Question about Maytag Refrigerators
Refrigerator side of my side by side to warm
I have a maytag side by side--the refrigerator part is at the coldest set temperature but its still warm in the refrigerator part. It had been making ice but it seems to have stopped (freezer-side) . I have cleaned under the appliance for dust balls etc. The door is sealing good as I had a new seal put in about 2 years ago and the seal is soft and without any holes etc.
  • 828 Answers
Check the back wall of the freezer section for signs of frost buildup. Your problem could be caused by a frozen evaporator coil in the freezer section. After making your check come back and give the model number of your Maytag .
Posted on Jul 03, 2008
Maytag model MBR2258XES4 refrigerator and freezer not cooling well d
I had a similiar problem with mine..it ended up being the defroster board..it seems to kak out every 3 yrs..mine was under the temperature control panel..it was in a white box inder the cover..good luck.
Mar 25, 2014 | Maytag MBR2258XES Stainless Steel
The fridge part of our side by side maytag gc2225gekw keeps freezing even when the temperature setting is on 1 (7 being the coldest!) Any suggestions on how to set a better temperature!?!
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101;';';';
May 07, 2011 | Maytag Refrigerators
Temperature does not go below 59 deg. refrigerator side.
Auto Damper models, The Auto Damper model refrigerator has
two controls and both have capillary sensing.
The Auto Damper controls the fresh
food temperature and the Freezer Temperature
Control guides the freezer temperature.
The fresh food compartment temperature
is maintained by a damper assembly located
at the back of the temperature control
housing. Changes in air temperature
cause the damper door to open and close.
A control rod and gear connect the fresh
food control knob to the damper control.
Turning the fresh food control knob to the
COLDEST position increases the flow of
freezer air into the fresh food section. The
freezer compartment temperature control
warms at a faster rate and cools at a slower
rate, increasing the compressor run time
necessary to maintain a satisfied freezer
temperature control.
Turning the fresh food control knob to a
WARMER setting decreases the flow of
chilled air into the fresh food section. The
warms at a slower rate and cools at a faster
rate, decreasing the compressor run time
It is ver possible that the auto damper has failed and will need to be cosidered as a likely cause. Part Number Click here=> 61005971 or 1005641 Auto damper control assembly here is the Service manual=> MSD2756G Instructions can be foun on pages 38 and 39 in your manual.If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Feb 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
Side by side, freezer working fine but fridge side not cold enought, set at coldest temp. Could vent between freezer and fridge be blocked?
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 08, 2009 | Maytag MSD2656G Side by Side Refrigerator
Refrigerator top rack is warm. Temperature shows 65 degrees
if your freezer can make ice and the ice is dry, the problem is simply air flow into the refig section. A very common cause for a service call that wasnt needed for reefers is the settings. One setting OFF 1-10 usually, operates the compressor. The remaining setting will say , for colder freezer or similar, It opens a little flapper door between the freezer and the fridge section. If you set that one to max or coldest freezer it will actually starve out the fridge section for air ,and you get a cold freezer and warmer box! It happens everytime someone has the problem , its too warm! they peg both controls to coldest! The compressor will coll the freezer sufficiently even if set to 1 and the fridge should be cool too if the setting isnt pegged to coldest setting thus closing down fridge air and making the freezer colder which isnt ever required!
Aug 25, 2009 | Jenn-Air JSD2695KES Side by Side...
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
MAYTAG MSD2354ARW
How great is the freezer temperature? Look for frost on the freezer back wall. If there is frost there you have a defrost system problem.
the refrigerator is cooled by air it receives from the freezer. When the freezer coil freezes up the air circulation stops.
May 30, 2008 | Hotpoint HSS25GDMWW Side by Side...
Side by-side freezer is fine; fridge is warm
Reset the unit by unplugging it for about 9 minutes. Consult your manufacturer about how long after unplugging that the unit should be at it's set temperature.
Mar 01, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerator won't cool. Freezer works fine!
Pierce, there was a service bullitin put out on this model. TDR-0010A-B. Had to do with normal freezer, warm fresh food compartment. Maytag issued a kit that included a new thermostat and damper assy. to solve this problem. Bullitin came out in 2002. If you are not having a defrost issue and all fans are running normal, I would call Maytag and inquire about the above posted bullitin, It may be covered. Catriver...post back.
Sep 03, 2006 | Maytag MZD2768G Side by Side Refrigerator
Refrigerators Logo
89 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
