Trying to use a Zebra ZTC ZM400 with an AS400
After a label prints, the label is duplicated with the page showing as 1*. The printer uses a remote outq on the AS400 and works fine with all the other Zebra printers but this one. Below are the settings for the printer.
JAY022423.08c442102122.79400-011.A.C
+10 DARKNESS
4 IPS PRINT SPEED
+000 TEAR OFF
TEAR OFF PRINT MODE
GAP/NOTCH MEDIA TYPE
TRANSMISSIVE SENSOR SELECT
THERMAL-TRANS. PRINT METHOD
832 PRINT WIDTH
1223 LABEL LENGTH
39.0IN 988MM MAXIMUM LENGTH
MAINT. OFF EARLY WARNING
NOT CONNECTED USB COMM.
BIDIRECTIONAL PARALLEL COMM.
RS232 SERIAL COMM.
9600 BAUD
8 BITS DATA BITS
NONE PARITY
XON/XOFF HOST HANDSHAKE
NONE PROTOCOL
000 NETWORK ID
NORMAL MODE COMMUNICATIONS
<~> 7EH CONTROL PREFIX
<@> 40H FORMAT PREFIX
<,> 2CH DELIMITER CHAR
ZPL II ZPL MODE
CALIBRATION MEDIA POWER UP
CALIBRATION HEAD CLOSE
AFTER BACKFEED
+000 LABEL TOP
+0000 LEFT POSITION
DISABLED REPRINT MODE
054 WEB S.
086 MEDIA S.
071 RIBBON S.
043 TAKE LABEL
050 MARK S.
002 TRANS GAIN
032 TRANS BASE
138 TRANS BRIGHT
219 RIBBON GAIN
011 MARK GAIN
DPSWFXM MODES ENABLED
....... MODES DISABLED
832 8/MM FULL RESOLUTION
V53.16.2Z <- FIRMWARE
1.2 XML SCHEMA
V37 --------- 38 HARDWARE ID
CUSTOMIZED CONFIGURATION
11200k...........R: RAM
2048k............E: ONBOARD FLASH
NONE FORMAT CONVERT
FW VERSION IDLE DISPLAY
07/02/08 RTC DATE
19:47 RTC TIME
DISABLED ZBI
2.0 ZBI VERSION
3,601 IN NONRESET CNTR
3,601 IN RESET CNTR1
3,601 IN RESET CNTR2
9,146 CM NONRESET CNTR
9,146 CM RESET CNTR1
9,146 CM RESET CNTR2
SELECTED ITEMS PASSWORD LEVEL
I was having same issue printing from our AS400's as well.
Issues was resolved by installing latest Zebra ZM400 firmware.
We were on ver V53.16.3Z but upgrading to V53.16.4Z seems to have resolved it.
Good luck.
Posted on Jul 25, 2008
Zebra ZM400 drops interface on port 515
make sure you have no network traffic for your printer and decrease the printing speed, and make sure you are using a free port not a used and default port for the service..
Jul 20, 2014 | Zebra ZM400 Thermal Label Printer -...
Have A Zebra Z6M Plus 300dpi printer Z6M00-2006-0000, then purchased a Zebra ZM400 300dpi printer, attempting to print using formats from Z6Mplus, result is a print approx 150 % larger ??? Downloaded...
Print configuration from both printers and compare. Print config- Hold cancel button 10 sec. while power on. Check Resolution parameter. 203dpi=8MM Full , 300dpi=12MM Full. Sounds like perhaps they are different dpi.
Apr 03, 2011 | Zebra ZM400 Thermal Label Printer -...
Zm400 print a part of a label. Hello, my Zebra ZM400 only print 1/5 last part ot the barcode label. Could you please tell me how to fix it?
What part, rigth site or bottom site?
check the lengt and the with from the driver and print the testpage (have to print on full label)
if is one of the sides, try to give more pressure to that side on the printhead.
Nov 17, 2010 | Zebra 203DPI Printer
Printing and counting problem with Zebra ZM400. We have connected a Zebra ZM400 to our network and we now have a problem with printing. When we print he prints the labels 1 by 1 instead of de total...
if you sending a file (ex. pdf or picture). to the printer, can do this, if you send the proper format with normal fonts (caracteres))to the printer, work fine. build new label from zebradesigner
May 20, 2010 | Zebra Z4Mplus Label Printer
Zebra zm400 turn printed info 180 degrees
Yu can rotate the print orientation in the Z Designer printer driver, in the OPTIONS tag tick the 180Deg box
Dec 17, 2009 | Zebra 300DPI CUTTER [zm400-3001-1000t]...
Prints larger that print preview shows...
Firstly make sure your using the correct drive ZM400 rather than Z4M. if you are using the applications driver make sure of headers and footers sizes and the print area is set correctly. If your using odd sized lables download some new drivers from the Nice Label website, they are far more adjustable that the standard Zebra drivers.
Aug 29, 2009 | Zebra Z4M Printer
Error condition ribbon out in ZM400
In the printer setting-
Change the Print Method from - "Tharmal Transfer to Direct Thermal" and save it permanently
Aug 10, 2009 | Zebra 105SL Thermal Label Printer
How to load new labels
http://www.scanonline.com/Online-Store/ZM400-600
Download the ZM400/600 Quick Reference Guide on the right hand side of the page. They have a diagram on how to load labels.
There should also be one inside the printer - printed on the back wall...
Jul 10, 2009 | Zebra ZM400 Direct Thermal-Thermal...
ZEBRA printing issues via AS400
*SAME
*WSCST
ZEBRA
*LIBL
*NONE
'10.27.9.21
Jun 26, 2009 | Zebra 105Se Thermal Printer
3,484 people viewed this question
k24674
jasbo
jasbo
