Panasonic active subwoofer
I have a panasonic active subwoofer left over from an old dvd and surround sound set. I'd like to hook it into an amp that runs my gaming system sound. It has a 13 over 12 pin female input socket. Any ideas or should i just scrap it?
  • dukeofmud Jul 04, 2008
    Cheers for the advice. I managed to locate the speaker wires....took a while... and bypassed the amp. Its now wired in to the and have wired it in to the gaming system. Works pretty well. It'll do till i can afford a decent setup.
    President:
  • 624 Answers
No way to connect it to your gaming system, unless you are good at rewiring things and even then it may not work right. It would be a tough job, but if you give me the model number I could send you the pinout of the din plug jack. You would then need a male din cable to connect into it and try to figure out which color wire goes to which pin. It can be done, but not to easy. You can't connect it to an amp, it has an amp in it. you would need to use it as your amp. Or just remove the amp section and go right into the speaker wires that plug into the amp board of the panasonic. If you want that information put your email address in the next post with the model of the sub-woofer.I will email what I have on it.
If I were you, I would sell it on ebay before trashing it. There may be somebody who needs one just like it. It can be used with a couple of different Panasonic models probably.
Posted on Jul 03, 2008
Panasonic SA-HT930 surround sound. Only the left and right speakers have sound. I need to check the pro logic setting, however, I have lost the remote.Is there any way to activate surround without it?
There doesn't appear to be any buttons on the unit which activates any sound setting. Without a remote you are stuck. Worse still is that remote for your model seems to be no longer made. If I have the right code, you can try searching for it yourself.
EUR772XD0.
Have a look on the Curry's Partmaster website for a start.
Aug 18, 2015 | Panasonic Audio Players & Recorders
I have a panasonic home theatre system Model No SA-HT690 and want to bypass the DVD player and hook it up directly to my new Samsung TV. I want to be able use the surround sound when watching TV and using...
I don't really understand what you want to do. The DVD player in the Home Theater, you don't want to use or doesn't work? In any case, the sub needs to be hooked up to the Panasonic, not the TV. The Panasonic doesn't have an HDMI out? If you let me know just what you're trying to do and why, I can be of actual help. I will also need to know what connectors are available to you, and on which unit.
Dec 07, 2014 | Samsung Audio Players & Recorders
Panasonic sb-wa 340 active subwoofer has just low freequensy noice from subwoofer ! The other speakers working good and dvd fanction normally !
This is normal operation.. The subwoofer will only play sounds below a set frequency...There may be a crossover setting in your menu that you can adjust the frequency cutoff to your liking.
Oct 01, 2010 | Panasonic SC-HT690 System
My surround sound will not work through the TV, only the DVD
If your tv and surround has an optical input/output.Then you can connect with an optical lead.This will then play the sound from whatever you are watching.You normaly select dig1 or input1 on the surround system.
Nov 12, 2009 | Panasonic Televison & Video
I have a 3 yr old Panasonic 42" Plasma
it might be coming from the actual audio/video source. try hooking up a dvd player or gaming system and see if it still does it.
Jul 11, 2009 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Replacing a Surround Sound System Receiver
the difference is the "same speaker connections"
the front and rear will connect the same but the subwoofer is amplified by the HT75 , and the HE75 does not have an internal amp for the subwoofer speaker , only a "pre output"(has to be amplified)
Mar 24, 2009 | Panasonic SA-HE75 Receiver
Panasonic subwoofer
Any active subwooofer. I have an HE70 as well and I am using the SONY active subwoofer.
Nov 12, 2007 | Panasonic SB-WA100 Subwoofer
Subwoofer Connection: Speaker wire to Mono RCA
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
  1. Connect the mono RCA subwoofer output from your Sony with a 1xRCA-to-2xRCA splitter to both the left and right input of the cheap reciever's tape or aux input
  2. connect both speaker outputs of the cheap reciever to the speaker input on your subwoofer. make sure both black (-) outputs on the reciever connect to the black input on the sub, and the red outputs (+) on the reciever are both connected to the red input on the subwoofer.
  3. make sure the cheap receiver's volume is all the way down. turn your Sony up to about the loudest you'll listen to it. turn up the subwoofer amp until it's loud enough to sound good.
  4. leave the subwoofer amp alone, the Sony volume will all you ever need to touch from now on.
You can even now turn off your subwoofer / adjust the volume easily now!
Oct 30, 2007 | Audio Players & Recorders
256 people viewed this question
 Grubhead
Grubhead
