Question about 3Com OfficeConnect VPN Firewall - Firewall - 4 ports - 253 Connections - EN, Fast EN, English (662705471105)
Suddenly Disconnected Hai I have a problem in 3com,it will disconnect from network .once its restarted it will work it will happens 3 times a day
    Scholar:
  • 176 Answers
Maybe it's overheating ?! see if it is too hot, and if so, try to coolit (with a fan for example) and see if that is the cause ...
(i don;t know u;re product, but overheating is a general problem ...)
Posted on Jul 03, 2008
I Couldn't find out it's driver
3 com NIC card is universal plug & play device.
Please restart the computer once you insert it.
If still persists, update the driver from
"C:\Windows\system32"
All the best!!
Jan 30, 2011 | 3Com OfficeConnect 3CSOHO100B-TX Network...
My 3com 4200 28 ports is restarting by itself many
Base from the description of your problem its only showing that some of the port on of your Ethernet switch is already getting bad and this usually happen on switch like this and eventually all port will go bad and will lead to the replacement of the device. With this type of problem you can first try to adjust the speed of your network card to 10 half duplex and check if that will correct the connectivity problem and if it does its just a sign that sooner or later the device is already getting bad and since its only a switch there's no firmware that we can load to it or even a reset button to bring the device back to its default settings.
Jan 27, 2010 | 3Com 4200 24-Port Ethernet Switch
1995 Daewoo Racer, Stops suddenly for no apparent reason.
Check heat level of your at that time. A sensor is installed in its Radiator, which automatically turn off the vehicle (as the Temperature needle crosses 3/4) until its temperature falls. In case it is true, then; 1) clean its radiator 2) Check the sensor installed in its radiator. (this sensor was not available in 1993 model)
Aug 05, 2009 | 2001 Daewoo Lanos
Hi, i hav sony ericson W910i phone.. its always getting restarted atleast 3 to 5 times a day.. now my phone is suddenly got switched off when i sent a msg.. didnt get restarted for nearly 30 mins.. i hav...
hey that happens in w910 i...its common in all those sets...so whenever it happens like that u jus remove the battery once and fix it again...done then switch on u r mobile...prb solved!!!!
Jul 13, 2009 | Sony Ericsson W910i Cellular Phone
Cleaned coke off keyboard, not disconnected, wiped over all keys on left side of keyboard. Now nothing works on keyboard at all. How to reset?
Try disconnecting it once and connecting again after restarting...the same thing happened once and disconnecting worked..otherwise just restart and checck the cable is connected properly..
May 27, 2009 | EzKey EZ-8000 Smart Office Keyboard
Verizon USB727 - disconnects often
I have a friend who works for Verizon tech support. He told me awhile back that nowadays there are just too many people on cell phones. In your case what is happening is that some days there aren't as many users in your area as other days. Shopping, sales etc. From what I've seen here in Scottsdale, all the carriers have this problem/
Mar 22, 2009 | Computers & Internet
Problem with SW 4400 - restarting....
switch dont restart by themselves without command, first remove the switch from the network, disconnect from internet, make sure you hadn't fired anybody recently it sounds like a hack. reduce network traffic to local area only and priortise important internet traffic. now got back to the switch and troubleshoot make to check the reboot command on error or when error is found, if the problem stops when the switch is remove somebody is messing with the network.or the darn switch is faulty install a new one.
May 30, 2008 | 3Com SuperStack 3 4400 (3C17204-US)...
Disconnection problems
well i guess it under garatee my sugestion is to take it back to wear ver you got it from
Jan 28, 2008 | iRiver S10 2 GB MP3 Player
3com officeConnect with 16 connectors
check cable connection make sure it is all straight cable not cross cable, the switch could incounter traffic.
Mar 26, 2007 | 3Com OfficeConnect (3C1670500A)...
Handing Problem
You might consider trying to upgrade the BIOS's on the affected switches
Aug 26, 2006 | 3Com SuperStack 3 4228G (3C17304-US)...
3Com OfficeConnect VPN Firewall - Firewall - 4 ports - 253 Connections - EN, Fast EN, English (662705471105) Logo
141 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
