Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
My amana sise by side fridge wont drop the ice
My fridge has not drop cubes in two days. In the ice maker area the water has frooze but it wont release the ice. I cant figure out how to get the ice to drop.Amana side by side scd23vw
  • Anonymous Mar 12, 2014
    It's an Amana dbl dr and bottom freezer, approx. 2008 model.
  • 943 Answers
Hi thanks for the question probably have a problem with ice maker the timer in ice maker is not advancing to the drop off cycle need a new ice maker thanks the appliance doc
Posted on Sep 18, 2008
GE Profile REfrigerator: Model PFSS6PKWASS Problem with loud clicking coming from icemaker every 2-3 seconds. Will do this for 30-60 minutes constatntly, then will stop clicking for the same period of...
i have same fridge with same prob makes 6 cubes of ice in a day with a lot of noise like you discribed also i have water collecting under crisper drawer of fridge i have to clean out water once a month or so still trying to figure out how to take ice maker out to fix
Jan 25, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
MOTOR NOISE AFTER ICE CUBES DROP - LASTS 2 OR SO MIN UTES The noice is not always the same - sometimes steady hum as if small plane is going over - lasts a few minutes. Sometimes noise is loud for a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 07, 2010 | Amana DRS2660B Side by Side Refrigerator
Ice maker and hose from back of fridge to it both frooze up.
Good day,
If the fill tube overfilled the ic maker and is iced itself, it is due to the water valve in the bottom rear leaking slightly after filling the ice maker during a normal cycle. The water valve will have to be replaced. However, it will take time and patience to get it thawed properly.
The ice maker should be removed and set aside to thaw out completely.
As well, the fill tube must be thawed out itself very carefully. Haste makes waste here. A hair dryer can be used but very sparingly since it's possible to start melting things you don't want melted.
Ideally the machine should be shut down but that's your call.
Once the new valve is installed and the machine reassembled it should be fine.
May 22, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Hooking up water to ice cube maker
On page 4 step 3 of the manual on link below tells you how to hook up the water supply for your fridge.
http://shop.amana.com/assets/pdfs/literature/004251.pdf
Mar 13, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Amana SBD21VE No water to ice maker
your water line to the fridge is most likely leaking. You should turn it off right away. The line turn off is either behind the fridge or under sink. sometimes its in basement. The line is very easy to replace. You can get the plastic ones at home centers for under 5 bucks.
Jun 08, 2009 | Amana ASD2326HE Side by Side Refrigerator
Cubes won't dump into the storage bin
In photo below you can see the heating element that comes on moments before the ice maker drops the ice. If not working then the icemaker will struggle to unload. You need to unplug the refrigerator and then unpluge the ice maker and remove it to test these parts. Test with a multi meter or ohm meter. Test the 2 connections next to the number #26. Hope this helps, Sea Breeze
May 21, 2009 | Whirlpool GS5SHAXN Side by Side...
Ice Maker
well ur refrigretor is;nt producing enough gas to produce ice make sure u hire some expert who can examin and solve it.
Mar 18, 2009 | Amana ARSE66MB Side by Side Refrigerator
Water does not reach ice tray, ice maker appears to be cycling
Pull the filltube from out of the back check for ice inside, use warm water to melt.
Mar 12, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
551 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
