Question about Rinnai Vent Free Gas Heater/: 6,000 BTU RCE-229A
Rinnai Convector 404 Natural Gas
I have a Rinnai Convector 404 with the gas supplied by LPG bottles at the momemt. I have just moved into a house which has mains supply gas. I suspect the new gas is 'Natural'. Is there some sort of converter needed to use my old Rinnai if this is the case?
I have a natural gas unit. do you want to swap? 0407284314
Posted on Dec 26, 2009
  • realistic1 Sep 02, 2011
    you may need to get it back to the rinnai factory to convert it. give rinnai a call or your nearest gas shop/supplier
  • 53 Answers
No conversion parts available since 2005.
Posted on Jul 16, 2009
I have inherited a rinnai 516tr heater how do I tell if it is lpg or natural gas
There is a makes plate on it which say NG for nat gas or lp for lpg
Jan 07, 2013 | Rinnai Vent Free Gas Heater/
Is it possible to convert a rinnai avenger 25 from natural gas to lpg?
Yes it Should but you will want to check with manafactuer because it will need a conversion kit for lp gas. Natural gas is a different p.s.i. than lp gas so don't try without conversion kit. It should be just a small fitting that goes inside the gas valve. Hope this helps have a good day
Aug 12, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heater goes out after 20min error code 12 appears
Definately a gas supply problem. If it was an overheat you would get a different code. Error code 12 meant a flame was there but then went out. The code 11 meant tried to light but no flame sensed. Error code 12 on heaters and Infinites is nearly always a fault on the gas regulator at the bottles. Sure I recognise your company name from up in Queensland. As you might know we hae had problems with an oily residue in some regulators for ages. I am recommending going away from two stage regs and spliting them up with a seperate first stage and then a second stage. Bit more expensive by zero call backs.
May 24, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
What is required to convert an LPG Rinnai 1001 to natural gas
Its complicated to convert. Get a qualified gasfitter to do it. The part number to convert LPG to Nat Gas is R1911 (at least it is here in New Zealand)
Jun 14, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Need to convert rinnai convector 417 gas heater from propane to natural gas, are the nozzles available?
Rinnai New zealand conversion kit number, R1852.
VERY complicated - get a qualified gasfitter to do it.
Jun 10, 2009 | Rinnai Vent Free Gas Heater/
Bad gas smell when heater is operating
I would call him back out. It sounds like a gas line is loose or the vent is not on properly
Jun 01, 2009 | Rinnai Vent Free Gas Heater/
Need to move the unit by dismantling
Remove the two screws on the side trim. Remove the two top screws from the filter panel. Reach behind the heater and pull the sock down on the vent pipe. unclip the two clamps holding the vent pipe together. Remove the plastic elbow off of the vent termination. Slide the heater to the left to slide the vent pipe off of the vent termination. Remove the gas line after shutting the gas off.
Dec 28, 2008 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
Hi pinkinfinite,
The 404 is a great heater. I am assuming it is a Natural Gas Heater. All it needs is a good blow out with compressed air. They tend to carbon up in the pilot light area. You will probably also find it is very dusty inside. Easiest way to clean the carbon out is to remove the hose at the heater and with compressed air blow through the fitting where you have removed the hose. Make sure you hold down the start button so the air can get through to the pilot light and jets. Don't connect the electricity for the fan when you do this.
To clean it out internally you only need to remove the front panelling. There are two screws holding the top panel (not to be confused with the side and top). The screws are located inside the bottom grill at the front. There are also screws for the bottom grill there which you will also need to remove and probably best to remove the bottom panel that house the front feet. It should expose all the inside workings of the heater except for the pilot light and jets etc. You should be able to see the fan - it is round and looks like a filter and sits behind the vent section. Make sure you give it a good blow out - it gets all dirt and dust around it. When you do it remove both the rear filters/covers. They are mesh. Blow the top one which is the larger metal one and make sure you blow inside where it fits over to remove the dust and dirt. Same with the other one which should be plastic with mesh. Once you do this put it all back together. Make sure all wires are connected and be wary with the compressed air as it may blow the connectors off from loose fitting parts. Once you get it all back together Test it and hopefully it should work. Hope this helps. I did one the same today that was having trouble starting and it now works like a new one.
Regards
Bryan
May 06, 2008 | Heating & Cooling
Open Questions:
See all Rinnai Vent Free Gas Heater/: 6,000 BTU RCE-229A Questions
Heating & Cooling Logo
1,128 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
