We have a few Mitsubishi electric air conditioning indoor units Model: PCFY-P63VGM-A Year 2002 They all seem to be dripping internally and leaking outside of the foam
    Novelist:
    Champion:
  • 230 Answers
They are probably thawing. This can be the result of lots of different failures, However the most common ones would be dirty filter(s) or low refrigerant.
Posted on Jul 03, 2008
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
Noise from the indoor unit of Mitsubishi MS09TW
My unit is a 3 year old Mitsubishi and it started making the humming noise you described. It is quite high and I finally got up on a ladder to have a look. It is the water pump making the noise in my case. It seemed like it was pumping a little too much water out. I undid a screw and angled the pump slightly and problem solved.
hope this makes sense and helps a little.
Jan 02, 2018 | Mitsubishi MS09TW Air Conditioner
I have a Mitsubishi split system with 2 indoor units (MS09TW) and one outdorr (MU09TW). The evaporator coil on one of the indoor units has been diagnosed by a A/C repair company as having a pinhole leak. I...
The following link includes service manuals for your air conditioning system: http://usa.mylinkdrive.com/uploads/documents/2388/document/MS-09~17TW,TN__MU-09~17TW,TN_Service_Manual.pdfI'm sure you find the solution inside the manual.
Sep 29, 2012 | Mitsubishi MS09TW Air Conditioner
Water dripping out of Mr. Slim on indoor unit.
Reason for water leaking.
1. Filter block. 2. Cooling coil block. 3. Alignment of indoor a/c unit is sloping downwards. 4. Drain pan block. It's advisable to service your unit first.
Jul 02, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
What does error code p8 mean
P8 means Abnormality in outdoor unit.
Check:
1) Wrong wiring of indoor/outdoor
connecting wire
2) Reversed phase
3) Protection device is working
4) Damaged outdoor coil thermistor
Solution:
1) Check the indoor/outdoor connecting wire.
2) Change the connection of electric wiring.
3) Check the protection device.
4) Measure the resistance of the outdoor coil thermistor.
If the resistance is normal, replace the
outdoor controller board
Hope, helpful.
Feb 03, 2011 | Mitsubishi Heating & Cooling
We have a P8? CAN'T FIND MANAUL
P8-Abnormality in outdoor unit.
1.Wrong wiring of indoor/outdoor
connecting wire.......................Check the indoor/outdoor connecting wire.
2) Reversed phase......Change the connection of electric wiring.
3) Protection device is working........ Check the protection device.(LP,HP)
4) Damaged outdoor coil thermistor.....Measure the resistance of the outdoor coil thermistor.If the resistance is normal, replace the outdoor controller board.
5) Check out door coil is cleaned. If not do it.
thanks.
Jan 30, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a Mitsubishi electric Mr Slimair conditioning. It runs a few minutes in cool mode, then it stops and an error of P8 code appears. When it runs, the fan is not strong.
connecting wire
2) Reversed phase
Solution:
Hope,it's helpful.
Jan 15, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi electric, AIR CONDITIONER model peh-8,10, 12myc ERROR CODE E6 ,
E-6-Indoor unit heat exchanger sensor [ThIR] defective (resistance is open circuit or closed circuit).
• Poor connection of sensor connector on the indoor PCB.Rectify or replace sensor.
Jan 04, 2011 | Mitsubishi Heating & Cooling
I have a Mitsubishi Mr Slim model MSZ12UN. The
you must see the indoor fan and you must clean it very good as well all the indoor unit.
Aug 13, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a a/c unit mitsubishi electric ms-12rv r22 when starting it on cooling or heating mode it stops after 30sec and the operating light flashes and the otdoor unit does not run the indoor unit fan stops...
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Apr 04, 2009 | Mitsubishi MS12TN Air Conditioner
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
