Question about HP Office Equipment & Supplies
Should I turn off my HP Photosmart C700 All-in-One Series printer when iI'm not using it?
    President:
  • HP Master
  • 1,314 Answers
Unless you are going to be using it sporadically throughout the day, then you can. However, it doesn't hurt to keep it on either, it just uses a little bit of electricity and if it has a power saver mode then that isn't even an issue. So, basically, the choice is yours. There is no pro or con in doing it either way.
Posted on Jul 03, 2008
  • Kevin Shafer
    Kevin Shafer Jul 05, 2008
    Could you take a moment to rate this as fixya? Thanks.
Printer HP Photosmart C5180 Series cannot be contacted over the network
Check with HP for a Windows 7 driver for the printer. HP Ink Jets require proper drivers to work correctly. Once you have downloaded and installed the drivers try connecting again.
If you have installed the drivers and Windows 7 still refuses to "talk" to the printer, you may have to adjust your advanced network settings as well. Open up the Network and Sharing center, click on advanced sharing settings and make sure file and printer sharing is turned on. Also check "File Sharing Connections" and enable file sharing for devices that use 40 or 56 bit encryption.
If that fails to work you may need to speak with HP support for further assistance.
Feb 23, 2012 | HP Photosmart C5180 All-In-One InkJet...
What to do hp photosmart c1580 series ink system
hat to do hp photosmart c1580 series ink system failure Oxc18a0001
May 01, 2010 | HP Photosmart C6280 Printer
How to set my ho photosmart c4600 series to work
Your photosmart c4600 series printer is a USB printer. It is designed only to work with USB cable. However you can use HP Wireless Upgrading kit to print wirelesly.
Apr 05, 2010 | HP Office Equipment & Supplies
My HP Photosmart C6280 will not scan documents to my computer. I have it connected to USB port on my wireless PC. I try scanning thru solution center and that does not work. I have turned off the computer,...
Solution
For Windows XP
*Go to Control Panel > Printers > HP Photosmart c6200 series > Right Click > select Delete
*Load the CD / Downloaded Software for HP c6200 series
*Select add a device > select usb (if preferred)/ wireless
*Wait for the installation to finished and repair the settings.
*Restart PC/ Try Scanning Again.
If it doesnt work, I suggest try uninstalling and reinstalling the software completely using the CD itself.
Hope this works. Good LUCK!
Feb 14, 2010 | HP Photosmart C6280 Printer
Need a new power cord, how much ?
Here you go:
Compatible Part No:
  • HP 0957-2094
  • HP 0950-4466
Compatible Printers:
  • HP OfficeJet PSC 1350
  • HP OfficeJet PSC 1355
  • HP OfficeJet PSC 2410
  • HP OfficeJet PSC 2410xi
  • HP OfficeJet PSC 2450
  • HP OfficeJet PSC 2510
  • HP OfficeJet PSC 2600
  • HP OfficeJet PSC 2610
  • HP OfficeJet PSC 5510
  • HP OfficeJet PSC 5510 all in one
  • HP OfficeJet PSC 5850
  • HP PhotoSmart 1315 all in one
  • HP PhotoSmart 2510
  • HP PhotoSmart 7960
  • HP PhotoSmart 7960w
  • HP PhotoSmart 7969
  • HP PhotoSmart PSC 2510
  • HP model numbers Q3435AR, Q3435A, Q3501A, Q3087A, Q3090A, Q3094A, Q3020AR, Q3020A, Q3023A, Q3024A, Q3021A, Q3022A
  • HP Bundle PSC1315+M307 Q5776A
  • HP OfficeJet 5500 Series All-in-One Q3434A, Q3435AR, Q3435A, Q3435P, Q3436A, Q3437A, Q3438A, Q3440A
  • HPPSC 1300 Series All-in-One Q3492A, Q3493A, Q3495A, Q3500A, Q3501AR,Q3501A, Q3502A, Q3503A, Q5532A, Q5534A, Q5763A, Q5765A, Q5766A, Q5767A,Q5768A, Q5769A, Q5770A, Q5771A, Q5772A
  • HP PSC 2410 PhotoSmart All-in-One Q3087A, Q3088A, Q3089A
  • HP PSC 2500 Series PhotoSmart All-in-One Q3094AR, Q3094A, Q3095A
  • HP PhotoSmart 7900 Series Printer Q3020AR, Q3020A, Q3021A, Q3022A, Q3023A, Q3024A Q3090A
For HP 0957-2094 PhotoSmart 2410, 2510, 5510 Printers and much more.Come with power cord. Power Rating: 32V 940mA and 16V 625mA
Note: Amps and Watts are maximum load tolerance. Devices only draw as many Amperes or Watts as they needed
For purchasing you might also contact this link below:
http://cgi.ebay.com/Adapter-For-HP-0957-2094-0950-4466-32V-940mA-16V-625mA_W0QQitemZ250414311173QQcmdZViewItemQQimsxZ20090427?IMSfp=TL090427149005r21586
Hope you like my info
May 25, 2009 | HP Photosmart 2610 All-In-One InkJet...
HP C4580 PhotoSmart Install Crash
Dial 1-800-436-0509 for technical support for HP Photosmart C4580 All-in-One Printer, HP Photosmart e-All-in-One Printer D110, HP Photosmart 8450 Photo Printer Series and best hp printer of 2017 HP Sprocket Photo Printer-One 1 800 436 0509 HP Printer Technical Support Phone Number
Apr 04, 2009 | HP Photosmart C4580 All-in-One InkJet...
Too many printers listed
Not sure what happen to this but I had the same problem. What you need to do is highlight each one except the first HP Photosmart 4100 series, and delete all the other ones.
So delete the following 6 printers.
Send to One Note 2007
Microsoft XPS Document Writer
HP Photosmart C4100 series (copy 1)
HP --------------------" ------" (copy 2)
HP....................................(copy 3) AND
HP ..................................(copy 4) which is the only one that works!!!!!
Now the one that is left should be the default. Do a test page or print something out to make sure.
This should fix your problem. Please rate.
Feb 19, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
My HP Photosmart 8450 no longer prints lines, boxes, etc., since I upgraded to VISTA and MS Office/Word 2008. HP says to buy a VISTA-compatible printer...they do not have an updated driver. Any solutions?
You can use the drivers supplied by Windows Vista
Verify that the printer is turned on.
Connect the Universal Serial Bus (USB) cable to the printer and to the computer.
After plugging in the device, select Don’t show this message again for this device.
Click Continue on User Access Control (UAC) Window.
Go to the Start ( ) icon, click Control Panel , click Hardware and Sounds , and then click Printers .
Click Add a printer .
Click Add a local printer .
Select the Use an existing port check box.
In the Use an existing port drop-down list, select USB001 and then click Next .
Under Manufacturer on the Install the printer driver dialog box, select HP .
Under Printers , select HP Photosmart 8400 series and then click Next .
In the Printer name text box, type the printer name and then click Next . The printer driver starts to install.
When the message You're successful and HP Photosmart 8400 series appears, you can print a test page to ensure that the printer is working correctly and then click Finish .
Apr 03, 2008 | Office Equipment & Supplies
Using JETCET Print with OKI C5200n Printer
The OKI 5200 is a 'GDI' or Windows only printer and does not support PCL or PostScript languages.
Most if not all of the printers listed support either PCL or PS or an inkjet based language.
I'm afraid you will not be able to print the the 5200 without it's driver loaded on the PDA.
If the 5200 supported PCL you would be able to choose any of the
Color HP Deskjets.
Oct 15, 2007 | OKI C5200n Laser Printer
54 people viewed this question
Ben Johnson
