Saws Logo
Posted on Dec 20, 2010
The blade won't up & down any more - Saws
A
Anonymous
If I understand correctly, you have a table saw and the blade won't raise and lower.
If your table saw is like mine, there is a threaded gear that turns when you want saw to go up.
When my blade stuck, I crawled under the saw with a toothbrush and WD40.
Used toothbrush to clean away sawdust and get down to the metal thread.
Then I sprayed WD40 on the threads.
I kept working on it until the saw started going up and down again.
One other thing.
If the handle no longer turns threaded rod, you may need a new handle.
Or substitute vice grips, like when car window handle wears out.
Vice grips are inconvenient, but would do the job.
Anonymous
Level 1:
New Friend:
  • Contributor 33 Answers
  • Posted on Dec 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
33
Questions
0
Helped
7149
Points
99
The wheel that you turn has a long bolt which threads through a type of nut on the motor assembly. You will need to turn the table saw upside down to check it. It maybe broken or jammed, There also could be a piece of wood the fell in there and is jamming the mechanisim.
Pleas leave a comment if this helped you out
Good Luck
I ordered a new blade because the original one's
No one can help you without the make and model number of your shaver
5 ' brush hog boggs down when attempting to mow & one blade hits underdeck in one place
sounds like that blade is bent also if they are dull it will bog down more
Jul 05, 2012 • Garden
2answers
10 inch table saw blade not square with table
Sounds like the bolts that hold the motor assembly on the table may be loose allowing the blade assembly to move. Look underneath the table and clean out all the dirt and loosen all the hold down bolts and realign the blade and tighten back up.
When I turn it on, the blade is slow to take off turning. Sometimes it just won't go at all, so I turn it off so as not to burn up the motor. Does it need cleaning, oiling, or something else?
If you don't have the original paperwork for maintenance for the ceiling fan this is what I would suggest: Cleaning and adding lubricant to the fan's main stem.
Put some lubricant on the fan stem: a drop of oil / graphite grease will do it.
First turn OFF the power, AT THE CIRCUIT BOX - BREAKER BOX.
SECOND Get a household or larger step-stool sized ladder 5 - 6 ft - set it up by your fan, clean the stem around the blade area, wipe gently with a Swiffer duster pad (those pink & white loopy-looking pads, they come in a kit in cleaning supply section of store -- with a slide-on plastic handle, & refills).
These REALLY do work to attract the majority of the static-oriented dust that is so common on electronics.
Then :
Clean and dust off all the blades, (if wood a drop or two, of a Murphy's oil soap will keep them looking nice).
So - clean them - add the Murphy's oil soap, using a small spoonful to 1/2 cup of warm water. Mix in an empty 'Cool Whip' (or similar sized container).
And place that on your small ladder on the ladder's shelf; for ease of use -- no pesky buckets to worry about getting knocked over -- (then start to clean using a rag made from an older smooth cotton sheet, or a really worn towel that has VERY little 'lint producing' potential, (the less junk you add to this cleaned fan the better) as to ANY lint on towel or cloth residues) -- wipe carefully, working slowly -- all the surfaces of the wood!
Top, bottom and those PESKY thin edges. That way you won't be fighting extra dirt in your eyes as you try to tackle the other problem! Dry off the blades with a clean cotton rag made from a sheet. Gently, no hard rubbing needed,
Ok, so NOW you are done with the fan blade cleaning, I bet it looks nice!
Add the oil: a drop of WD40, a household oil in a metal skinny can with a progressively graduated 'needle' like top (or a small dab (using a paintbrush dedicated to that use) of graphite grease -
Some hardware stores sell it in small tubes ... (or small containers like the size of sterno fuel jars) ...
You don't want any motor running without adequate lubrication, or they run 'hot'. Then they can start to cause trouble.
Add the graphite or WD40 to the stem, let it 'run' down the stem & add a 'little' more, but not too much as to 'flood' the area below where it is needed or 'flowing' to ... before you climb down the ladder and go to turn it on -- look to see if the oil has run the length of the rod, is allowing easy movement, as to turning of the blades.
Check it manually by pushing the blade in the direction the blades are set to go, by pressing the fan blades to move forward with a flick of your fingers. They should move easily without hesitation.
Look above and below the blade location as to connection of the blade on the fan rod or stem itself, to see if all oil needed is present; stem is not appearing overly 'dry', or too 'wet' either.
