself. I have some knowledge of electronics and can to some testing and soldering. Any ideas of what causes this?
  • 4,234 Answers
Open up the unit and clean the gain/volume control using an electronic swithc cleaner spray. Make sure that the cleaner contains a lubricant as well. That should resolve the problem. If not, update this with any changes in behavior.
Dan
Posted on Jul 03, 2008
    Sergeant:
    Champion:
  • 417 Answers
Its shorting out on you i did more research on this inside there is a chipboard now there is a fault inside and you need to take it in for test so they can find exactly whats shorting it out
I have a JBL Venue sub12.It pops and crackles at certain levels.Ive had it for 5-6 years, dont use it much. Ive turned the volume down on the speaker to the lowest setting and it still makes the noise
It is hard to diagnose without seeing it, but most likely you need a new amp. We have them in stock. http://reconingspeakers.com/product/jbl-sub-12-amplifier-assembly/
Nov 21, 2016 | JBL Audio Players & Recorders
Remote reset
Yes the woofer and tweeter can be replaced but the woofer needs a recone kit to repair as the whole speaker cannot be replaced without replacing half of the speaker enclosure.... call JBL pro or a service center for help.
Oct 08, 2013 | JBL EON15 G2 Main / Stereo Speaker
My JBL eon 15g2 speaker was working fine and then suddenly the lower woofer suddenly stopped. The higher tweeter still seems to work. All of the fuses are fine and all the wires seem to be properly...
the braided wires from the speaker connectors to the voice coil could be broken (from repetitive movement) or it could be the voice coil it self that could be cut open from a miss alignment of the cone (ware and tear), delicately push on the cone and feel if it rubs, a simple test is to check the IMPEDANCE of the speaker with a OHMMETER, if you have a reading (4,6,or 8 ohms) than the speaker is fine, check the rest of the wiring, if it reads OPEN than you need a new speaker...
Apr 09, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
My JBL Eon15 g2 has a cracklin sound within the main component when the bass is turned up. How can I fix this?
it can be the amp or the speaker itself. it has to be diagnosed by a service center.
if the amp is the problem, there can be board replacements or component level repair. if it is the 15" speaker, then it can be reconed with authentic genuine JBL parts returning it to brand new. cathy@speakerex.com
Jun 21, 2009 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL EON15 PA Speaker problem
check the wire terminals under the cone by the spider and make sure that they are both still connected
Apr 16, 2009 | JBL GTO Series RLC Amplifier Accessory -...
JBL EON G2 15 loud noise.
The noise may be the reason why the speakers were available used. The tweeter may be defective.
Jul 22, 2017 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL Eon G2 Speaker
from our experience rebuilding woofers once the lead wires get pulled too much or start to strain you have been running too much power into the woofer and making the cone move too far in and out.You need to cut the input signal from your preamp down and cut the volume down on the speaker input on you eon. We keep seeing too many of these amped speakers blown from too much signal.
Oct 12, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL EON15-G2--Does the HF Amplifer to the driver have any voltage?
The 2 leads that come off the HF driver are different sizes...you should only be able to hook them up one way. Takes the guess work out of it for ya.
Assuming there is nothing wrong with the speaker, hooking up the 2418H HF driver to it should do the trick. However, I blew my HF driver a few months ago and bought a new one, only to blow it immediately. This was because the motherboard of the JBL EON G2 had actually failed and caused the HF driver to fail. Once I replaced the motherboard and the HF driver (again) everything was back to sounding great. Hope that helps.
Oct 10, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
KitchenAid Superba humming
First to adjust the leveler/wheels you will need to remove the front grill/toe plate. On the left and right sides you should see some bolt heads that are about 1/2" hex head. One on the left adjust the rear leveler/wheel and the other on the left adjust the front leveler/wheel. Turn the hexhead clockwise to raise cabinet higher counterclockwise to lower cabinet. The right side is the same.
Now to your noise, it sounds like you may have pushed the cardboard air dam under the condenser and condenser fan motor near the compressor up into the fan blade area. Carefully follow the source of the sound and you will find what is out of its proper position.
I hope I helped, supertechks
Nov 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
63 people viewed this question
 Grubhead
Grubhead
