Question about HP LaserJet 8150dn Printer
Hp 8150 io error
I have problem with hp 8150dn printer.the problem is error on display 81..01180 io chennal not function ..How to sowl this problem
Regards
bhavesh
09913097699
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 121 Answers
Most I/O errors are the jetdirect card. You can try removing and reinstalling the card. You can also try installing the card in other MIO slot.
If the card is a jetdirect 615 failure is common replace with the 620.
Posted on Mar 06, 2009
What does the error message EI0 1 Mean on the 8150dn printer?
EIO is the External Input Output slot that is on the formatter of the printer. the 8150 has 2 EIO slots (EIO 0 or EIO 1). One of the slots is probably the JetDirect card (network card) for the printer. The second slot might be a hard drive but is usually open.
If you are getting a EIO error first try reseating the JetDirect card (power off the printer first). If you are still getting the error pull the card and power up the device with out the card installed. if the error goes away power down the unit and install the card in the other EIO slot. if the card works you have a bad slot on the formatter but you should be good to use the device. If you get another EIO error the card is probably bad.
Mar 10, 2015 | HP LaserJet 8150 Printer
62.0 error
62.XX error
There is a problem with the printer's memory. The x value refers to the location of the problem:
0 = Internal memory
1 to 3 = DIMM slots 1, 2, or 3
Recommended Action
Reseat or replace the specified
DIMM
It might also be the formatter but start with reseating the DIMMs
Dec 04, 2013 | HP LaserJet 8150dn Printer
Error 0.000000 aa
Error 0.000000 aa does not exist within HP Service manual, this said I have come across a few errors that dont exist, I would ask If the machine Sounds like its trying to come to ready ( eg can you hear the engine motors turning, does the fuser get warm, if so I would recommend you change the display As it could be a spurious error from the display module -or in the case the machine immediately displays the message without any motors turning or no heating of the fuser rollers , then I would recommend you start by replacing the firmware then the memory , finally the formatter in that order. hope this helps
Sep 25, 2013 | HP LaserJet 8150dn Printer
PCL XL error hp8150DN windows server 2003 for
Depending on what you are trying to print you might try updating the PCL driver or switching to a PostScript PS driver. the discrete drivers for that device were last updated in 2007.
Good luck
Aug 17, 2013 | HP LaserJet 8150dn Printer
HP 8150 error code of 57.5 comes up, I cycle power, I have checked all the cables and still comes up with error code. Does anyone have any suggestions?
Hi
Error code 57.5 in HP 8150 means that printer fan error has occurred with the power supply fan. This issue can also be due to laser/scanner fan. Make sure both the fans are working perfectly fine. If the fans are fine, then the error is due to DC controller board.
To resolve this error turn off the printer for 4-6 hours (atleast 4 hours), this will reset the error. However, even after 4 hours you still can see the error then please check and replace the fan1 (power supply fan). Also, check for any burnt components on the dc controller board.
Daniel Scott
Jun 18, 2010 | HP LaserJet 8150 Printer
Trying to setup tcp/ip settings on my hp laserjet 8150 series printer
First, make sure your Network Interface is working properly. Print a test-page. Menu--->Information------->Print configuration-page. If your machine print only one page, your interface doesn't work right. If your machine prints a configpage and a seperate network-page, you're good to go.
The easiest way is to look at the network-page and see if the machine already got a ip-adress. If it already got a ip-adress (DHCP), type that adress into your favorite web browser and do your config from the machine's web-interface.
Or you can access the printers menu.
Menu---->I/U---->EIOx settings---->TCP/IP----> and set your settings as you wish. Good luck.
Dec 14, 2009 | HP LaserJet 8150dn Printer
Printer problem - HP Photosmart 8150
If the printer cannot print or move any paper, follow these steps to display the Event Log. Otherwise, print the Event Log.
1. Press Menu until INFORMATION MENU appears.
2. Press Item until SHOW EVENT LOG appears. Press Select to show the Event Log.
3. Press - Value + to scroll through the Event Log.
4. Write down the error messages.
If you see a 52.X error then this indicates the following:
0 Laser/Scanner Error
1 Laser/Scanner Startup Error
2 laser/Scanner Rotation Error
ACTION:
1. Press GO. The page containing the error will automatically be reprinted.
2. Turn the printer off, and then turn the printer on.
3. Reseat the cables fort the Laser / Scanner Assembly.
4. Replace the Laser/Scanner Assembly
Sep 21, 2009 | HP Photosmart 8150 InkJet Printer
HP 8150 prints OK for 30 minutes then will not go.
I am certain you need to replace the tray one seperation pad. That will solve your problem.
I could walk you through it if you like. Very easy to do. Sep pad costs around $10 but it can be installed in two minutes. Easy.
Feb 14, 2009 | HP LaserJet 8150dn Printer
HP LaserJet 8150dn Printer Logo
167 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