When that is done to your satisfaction, climb down from the ladder, turn on the fan, let it run for a while on the LOWEST speed setting, then check back like in perhaps an hour. AS to if it needs another oil addition.
If not I'd say start out on low always to turning it on, then change to medium speed or high only later.
You don't want to start off on the highest setting each time you use it. That is a likely way to burn out a motor.
If it is running 'smoothly' without 'wobbling' or smelling 'hot' as to an electric motor that is laboring, then you are in business!
Proper maintenance is 'always' welcome if you want your appliances & fans to last ...
Highlight these instructions in yellow sharpie - if you print a copy to use, as to steps that worked well. Then follow those every time from now on.
CLEANING THE FAN at least once or twice A YEAR for basic maintenance that will save you stress, money in the long term (it won't need replacing) and help keep you cool ...!
So ENJOY your fan and the coolness it delivers!
Aug 21, 2011 • Dryers
When backing up the mower blades shut down and won't come back on when I try to go forward again.
on most riding lawn tractors you most first disengage the blades before going into reverse moving the tractor stop, put the tractor in a forward gear then re-engage the blades. if this dose not help please contact me. Thank you
Jul 06, 2011 • Garden
Saw will not tighten when wrenching center nut blade slips
Unplug the saw. Put the blade on and finger-tighten the nut. Then rest the blade on a piece of scrap wood so that it won't slip. Then tighten down the nut and you should be fine.
2answers
I have an Andis outliner II I purchased a year ago. I recently changed the blade but it won't cut my hair. Do you kow why?
Sometimes the new blades from Andis are not sharpen enough to get that clean cut. also all trimmers need to be readjusted for power and alignment, plus sharpening the blade, it look like you need a complete sharpen & service on your Andis trimmer. check out Manny's Sharpening they have a Mail Order service, the service they provide is fast and they will sharpen make all the adjustment and give your trimmer more power and the blade will cut clean. They will even adjust the blade at your request on how you want that blade to be set at. Line Ups or Fade Cuts and even shave set. Manny's Sharpening been around for over 20 years and they have a very good rating on the net. Check it out Manny's Sharpening
1helpful
Sabre saw- craftsman - 17256 - change blades
This saw uses a tool-free blade change. 1. Unplug the jigsaw 2. Place your finger on the lower edge of the see through blade guard, and pull it forward until it locks up in place 3. Lift the tool-free blade change holder (bright yellow piece above the blade), and insert the blade into the slot of the tool-free blade change holder. 4. Release the tool-free blade change holder to lock the blade in place. 5. Pull down on the blade to verify that the blade is securely locked in place. The teeth of the blade should be pointing forward and down. 5. Put the blade guard back down.
You can use with both 'T' & 'U' shanked blades.
Feel free to ask me any other questions about this saw.
3helpful
2answers
How to change the saw blade
Adjustments
LARGEHEXWRENCH
TO REPLACeTHE BLADE
See Figures 43 - 45.
 Unplug the saw.
 Lower the saw blade, raise the blade guard, and remove the throat plate.
 Make sure the bevel locking lever is securely pushed to the left. Raise the saw blade to its full height by turning the height/bevel adjusting handwheel clockwise.
 Using the smaller hex wrench, insert the flat open end into the flats on the arbor shaft.
 Insert the closed end of the larger hex wrench over the hex nut. Holding both wrenches firmly, pull the larger wrench forward to the front of the machine. Make sure the blade nut is securely tightened. Do not overtighten.
Check all clearances for free blade rotation. See To Set the Scale to the Blade. In cutting operations, the scale will be set to the side of the blade where the cut will be measured and made.
To replace the blade with an accessory blade, follow the instructions provided with the accessory.
To install a standard blade:
 Place the new blade on the arbor shaft (the teeth must point down toward the front of the saw to work properly).
 Place the blade washer and the blade nut over the blade arbor. Be sure the dome side of the blade washer faces out from the blade and that all items are snug against the arbor housing. Tighten securely.
SMALLHEXWRENCH
Fig. 43
Blade
Bladewasher
arbor shaft
Bladenut
Fig. 44
BLADEGUARD
THROATPLATE
spreader
BLADE
Fig. 4535
ADJUSTMENTS
 Rotate the blade by hand to make sure it turns freely.
 Lower the saw blade and reinstall the throat plate.
NOTE: Securely tighten throat plate screws. Do not allow the throat plate to bow up above the table surface.
Sep 18, 2009 • Saws
Top Saws Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Saw Expert? Answer questions, earn points and help others
