Question about Toshiba Satellite P30 P35 Series Notebook
I have a Toshiba P35-S611 laptop computer. I also have two power supplies for it. Which is the correct power supply. When I connect either one I get nothing.
5 Suggested Answers
SOURCE:
eagle338
  • 4889 Answers
SOURCE: Troubleshooting Toshiba Satellite P35-S611
This can be due to 3 reasons.Check these out and report back so that i can help you out
1.The AC power cord is damaged:Try connecting another chord to see if its the problem is with this
2.Damaged Battery
3.This is slightly tougher..you will need to open your laptop check if the DC powerjack is damaged..If you dont know how to check this come back and ask..I will guide you
Posted on Oct 21, 2007
SOURCE: Missing P35-S611 Restore CDROM
Boy some of you guys are just plain idiots? A restore disc is not illegal.
Posted on Jan 19, 2008
drifterK
  • 4924 Answers
SOURCE: Toshiba P35-S611 wont power on!
yeah if you are planing to do it yourself..it is worth ..I just bought last week a broke one and I payed something under 100$ ..and I changed the motherboard in one that was doing the same..so ...if you think you will use it ..its worth looking on ebay ..or parts to buy what is missing
Anyway check the power line on the motherboard ..it may be just something unplugged..or a little part..but if it does not get any power..its just that ..
The fact that is charging the battery it means that the power is ok from the charger and the entry on the board...so check the ram memory ..and the power cable of the board...cause if the charging is ok ..and the fan is working ..it may be something like a cable or the switch itself..( in this case the switch board is changeable in a few minutes and has just a plug and 2 screws..
Posted on May 08, 2010
Testimonial: "well i actually took it to a computer store where i live at and the guy looked at it for free, he said it was the motherboard but the power button doesnt even work, the fan doesnt kick on, when it s plugged in it doesnt do anything, so im wondering if the guy even looked at it really b/c he didnt charge me and he just told me i might as well junk it, i found motherboards for it online for like 90 bucks its just i dont want to spend 90 bucks and then find out its a power problem too. the power button is broken on it too, but that shouldnt stop the light from not coming on when i plug it in"
cirocpatel
  • 524 Answers
SOURCE: My Toshiba P35-S611 shuts down without warning.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
Posted on May 11, 2010
How do I start over with my computer toshiba p35 s611 do I have a restore on this model or do I need to format HD and reload XP? I dont have any restore disks.
if you go to "computer" and there is a partition or hard drive showing as "recovery" then you should be able to take your lappy back to its original state.
if not then you will need to format, depending on how old your system is anyway, a format might do some good.
Jan 02, 2010 | Toshiba Satellite P35-S611 Notebook
Toshiba Satellite P35-S611, power up failure.
Open the processor area located under your laptop. You can detached and re attached the processor, some sort of lose contact on pins. If same problem occur, your processor may burnt out. pm me [email protected] i will assist you remotely.
Oct 21, 2009 | Toshiba Satellite P35-S611 Notebook
Satellite P35-S611 has trouble charging
If you have to wiggle the power cord it is most likely the DC jack on the motherboard. It is usually the center pin in the the jack that breaks the solder point and the small tension band inside the jack housing weakens.
Sep 26, 2009 | Toshiba Satellite P35-S611 Notebook
Starts up for a second or two the shuts down
You can't conclude it is power just like that. What happens when it is connected to the mains? Same thing, then the problem might be a virus infection.
Sep 03, 2009 | Toshiba Satellite P35-S611 Notebook
Slow Hard drive
That model is only IDE capable and has no SATA ports on the motherboard. You should get a faster IDE harddrive OR an external USB harddrive .
May 08, 2009 | Toshiba Satellite P35-S611 Notebook
Lines on screen
usually when you have lines on your screen then you have to buy a new one
Apr 22, 2009 | Toshiba Satellite P35-S611 Notebook
My satellite P35-S611 will not run on AC power nor will it charge the battery
I have just fixed the same problem on my Toshiba p35 s611.
The power jack inside the laptop had been damaged. To reach the problem you must take apart the entire laptop (there are a few guides for doing this online). Next I simply found the positive connection coming from the jack (it is the wire coming out of the back of the jack) and followed it to where it enters the motherboard. I simply flipped it around and re-soldered that one spot. Other sites recommended I remove the jack but I couldn't melt the solder enough to do so, however just trying and adding some fresh solder was enough to fix the problem. I no longer need to jiggle the power connector to the right angle just to get power.
Feb 02, 2008 | Toshiba Satellite P35-S611 Notebook
Sorry but that would be illegal :(
Contact microsoft for a replacement.
Jan 05, 2008 | Toshiba Satellite P35-S611 Notebook
Toshiba Satellite P30 P35 Series Notebook Logo
78 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
