Question about Kodak EasyShare C330 Digital Camera
Pictures for some reason i can only take 16 pic's , i have a SD card 128 in it , not quite sure how to use that part
    Genius:
  • 1,036 Answers
That should be good for about 200 pics.
Have you tried removing batteries and card and trying again?
You need to format the new card before use. There should be an option to do this from the menu.
Kodak's Tutorial for your camera is available HERE
Thank you for using Fixya! If it has provided a solution, please rate accordingly. Thank you.
Posted on Jul 03, 2008
Pics will not save to empty sd card
First, make sure card is empty. Erase and format it if it's not. Try another card to see if it takes the pics.
Jan 13, 2015 | Primos Truth Cam 35 3.0 Ir Infrared Game...
Memory full
If you are using the memory that came in your camera, and you do not have an accessory SD memory card installed, your camera's built in memory will fill up quickly because it has a very small capacity. If you have an SD memory card, it may be a small card with limited capacity. SC and SDSC memory cards are available with 4, 8, 16, 32, 64, 128 and 256 Gb capacity. Of course, the higher the capacity and the faster the card, the more you will pay. For most amateur applications 16 or 32 Gb should be sufficient. Optionally you could set your camera to take lower resolution pictures. That will increase the number of pictures your memory will accommodate, but there is a price; picture quality.
Apr 16, 2014 | Nikon COOLPIX S9500 Digital Camera Black
My camera doesn't see SD 16GB anymore. Worked fine until a few days ago. SD works fine on PC
Try inspecting the memory card slot, eventually with a magnifying glass. Sometimes just a little bit of dust, a small paper or other debris, can block data transfer. Be sure al contacts on the card, but also in the camera are clean and shining. Never use sharp tools in or around a camera. Don't scratch the contact points.
And to make sure you can put pictures on a memory card, there must be space. If possible try to format the card in the camera. Just to make sure the camera sees the correct file system on the memory card.
Dec 15, 2013 | Panasonic Lumix DMC-FZ28 Digital Camera
Memory full on SD card but still space left
FRIST, download the 83 pics u have and save them. your camera may be reading the internal memory. go to setup and change to sd card option. If that doesn't do it, and it's already looking at the SD card. Format the card. NOTE: see first line again!!!
Jul 31, 2012 | Fujifilm Finepix A600 6 3 Mp Digital...
I recently bought the vivitar 7024 and bought an sd card lexar multi use 4 gb. For some reason when I take photos and try to look at the pics it says no file exist. But when I take the sd card out and I...
Apparently, you have pics on the camera's internal memory. Your card won't work until those pics are gone. Here's how...with no card in the camera, go into the menu and find "format" and follow the on-screen instructions to erase the internal memory. Then, insert your card and it should work.
Aug 18, 2011 | Vivitar ViviCam 7024 Digital Camera
Stops taking pictures after approx. 128-130
Hi, Sue,
Not really sure on this, but if where he bought cam will take it back,try it...
However, it may not be the cam, but different resolution settings on the two different cams. Digital cams by different manufacturers format SD cards using different means; some allow more memory space on card for formatting than others..and if the game cam is set at a higher resolution than the other cam, then the 2nd cam might use space 1st cam left avail.i.e., say cam "sets aside 4mb of memory to format card, but only uses 2mb of this space. Now, the game cam is set for high resolution and take 130 pics @ 15mb each..15x130=1950mb,+ 2mb left by game cam=1952mb(1.952gb), or about 50mb of space left on card...put it into cam set for lower res. and might get several more pics before card was really full...be sure all is equal...both cams, and card,ect. 128-130 pics @ high resolution ain't bad....on a 4gb SDHC card with my I-40's set for High Res., I can get 1000 pics;@ enhanced and I get only about 300. Set at low res., and # goes way up.Hope you understand all this.
ron
Mar 11, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
I have a htc touch phone and i put all my pics on the storage card, and than one day all pics where gone and nowi cant even save my pics to the storage card.. and now there is storage card , and storage...
Why this happens:
If for any reason your phone cannot find the SD card on boot it will create a folder on your Phone's Memory called 'Storage Card' to put the Temp Files, Pictures, Music, etc into. Now as soon as the SD card becomes available, since there is already a folder called 'Storage Card', it is forced to name the "Real" SD Card 'Storage Card 2'.
Solution: Delete the "Storage Card" folder and soft reset. If the phone finds the "Real" SD Card, it will be named 'Storage Card' again. If for some reason it is not found, you might have a corrupt SD Card that needs to be reformatted. This would of course loose all the information on the card, so hopefully this is not the case. Warning: If you have pictures or other files in the 'Storage Card' directory, you will want to move them to 'Storage Card 2' before deleting 'Storage Card'. Use the 'File Explorer' found in your 'Programs' to do this. Good luck!
Aug 27, 2008 | HTC Touch P3450 Smartphone
No memory card will work in my Coolpix camera
Nikon has tested the following cards and approved their use in the Coolpix 3200:
SD memory cards:
SanDisk 16/32/64/128/256MB
Panasonic 16/32/64/128/256/512
Toshiba 16/32/64/128/256MB
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
Multi Media cards (MMC) are not recommended and should not be used.
Jan 23, 2008 | Nikon Coolpix 3200 Digital Camera
Micro SD Not Reading
I have same problem with A1200 not recognize micro sd card.
some one help ,Please.
Thank - you.
Oct 07, 2007 | Motorola Mobility A1200
Kodak EasyShare C330 Digital Camera Logo
21 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
